OKType3Tim Samba Member
Joined: April 30, 2011 Posts: 279 Location: Northeast Oklahoma
Posted: Sat Nov 10, 2018 7:54 pm Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
Nice tip, thanks. _________________ '69 Squareback restoration
'69 Fastback restoration
'66 Type34 |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Fri Jan 18, 2019 7:11 pm Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
I had a dealer tell me that TRW has been sold to ZF and the steering box production has been moved to Germany. Anyone else hear this? _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Posted: Sat Jan 19, 2019 8:49 am Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
That transaction completed in early 2015. I don't have any information regarding whether manufacturing operations were moved from one place to another. _________________ '69 Squareback restoration
'66 Type34 |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Mon Jan 21, 2019 3:10 pm Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
Looks like I’m just about ready for reassembly!
Everything has been cleaned and rebuild kit purchased.
New worm shaft
Lucked out and a neighbor gave me this granite sink cut-out. Just the right size.
Resurfaced the adjustment screw.
I have Corn Head grease being delivered later this week. In the mean time I’ll get the body, lid, etc. painted black.
Am I missing anything else needed before the final assembly? _________________ 1976 Westy
1966 Beetle |
Posted: Mon Jan 21, 2019 3:42 pm Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
Looks like you are prepared.
Work the top of the housing on the surface plate to make sure you have a nice level sealing surface:
And chase all the threads.
Also, based on recent evaluation of a couple units that had now been reassembled for a couple years; I recommend going on up to 22-25 ft-lbs on the cover bolts, and using blue (medium) threadlocker. At 15-18 ft-lbs and no threadlocker, we have seen a couple bolts become loose with time. _________________ '69 Squareback restoration
'66 Type34 |
Solidbug Samba Member
Posted: Fri Jan 25, 2019 9:29 pm Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
Bala/ May I ask where did you get the rebuild kit ? |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5995 Location: Brooklyn
Posted: Sat Jan 26, 2019 12:04 pm Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
Solidbug wrote: |
From the man himself:
https://www.thesamba.com/vw/classifieds/detail.php?id=2013334 _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Bala Samba Member
Posted: Thu Jan 31, 2019 8:49 am Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
Yes indeed, straight from Tim. Awesome that he is offering these kits.
Next steps complete.
I resurfaced the housing/lid mating surface.
Before
I used 1500 grit wet/dry sandpaper, and it took a LONG time. Just what I had around and was actually kind of relaxing working it on the granite.
After 3-4 sheets of paper and a good 1/2 hour. I can still see a few original tooling marks and what looks to be some sort of factory stamping (check out the upper left corner), but otherwise it is very flat and mirror shiny.
Painted all my parts.
New worm shaft all cleaned off.
And got my Corn Head grease in the mail! They sent me horizontal CHG when I requested vertical as it specifies in the Bentley. Hope this still works.
I've installed the adjuster screw bearing dry and it feels perfect I think. But, I'll have to take it back apart and add grease to see if it still feels right.
Tim, should if feel similar to the resistance when adjusting valves but maybe a little more firm? _________________ 1976 Westy
1966 Beetle |
Posted: Tue Feb 05, 2019 4:25 pm Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
Good progress BALA.
Yes, that would have taken some time starting with 1500. But, your shoulders are all "buffed up" from all those repetitions.
I start out with "Fine" emery and finish with 2000.
'66 Type34 |
Bala Samba Member
Posted: Wed Feb 06, 2019 7:52 am Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
Thank you!
Yes, it was a workout for sure.
Did you see my question on the adjustment screw above?
I have non of the specialty tools, so I'm sure I'll have plenty more inquires coming. Hopefully my slow progress will be a decent guide for the "average" box rebuilders out there. _________________ 1976 Westy
1966 Beetle |
Posted: Wed Feb 06, 2019 9:10 am Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
Bala wrote: |
When assembled with grease, the adjuster screw should turn freely, but without any vertical play.
(Sorry, saw the question and forgot to answer sooner.) _________________ '69 Squareback restoration
'66 Type34 |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Wed Feb 06, 2019 9:15 pm Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
_________________ Bus Motor Build
What’s That Noise?!? |
maggiolo72 Samba Member
Joined: April 24, 2013 Posts: 332 Location: Basel (CH)
flyingbrick Samba Member
Joined: January 26, 2019 Posts: 1 Location: Hamilton, New Zealand
Posted: Thu Feb 07, 2019 10:53 pm Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
OKType3Tim wrote: |
Next, I build up the roller shaft.
The roller shafts are degreased, all the paint and gunk is removed from the bottom of the shaft and the splines where the steering drop arm attaches.
Then checked for wear on the surfaces that ride on the brass bushings. This one is pretty suspect at the top of the shaft. I rejected it:
Then check for wear on the roller surface:
With my limited experience I think this one has only moderate wear, and will still have some life in the roller surface. I.E. the shinny wear is not all the way to the bottom of the groove, and there are no FLAT spots anywhere on the roller surfaces.
Then the roller is checked for axial (side) play. The Bentley spec is that if a 0.05-mm (.002-in) feeler gauge can be pushed between the roller and washer, then the roller shaft must be replaced.
This one is bad (double the allowed play):
This one is just barely ok:
Note, that every bit of side play at the roller translates directly into free play when you move the steering wheel back and forth.
The roller rides on a cage-less needle bearing. The movement should be smooth without excessive play. Here are some pictures of one that was NOT smooth. (but it still turned.)
Yep, those needle bearings are worn out.
The adjuster screw bearing surface at top of the roller shaft must be clean and smooth:
And the circlip WILL BE worn, so replace it.
Note: The adjuster screw is a bearing. The adjuster screw is fixed/locked in the cover plate. And applies continuous pressure to the top of the roller shaft as the shaft rotates back and forth.
I found a unit that had been assembled "DRY" and even though it had never seen service, the adjuster screw already shows scaring.
Since the adjuster screw is a bearing, I make sure that the surface is nice and smooth,
by doing a few figure 8 motions on the surface plate:
With this result:
So now I have all the parts.
Acceptable shaft
Polished adjuster screw
Selection of Roller shaft shims
New circlip
Adjuster screw lock nut
Note that the shaft bearing surfaces are clean, bright, free of damage. On this unit, the bottom section of the shaft has been "blackened" to protect from corrosion.
I test fit the adjuster screw, shim and circlip dry.
And the adjuster screw turns nicely, just right.
BUT I disassemble and fill the cavity with corn head grease,
and the circlip has to be forced into the slot and the adjuster screw is so tight that it will not turn. So I back off one size on the shim:
Note: both the shims shown above are VW shims. So you get an idea of what the manufacturing tolerance on those shims were.
And all is well. No sloppiness, adjuster screw turns nicely, but firmly:
Next, I'll examine the worm shaft. |
Im feeling less and less optomistic about a good steering box rebuild after reading all these pages of thread.
Interested in how you got that pin out.. do you drill out one side? I cant tell if its peened over or not and she wont budge |
duncan1958 Samba Member
Posted: Sun Mar 31, 2019 10:08 am Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
Bought a new box for my type 3
With these markings
AMPRI
24109
1618
This was from a vender online in the UK
Got the box home (Spain) unpacked it and it does,nt rotate freely/smoothly as I would expect a new box to be.
After reading this fabulous article I am concerned that what I have bought is of poor quality.
Could I make adjustments to the box to eliminate the roughness of the turning action, I have not installed the box yet but have removed the one that was on my squareback, The adjustment top screw was wound right in and had a large amount of play on full lock and felt tight in the centred position.
Looking for guidance as to best course of action.
Rebuild original box ?
Strip new box (mildly) to investigate cause of non smoothness ?
Thanks in advance guys |
Posted: Mon Apr 15, 2019 7:12 pm Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
flyingbrick wrote: |
Yes, the only way is to drill off the end of the pin. I mounted the shaft in my mill and used an end mill to take off the end of the pin. So yes, I destroyed that unit in the name of science. [although obviously, it was already pretty destroyed.] _________________ '69 Squareback restoration
'66 Type34 |
Posted: Mon Apr 15, 2019 7:27 pm Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
duncan1958 wrote: |
With these markings
AMPRI
24109
1618
Could you post a picture of the box you purchased?
With the adjustment top screw wound right down in; my experience is that both shafts are gone. Possibly the top bushing also. The question will be if the bottom bushing is still worthy. If it is, then new shafts, the kit, and a rebuilt top bushing could get you back in service.
Another option is a new, real TRW that doesn't have machining errors; Take it apart, clean out the bad grease, cheap bearings and seals. Use the bearings, seals, etc. from the kit. Corn Head Grease. Adjust it properly. Several individuals have had success with this approach.
Here is a bad TRW machining error:
Make sure the drop arm slides onto the roller shaft when you receive the unit. This one doesn't fit. The splines on the roller shaft are not spaced properly. TRW made good on this one and provided a replacement. _________________ '69 Squareback restoration
'66 Type34 |
Posted: Tue May 14, 2019 3:22 am Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
here is a photo of the box,doesnt tell you much really
have adjusted the top set screw in a little with wheels off the ground and steering wheel centred took for short drive and seems to track better in straight line at speed 100mph although still not confidence giving feeling at the wheel
there is still what i would call too much play when the steering wheel is in the centre /straight ahead position.
have ordered some oil seals and corn head grease to rebuild the original box |
Absoluteyeti Samba Member
Posted: Tue May 14, 2019 7:04 am Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
This popped up just in time, I might be picking up a box of type 3 steering boxes this weekend if all goes to plan.d |
monikober Samba Member
Posted: Fri Jul 05, 2019 5:12 pm Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild |
Where can I find a steering gear box for a 1971 Karmann Ghia. My mechanic said no TRW......Help |
