2Dokas Samba Member
Joined: October 09, 2004 Posts: 752 Location: Santa Cruz, CA
Posted: Tue Jan 15, 2019 4:24 pm Post subject: distributor model a bus? |
I am putting my 1956 convertible 36hp engine together and the distributor was in pieces,
But I am not sure what the model is: I have looked at Glenns webpage and I don't see this one.
The part numbers look like a Bus... 211.....
I am guessing it would work.
the part number on the vacuum advance is 211...
this shows the 211 part number as well.
and, where do these 2 washers go, they appear to be nylon, I am thinking under the points or under the base of the points (wrong name I know).
_________________ 87 Doka 2WD Ej22,
56 Convertible |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Jan 19, 2019 7:41 pm Post subject: Re: distributor model a bus? |
What you have there is a Garbe Lahmeyer distributor not Bosch. They were originally installed on Buses starting in 1955 with a mechanical advance, thus the 211 part numbers all over it. It wa used sporadically throughout the 1960’s not just 1965 on all VW models especially on domestic production. It’s probably not a good match for a 36 hp. Yours is not one of the adjustable later versions. There are five phenolic shims, one on each side of the cam as it passes through the housing, one on each side of the condenser through bolt as it passes through the housing and one between the two halves of the points where the brass post is. _________________ Roads Scholar &
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sat Jan 19, 2019 7:45 pm Post subject: Re: distributor model a bus? |
You would be better off with a Bosch VJ4BR8 or 0231 129 019. They are the same.
They are mechanical only and used on 99% of the VW Buses. Tuneup parts are readily available. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Jan 21, 2019 3:51 pm Post subject: Re: distributor model a bus? |
The "019" typically sells at a premium price, better to source a VJ 4 BR 8. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Mon Jan 21, 2019 9:33 pm Post subject: Re: distributor model a bus? |
The O P is working with a convertible. The stock distributor would have been a VJU 4 BR 8 with vacuum advance. This distributor has the same mechanical advance as the 019 with the added bonus of vacuum advance. _________________ Roads Scholar &
2Dokas Samba Member
Posted: Tue Jan 22, 2019 11:11 am Post subject: Re: distributor model a bus? |
great information, thanks guys!
Peter _________________ 87 Doka 2WD Ej22,
56 Convertible |
