ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
joetiger Samba Member
Joined: January 27, 2005 Posts: 5068 Location: denver
Posted: Tue Feb 05, 2019 10:33 am Post subject: Re: Subarugears rear drive conversion kit for Vanagon |
It's good to hear from you Ben! _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16474 Location: Brookeville, MD
Franklinstower Samba Member
Posted: Tue Feb 05, 2019 6:22 pm Post subject: Re: Subarugears rear drive conversion kit for Vanagon |
Thanks for the video Ben! Let us know when you get the rsfab kit video up, I have one to install and so does a friend. He is still waiting on his kit from the black Friday sale
I also suggest test fitting the shift rod to the subanose as soon as you get the kit. Mine doesn't fit... _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Wed Feb 06, 2019 6:07 am Post subject: Re: Subarugears rear drive conversion kit for Vanagon |
As we all move forward on the backs of those that went before us, thanks for showing us the way. Good to hear from you. Always very educational to watch your videos.
Thanks again. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Binolardo Samba Member
Joined: August 14, 2017 Posts: 5 Location: Sherbrooke, Qc
Posted: Wed Feb 06, 2019 4:22 pm Post subject: Re: Subarugears rear drive conversion kit for Vanagon |
Ben:
I would like to know if you had any issue with the clutch pedal travel?
Even if I had the BRZ slave cylinder with a 21mm bore, I had to put a stopper on the clutch pedal to reduce the travel to almost half.
Without the stopper, the clutch fingers were touching the clutch disk preventing gear engagement.
Math. |
Posted: Wed Feb 06, 2019 4:54 pm Post subject: Re: Subarugears rear drive conversion kit for Vanagon |
Binolardo wrote: |
Ben:
Math. |
Hi Math, I have use the stock transmission slave and it's perfect, friction point is about half way. Perfect in my book. I'm not sure that I get your problem?
I have seen somewhere people using the BRZ slave but I don't get why?
The slave need to be primed with oil of course. Master need to be solid or replace.
May you explain that 21mm bore to me??? This is simple hydraulic, unless the master is mess up and that happen often when it goes when it never when before.
Ben _________________ Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta |
Posted: Wed Feb 06, 2019 8:24 pm Post subject: Re: Subarugears rear drive conversion kit for Vanagon |
On my van, the pressure point is more at the third of the pedal displacement. Even if I have the bigger slave (which should increase pedal travel). So the last 2/3 are just moving the clutch bearing further until the pedal is close to the floor, then the clutch start to « bite » again. After removing the transmission I found rubbing marks between the clutch fingers ans the clutch disk.
By putting a stopper on the pedal, it prevent the clutch bearing from going too far and hitting the disk.
Is it ok for the pedal to go all the way to the floor, or is my master mess up?
The bigger slave cylinder (21 vs 19mm) should reduce the force on the pedal and increase its displacement for a given distance on the slave, but I already have the 21 mm and my pedal travel is still too short.
My issue seem similar to the small car clutch bearing going too far, except that the consequence are far less problematic. |
Posted: Wed Feb 06, 2019 9:16 pm Post subject: Re: Subarugears rear drive conversion kit for Vanagon |
Binolardo wrote: |
What trans are you using? Push clutch, or Pull clutch? Also are you using a stock flywheel and clutch/PP?
I have driven a conversion with the stock 19mm slave and I agreed it wasn't ideal. I am planning on using the 21mm slave also. You are the first I have heard of that has problems with the 21mm slave...Please let us know if you find a solution why you are getting too much travel with the larger slave.
thanks. _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
Posted: Mon Mar 25, 2019 2:42 pm Post subject: Re: Subarugears rear drive conversion kit for Vanagon |
ftp2leta wrote: |
I am also working on another video about the RS FAB shifter kit that gave me hell... but it's all fine now, I will post the link when I am done.
Ben
Ben,
Did you get that RS Fab Shifter Kit video up yet? _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
