Sudar Samba Member
Joined: May 18, 2015 Posts: 33 Location: Stewartstown, PA
Posted: Mon Sep 07, 2015 3:32 pm Post subject: Fuel filter |
I just moved my filter to under the tank.
Is it okay to leave it hanging or should I zip tie it to the brake line?
Maybe I should make a bracket and screw to firewall?
What has been done by those that place the filter under the tank, Glenn?
I put extra length of hose before and after the filter to make it easier to replace.
Thanks,
Darrin _________________ 1968 Ghia Coupe AKA "Harley"
1969 Beetle Standard AKA "Angus" |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Posted: Mon Sep 07, 2015 3:59 pm Post subject: |
I'd secure it to something. _________________ Glenn
Member #1009
#BlueSquare |
Sudar Samba Member
Posted: Mon Sep 07, 2015 5:19 pm Post subject: |
Glenn wrote: |
I'd secure it to something. |
It's hanging freely. Could I just zip tie it to itself where the lines cross? Wound that be too much strain on the tank elbow? _________________ 1968 Ghia Coupe AKA "Harley"
Glenn Mr. 010
Posted: Mon Sep 07, 2015 5:33 pm Post subject: |
Zip it to the brake line.
Or get a clamp and put a screw in the bulkhead.
Member #1009
#BlueSquare |
Sudar Samba Member
Posted: Mon Sep 07, 2015 6:42 pm Post subject: |
Thanks Glenn, I like that clamp idea! _________________ 1968 Ghia Coupe AKA "Harley"
Sudar Samba Member
Posted: Mon Sep 07, 2015 7:12 pm Post subject: |
and then there's this:
Comes with lifetime warranty!
Picture acquired from VWVortex.com _________________ 1968 Ghia Coupe AKA "Harley"
Sudar Samba Member
Posted: Sat Sep 19, 2015 7:22 am Post subject: |
So I found a electric conduit hanger at Home Depot, had a piece of aluminum flat bar and stair tread carpet and come up with this. I placed a strip of carpet around the filter so it wouldn't rub on clamp. I just used the drain hole already in the metal so I didn't add any holes to the car. There's still room around the mount so water can drain. Looks like it will work well.
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Sat Sep 19, 2015 8:36 am Post subject: |
Sudar wrote: |
Picture acquired from VWVortex.com |
ahahahahhaaaaa......I wondered where that wrench went.....LOL _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Tue Sep 22, 2015 9:10 am Post subject: |
I used this Plymouth Van fuel filter that came with a mounting tab and both in and out on the same side.
bhartwell59 Samba Member
Joined: December 28, 2014 Posts: 792 Location: dallas, tx
Posted: Tue Sep 22, 2015 11:02 am Post subject: |
i have a filter mounted above the rear axle.
thinking about adding a clear one under the tank... to catch and see any gas tank crap. _________________ '74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k |
Junkyardjockey Samba Member
Posted: Thu Jan 17, 2019 3:01 pm Post subject: |
runamoc wrote: |
sorry for bringing this up, but what is the part number of that filter & what brand? Thank you! _________________ Romans 10:9-10
SAVE THE SUPERS!!
1974 Super Beetle Sunroof
2022 Subaru Outback Limited XT in crystal white pearl
2022 Subaru Outback Limited XT in cinnamon brown pearl |
Posted: Thu Jan 17, 2019 5:38 pm Post subject: Re: Fuel filter |
Quote: |
part number of that filter |
I converted my fuel line to 5/16". From the tank, thru the tunnel, up to the fuel pump. The interchangeable part numbers are:
33324, 33463, GF168, 513, G477, 512, CH1, PFB53190
I think this filter has the stock hose size that can be used. Plastic but has in and out pointed to the same side.
PG6405 _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Thu Jan 17, 2019 7:33 pm Post subject: Re: Fuel filter |
http://lmgtfy.com/?t=i&q=Plymouth+van+fuel+filter
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
joey4420 Samba Member
Posted: Fri Jan 18, 2019 7:18 am Post subject: Re: Fuel filter |
I have to say, I like this idea of getting the filter out of the engine bay.
Since I am fairly new to the KG world, how hard is it to get to this area on the side of the road if you have a possible issue and need to check the filter?
Obviously Changing the filter after an x number of miles or x number of years would be best. |
smuenchrath Samba Member
Joined: February 20, 2005 Posts: 371 Location: Calgary, Alberta
Posted: Fri Jan 18, 2019 12:23 pm Post subject: Re: Fuel filter |
con: it's a plastic filter. it's $40 with free shipping.
Here is a metal filter with a mounting tab under $13 and free shipping also
https://www.ebay.com/itm/Fuel-Line-Filter-Replacem...1298030666 _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
c21darrel Samba Member
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Fri Jan 18, 2019 2:52 pm Post subject: Re: Fuel filter |
Someone should make a combination distributor cap and fuel filter mount.
Better yet, just manufacture it from clear plastic and incorporate the fuel filter right into the distributor cap itself!
That would be Da BOMB! |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
