Vanagon Nut Samba Member
Posted: Sat Jul 14, 2018 11:07 am Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
Use a length of 3/8" copper on a shop vac to remove crud out the vent hole? Spray crud with WD40 then loosen or remove fill bolt first? But if you use a pic tool to clear that hole, I'd think that if a small amount of road dust got into the tranny, it would be of little consequence if any.
1988 West DIY 50º ABA
VE7TBN |
?Waldo? Samba Member
Posted: Sat Jul 14, 2018 11:45 am Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
There is a 'pocket' chamber that the crud falls into. It does not fall into the actual lube. |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Sat Jul 14, 2018 11:55 am Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
That's awesome to know cause I just installed redline gear oil less than 3,000 miles ago. _________________ Brandon
Instagram @joannthevan |
Posted: Sat Jul 14, 2018 4:59 pm Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
Okay so maybe mine wasn't as clogged as I thought. I think I am now hitting metal in the back of my vent. I should have took pictures but I had grease all over my hands.
It's very hard to explain, but does it sound right if I stick a drill bit inside 1" and hit metal I'm fine - meaning at some point the 'vent' comes from the bottom of trans 1" inside. _________________ Brandon
Posted: Sat Jul 14, 2018 6:14 pm Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
Yes, that sounds right. |
ALstew Samba Member
Posted: Tue Jan 29, 2019 10:25 am Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
So I replaced my clutch last night and I powerwashed my trans the night before. I was looking for a breather hole because I didn't want to blast it with water, but I never noticed it caked under dirt.
The trans is back in so I guess it is a good idea to now drain the oil? I don't recall blasting that section very long with the pressure washer, but what is the likelihood I got water into the case? |
Posted: Tue Jan 29, 2019 10:39 am Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
ALstew wrote: |
What kind of oil did you use? I mean the right thing to do is change it. Really, I wouldn't take the chance. Oil is cheaper than a transmission _________________ Brandon
ALstew Samba Member
Posted: Tue Jan 29, 2019 2:51 pm Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
shagginwagon83 wrote: |
ALstew wrote: |
What kind of oil did you use? I mean the right thing to do is change it. Really, I wouldn't take the chance. Oil is cheaper than a transmission |
Yeah I think you're right, at least now I know where the breather is haha. I used swepco last oil change about a year ago. |
Posted: Tue Jan 29, 2019 2:55 pm Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
I mean it would be good to inspect that drain plug anyhow. You could maybe assume any water would float to the top and remove the top layer of the oil. I don't know but if I drove without changing it, I would always be thinking about the possibility of water in the trans and it about to blow. _________________ Brandon
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Tue Jan 29, 2019 8:11 pm Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
Does the auto transmission have a vent like this? _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
laststarfighter Samba Member
Posted: Thu Jan 07, 2021 8:00 pm Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
tonight is the first time I ran across the term "atmospheric bleed". Please let me know if this item is only on the VW bus type tranny or is it also on the Beetle tranny (particularly 1971 Super Beetle). Thank you. |
Posted: Thu Jan 07, 2021 9:39 pm Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
Virtually every transmission has an atmospheric bleed. You might find it called other things also, like atmospheric vent or breather. I'm sure your super beetle has one but I can't help regarding where it is located. |
Posted: Sun Jan 10, 2021 7:11 am Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
Thank you. Hopefully I will find it as I clean the tranny. |
Jacebc Samba Member
Joined: June 14, 2019 Posts: 8 Location: Bainbridge Island
Posted: Sun Jan 31, 2021 7:45 pm Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
Thanks for the tip! I have a slight leak around the gear selector shaft. Spent spent quite a bit of time looking for the breather vent, to no avail. Does anyone have any photos of it with the transaxle mounted to the vehicle? Thanks so much! |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2332 Location: Southeast Kentucky
Posted: Sun Jan 31, 2021 8:05 pm Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
With a flexible hose hanging down, the modified vent hole on this DK tranny has been in service since 2012... no mess down below.
_________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
jimf909 Samba Member
Posted: Mon Feb 01, 2021 8:13 am Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
I have a new to me '03 Toyota Tundra with 230K miles with a leaky axle seal. A short search for leaky axle seals reveals a similar fix for a Tundra rear differential breather. Sometimes good seals are forced to blow due to a clogged breather. _________________ - Jim
Abscate wrote: |
Black'n'White Samba Member
Joined: May 18, 2016 Posts: 81 Location: Butte County, CA
Posted: Tue May 11, 2021 2:57 pm Post subject: |
MsTaboo wrote: |
Here is a shot of the hole in front of Syncro tranny case.
Does anyone know the the thread that was used for that threaded hole? I'd like to pick up a banjo fitting and install a breather line... _________________ '87 Syncro/Westy Homebrew
Whatever it takes... |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1002 Location: Oakland CA
Posted: Tue May 11, 2021 7:21 pm Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
I do know the part number is N-021-075-5. The banjo fitting is N-902-788-01.
check Weddle Industries _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
4Gears4Tires Samba Member
Posted: Tue May 11, 2021 7:23 pm Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
A 2000s Honda Accord/Civic brake line and banjo fit perfectly if you have a neighbor with one just laying around after some maintenance. Good length too.
Yes I am totally running this right now. It even zip ties together to make a loop to stop water intrusion.
Posted: Wed May 12, 2021 7:05 am Post subject: Re: A Little Known Cause of Recurring Tranny Oil Leaks |
davideric9 wrote: |
check Weddle Industries |
Thank you for the info!
Both items were in stock at Weddle, might even get here by the weekend. But oh my gosh, those shipping prices!
BTW, the breather hole is just barely visible looking up above the driver's side transaxle nose/decoupler, looking to the rear of the van.
Gonna have to find a kid with little hands... [/img] _________________ '87 Syncro/Westy Homebrew
