vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Thu Jan 24, 2019 9:37 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
VOLKSWAGNUT wrote: |
So., the plan here is.. Vw cylinders and Ford Shoes??
Yes. The 1-3/4" shoes are near exact match, actually Speedway Motors repo Lincoln shoes, and the ends that fit cylinder are near identical. Travel near identical with VW being better suited. And we figure much lighter being less the V8 on top of front axle. We're going to try it and see. Since it's a bolt on, easy to change back. Pictures soon. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Thu Jan 24, 2019 10:51 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Ill ask the obvious... cause I'm curious.. .. why not just use the Ford cylinders ??
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Thu Jan 24, 2019 10:54 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Then.. why not just use the Ford cylinders ?? |
The beauty of being able to run 100% VW Brake lines and not swapping to 3/16 x 5/16-24 anywhere. 😀 |
Posted: Thu Jan 24, 2019 11:00 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
vaughn bros. wrote: |
Understood.. .. who would want want to mix SAE with Metric stuff.. .uuuuu...wait a minute... scratch that.
No matter... either will do the job...
Surprised ya just not going cable brakes for even more shock and awe. _________________ aka Ken {o\!/o}
72MUST Samba Member
Posted: Thu Jan 24, 2019 4:17 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Guess the shoes you're using are kind of fixed at one end ,bit like the VW ,not the self energizing type setup which some Lincolns(?) had ? Once they're well adjusted & lining curvature close to that of the drum , in conjunction with the VW cylinders ,should work well & with stock VW master, will feel similar in use & have similar front/rear balance to stock ,but looking much cooler , a great idea ! |
Posted: Sat Jan 26, 2019 11:02 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
72MUST wrote: |
You are correct sir.
Posted: Sat Jan 26, 2019 1:59 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Ok done.
Posted: Mon Jan 28, 2019 1:59 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Floor Scraps from a pan gasket office meeting.
Posted: Fri Feb 01, 2019 9:22 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Body got moved to the sandblasting tent. Bodywerk starts now.
And then came right back in.
Posted: Mon Feb 04, 2019 10:17 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Replacing door bottoms with nice donor doors.
Door donor car. Hated breaking up a project pile.
Posted: Wed Feb 06, 2019 3:34 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
The tooling for rear scoop.
Posted: Wed Feb 06, 2019 3:39 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Rear scoop plans. Actually a problem solving transition/cure.
finster Samba Member
Joined: May 26, 2012 Posts: 7935 Location: north o' the border
Posted: Thu Feb 07, 2019 10:47 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
like your doodle bugs - did you go to art school? |
Posted: Thu Feb 07, 2019 11:22 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
finster wrote: |
Thanks. No art school. My brother and I both draw a bit.
Cory Vaughn:
Andy Vaughn:
Posted: Thu Feb 07, 2019 3:50 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Scoop edges L & R and the dolly. Holes cut.
Posted: Sun Feb 10, 2019 12:56 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
How the scoop dolly is used with vise grips.
Starting to become a scoop.
Posted: Thu Feb 14, 2019 5:09 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Another hour to work on car today.
Posted: Sun Feb 17, 2019 7:02 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sun Feb 17, 2019 5:33 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
I always look when you post....Really nice work _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Tue Feb 19, 2019 1:15 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
andk5591 wrote: |
I always look when you post....Really nice work |
Thanks, and it goes without saying, your always welcome to come help.😀 |
