jp52 Samba Member
Posted: Fri Jan 18, 2019 5:43 pm Post subject: Screw(s) loose (actually missing) turn signal/wiper assembly |
Hello all,
I'm looking for the 45-55mm long machine screws that hold the turn signal/wiper assembly together. The appear to be 3mil screws with a fine thread. Local hardware stores are stumped and my only local scrap vanagon is already missing them. Anyone have a source?
These are the screws that are located behind the steering wheel and hold that sandwich of plastic and metal together that makes the turn signal, hi/low wiper assembly work right.
For some completely unknown reason (previous previous owner?) all three are missing.
Thanks!
Jon |
stormforge Samba Member
Joined: May 05, 2009 Posts: 355 Location: Adirondacks NY
Posted: Sat Jan 19, 2019 5:29 am Post subject: Re: Screw(s) loose (actually missing) turn signal/wiper assembly |
McMaster Carr has every sort of screw you could desire:
https://www.mcmaster.com/screws
When ordering if you ask for "cheapest shipping" they will usually ship small packs of fasteners flat-rate USPS which is very affordable.
-Bill
'89 Syncro |
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 925 Location: Calgary, Canada
Posted: Sat Jan 19, 2019 6:17 am Post subject: Re: Screw(s) loose (actually missing) turn signal/wiper assembly |
I found long thin screws - don't recall if metric - at a local hobby shop. They're used by RC cars and plane builders. _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Sat Jan 19, 2019 7:55 am Post subject: Re: Screw(s) loose (actually missing) turn signal/wiper assembly |
Morning Vanagon brother;
Here’s a tip on how to locate parts for your Van:
Step one, find the part #
- you need to look up a parts catalogue to find the number. Here’s a link to one : https://7zap.com/en/
Now you have an accurate description of the part you seek and a VAG part #
- copy the number and search it on the web. Better yet, go to a Vanagon specific parts supplier and enter the number in their search field.
The bolts you need are available. Be aware that the threads in the lock housing which they thread into can be easily stripped out and may in Fact already be.
Fahrvergnügen _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
