Replaced my rear axles
sam_w
sam_w is offline
PostPosted: Fri Aug 18, 2017 8:01 am    Post subject: Replaced my rear axles Reply with quote
My 'new' 74 Thing was making a clicking noise going around tight corners, and I checked and the boots were shot on the rear axles. SO instead of getting new boots I got a pair of Chinese axles and had my friendly VW mechanic Adam, replace the axles. They came with new bolts and washers, but the bolts were six pointed not the 12 pointed in place, so Adam used the old bolts. I will keep track on how long they last and I know Solomon Grundy will hate these boots, we'll see, $110 for 2 axles isn't worth sneezing at.
63 singlecab
73 thingster
74 Thing
Vanapplebomb
Vanapplebomb is offline
PostPosted: Fri Oct 05, 2018 7:45 am    Post subject: Re: relaced my rear axles Reply with quote
How are they holding up? Are these the ones with generic Type 2 joints instead of Type 4? I have the EMPI 90-6905 axles, which look similar. They fit things, but have the Type 2 joints. I have installed them on buggy’s before, and they held up well. I just installed a set on my personal project this past week, but I am really pushing it. At just over 20 degrees full drop, I suspect the cv joints won’t last long and I will be replacing them with Type 4 or “off road” Type 2 joints good for 25deg.
1800 Type 4 Berrien 295
sam_w
sam_w is offline
PostPosted: Fri Oct 05, 2018 7:56 am    Post subject: Re: relaced my rear axles Reply with quote
They seem to be fine, and I think they have Thing CV's.
I'll take a pic amd post it.
Sam
63 singlecab
73 thingster
74 Thing
74 Thing
74 Thing is offline
PostPosted: Fri Oct 05, 2018 8:56 am    Post subject: Re: relaced my rear axles Reply with quote
If those are the Empi kit cv's then I believe that they are Type II cv's and not Type IV. Glad they are holding up though. Empi has some race cv's that provide greater angles of movement.
Vanapplebomb
PostPosted: Mon Oct 08, 2018 2:20 pm    Post subject: Re: relaced my rear axles Reply with quote
Sam, look for a number on the EMPI cv joints. Example, VW 202-x-xxx. Just curious what yours are labled as.
Wildthings
Wildthings is offline
PostPosted: Mon Oct 08, 2018 7:03 pm    Post subject: Re: relaced my rear axles Reply with quote
Thing CV's are something like 1/8-3/16" thicker than bus CV's. Measure the thickness and we can tell you if you have Thing CV's or not.
Vanapplebomb
PostPosted: Mon Oct 15, 2018 6:39 am    Post subject: Re: relaced my rear axles Reply with quote
I called up EMPI for fun just to see what they had to say. They looked up the individual parts to the axle assembly on their bill of materials, and they are in fact regular bus CV joints.
Surprisingly, I don’t have any binding what so ever on my buggy with the axles areticulated to about 22 degrees. No clicking, no nothing. I’m very surprised.
Time will tell, we will see how long they last. I have never pushed these axles so far before.
Vanapplebomb
PostPosted: Mon Jan 21, 2019 10:29 am    Post subject: Re: relaced my rear axles Reply with quote
Sam,
Did you get a chance to look for that part number on the CV joints?
sam_w
sam_w is offline
PostPosted: Mon Jan 21, 2019 8:40 pm    Post subject: Re: relaced my rear axles Reply with quote
I was trusting, so did not check.
Typ181 CV's are slightly longer tham typ2's so that is a way to check
I believe that a type 2 does 18 degrees where a type 181 does 22 degrees
Check the 'blind chicken racing' website for details of cv joints
63 singlecab
73 thingster
74 Thing
Vanapplebomb
PostPosted: Tue Jan 22, 2019 6:57 am    Post subject: Re: relaced my rear axles Reply with quote
I know mine came with T2 joints. Between the part number, ball size, and thickness of the outer race.
Apparently they can be had with different joints if special ordered, so there are other varieties out there. Would be interesting to know what you had.
At full drop, what angle do your axles sit at?
[email protected] Premium Member
mpb181@aol.com is offline
PostPosted: Sat Feb 02, 2019 7:22 am    Post subject: Re: Replaced my rear axles Reply with quote
The balls are larger on type 2 cvs and the cages are silver colored
They dont allow as much travel as the thing ones
I have a small pile of thing cv complete assemblies with good boots
they have smaller balls and are usually brown or dark colored cages
Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173
PostPosted: Sat Feb 02, 2019 7:23 am    Post subject: Re: Replaced my rear axles Reply with quote
These:
http://www.thingparts.com/cv-axle-assembly-complete-vw-thing-type-181/
I also have some loose axles, cv ends a la carte
Michael Basso
CALL 518 630 0173
Thing68
Thing68 is offline
PostPosted: Fri Dec 20, 2019 6:10 pm    Post subject: Re: Replaced my rear axles Reply with quote
The EMPI 90-6905 axles are advertised as "Thing Only".
PostPosted: Fri Dec 20, 2019 6:15 pm    Post subject: Re: Replaced my rear axles Reply with quote
China junk
Michael Basso
CALL 518 630 0173
