icekoffee Samba Member
Joined: March 14, 2005 Posts: 1239 Location: DeSoto, Missouri
Posted: Mon Dec 17, 2018 12:02 pm Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
thirtyseven wrote: |
Wow, congrats on that nose, that turned out really nice! The bus looks perfect.
I guess you did more than just a Krylon job? |
Thanks! I had tower paint mix me up a couple cans of acrylic lacquer spray paint in the original colors
Peter_N wrote: |
Nice job on the nose!
How did you get those wear patterns if I may ask? Fine sandpaper, paint stripper?
Thanks |
Thanks! I noticed during past sessions of color sanding that I have a god given gift for burning through paint so I used the gift to antique the paint. After spraying I wet sanded with 1500 grit then some 1000 and 600 where I wanted to burn through and recreate wear. _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1958 Patina Beetle EJ25
1984 Vanagon Westfalia EJ25
1964 Lifted Mouse Grey Standard
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
ozzmonaut Samba Member
Joined: November 29, 2008 Posts: 151 Location: mount airy, NC
Posted: Tue Dec 18, 2018 6:23 pm Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
I am really liking this. I have a 60 SC and it will be used as an actual truck (meaning to do truck stuff). I wasn't sure about the WW wheels, but they look good on yours, so I may follow suit, since I plan on using similar tires. A previous post had someone asking if they were cheaper than used OG wheels. In my mind, I can get wheels cheap, but the time I would spend sanding , cleaning, painting, etc, outweighs the need to save a few bucks per wheel and risk one or more having an issue I didn't detect.
I want to raise mine as well. I'm curious about the flipped beam with raised spindles. I can't find raised spindles, and just assumed people were using lowering spindles but flipping them and switching sides. But is flipping the beam neccessary, or was that just for extra lift? Sorry for so many questions (and I realize it was done before you got the bus) but I figured since your bus has exactly what I need to get mine where I want it, I may as well ask here. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22461 Location: Escondido CA
Posted: Wed Dec 19, 2018 3:04 pm Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
Those Geolanders are impressive. Im going to use those on my 77 Westfalia here soon to be clad in 15's. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Sat Dec 22, 2018 6:36 pm Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
Got some mouse grey layed down on the rockers. It looks semi okay when its in the shop. Not even close when it is outside in the sun. not totally sure what I am going to do.
I got the interior together and in... minus the fridge. Still debating installing the fridge
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
Posted: Tue Dec 25, 2018 12:35 pm Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
When I was much younger, I had a 71 with jalousies and bed/jumpseat. I thought I needed a camper, so when I came across a 73 full camper for cheap, I sold the 71 to a friend for almost nothing. I found out that I did not need the full interior. The pop top was nice and the bed was great. Everything else was just clutter. Yours looks useful right now. For me, a small cooler that I could take out was better than a fridge. |
Posted: Tue Dec 25, 2018 4:40 pm Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
She is out of surgery and back on the road. It was good to drive it again.
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Tue Dec 25, 2018 5:57 pm Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
ozzmonaut wrote: |
i am with you on the fridge. a LARGE cooler is much better than any fridge. a 160 can cooler will keep your beer cold for days even in 90+ degree weather. Even if you camp with a couple of buddies. And you can put it outside..... _________________ regards
Uli
Posted: Tue Dec 25, 2018 6:17 pm Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
This evening my wife made some awesome curtains for it.
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
Posted: Thu Dec 27, 2018 9:35 pm Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
I'm curious about the rim/tire combination. According to the online tire/wheel fitment resources, a 215 tire requires a minimum 5.5" rim width. The WW rims are listed as 4.5". Any fitment issues? |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Fri Dec 28, 2018 7:56 am Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
icekoffee wrote: |
Compliments to your wife; they look great. I like the color combination between the curtains and upholstery and the greys of the door panels and exterior paint. Good-looking bus all around, and good luck with sale! _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Posted: Fri Dec 28, 2018 11:34 am Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
ozzmonaut wrote: |
Most tiers have that requirement even when the old 165's were available. All I can say is people still fit them on and have no issue. Im personally going to run Audi 15's on my bay window (different rim) and still have the 215/75/15 size. _________________
t3kg wrote: |
1964 1500 S
Posted: Sat Jan 19, 2019 4:09 pm Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
Installed some stock spindles on the front of the bus and did some reindexing on the rear. Went up one inner spline and down two outer splines. Got rid of that crazy positive camber in the rear
brought her in from the cold
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
Posted: Sun Jan 20, 2019 6:26 pm Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
The transformation so far
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
Posted: Sun Jan 20, 2019 6:40 pm Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
icekoffee wrote: |
i like it. Only thing that bothers me is the corner treatment on the rear bumper. Looks awkward. would look better if it was more tucked in like the front corners _________________ regards
Uli
KrisBalfe Samba Member
Posted: Tue Jan 22, 2019 9:16 am Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
Awesome bus. |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Posted: Tue Jan 22, 2019 9:23 am Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
mandraks wrote: |
i like it. Only thing that bothers me is the corner treatment on the rear bumper. Looks awkward. would look better if it was more tucked in like the front corners |
It would look perfect if he had a roof rack towards the back of the bus, the bumper ends would make a great step when loading stuff onto it! _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
1966 Beetle: My new project. (SOLD) Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040 |
Posted: Tue Jan 22, 2019 10:40 am Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
vwuberalles wrote: |
mandraks wrote: |
It would look perfect if he had a roof rack towards the back of the bus, the bumper ends would make a great step when loading stuff onto it! |
I agree and I actually have a rack I could use. The only problem is that with the rack on it doesn't fit in my attached garage _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
zehbeh Samba Member
Joined: February 16, 2008 Posts: 249 Location: Stuttgart
Posted: Tue Jan 22, 2019 11:47 pm Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
What about lowering and putting a roof rack on top??
Hope you too don't like that idea.
Your bus looks absolutely great as it is. |
Posted: Fri Jan 25, 2019 8:55 am Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
More power! Put in a fresh 1776. Going to put that trusty single port into my thing.
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
splitty_64 Samba Member
Posted: Sat Jan 26, 2019 7:47 pm Post subject: Re: Lifted 1964 Mouse Grey standard gets some attention |
WOW! awesome thread. I am curious though, I have a 64 as well and I noticed you had rear heat. Was that optioned or factory? I don't have that in mine, wish I did though. Really cool bus man. |
