cliffrun2 Samba Member
Joined: September 27, 2009 Posts: 24 Location: Fredericksburg, VA
Posted: Mon Oct 15, 2018 6:57 pm Post subject: automatic stick shift output seal replacement |
I have a 71 Super w/auto-stick. It leaked gear oil on both sides at the output (where the axles connects to the transmission). I received a few quotes but they were pretty steep so I am considering a DIY for the experience and save $. I haven't had any success finding instructions on the internet or in the maintenance manuals.
Does anyone have information or reference that could guide me on how to do it and the required tools.
Thanks. |
sb001 Samba Member
Posted: Mon Oct 15, 2018 7:31 pm Post subject: Re: automatic stick shift output seal replacement |
Hello cliffrun!
You might contact justin1958 here on the samba, he posted here not too long ago about having to do the same job:
I linked him in that thead to another thread on the topic over at www.vwar.org (that's the VW autostick site) that discussed part numbers and a bit of info on doing the job. Here is that thread in case it may help:
http://vwar.org/forum/index.php?topic=1731.msg12943#msg12943
Good luck _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Wed Oct 17, 2018 8:36 am Post subject: Re: automatic stick shift output seal replacement |
Thanks. I will reach out to Justin1958 to see if we can have a conversation on the subject and what was his resolution. |
sb001 Samba Member
Posted: Wed Oct 17, 2018 11:41 am Post subject: Re: automatic stick shift output seal replacement |
cliffrun2 wrote: |
Keep us posted!
The day will probably come when I have to do that job myself, so I am depending on you guys to do it first and iron out all the kinks _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Fri Oct 26, 2018 5:29 pm Post subject: Re: automatic stick shift output seal replacement |
I am more than willing to share information/knowledge. I was out of town all week, so as time permits I will get to the task at hand. Justin has given me homework , so when I begin we will be in close contact. |
Posted: Sat Jan 26, 2019 9:06 pm Post subject: Re: automatic stick shift output seal replacement |
Hi. Just to follow-up or rather update. Justin was a great helping I have removed the end caps and seals. I am only working in my spare time so its taking longer than expected. Also, I want to make sure I clean up the mess under there. Removing the retention clip that keeps the drive flange was the biggest challenge but I was victorious . The parts are cleaned and ready to be installed, however, the plastic piece between the drive flange and the transmission case is damaged and I'd like to replace if I can find a good ones. I placed a Want to Buy post in the classified section.
Here are some pictures of the process
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9960 Location: Huntington Beach, CA
Posted: Sun Jan 27, 2019 12:42 am Post subject: Re: automatic stick shift output seal replacement |
I think there is a member on here that can 3D print parts. Might try finding that person. Wish my memory was better. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Wed Feb 06, 2019 5:58 pm Post subject: Re: automatic stick shift output seal replacement |
We had a few warm days on the east coast so I scurried in the garage to finish the project. I won't get into the details but will say it was not easy, but very do-able. I thought I was done with all the mess after I completed the teardown, but repacking the CV's was really messy. I got grease everywhere on everything , but in the end, I got it done with the expected outcome, no leaks .
Thanks to everyone for advice along the way.
I chose not to delay the process trying to find those deterioated plastic locking plates because they don't impact the functionality of the other parts. |
vamram Samba Member
Posted: Wed Feb 06, 2019 7:09 pm Post subject: Re: automatic stick shift output seal replacement |
Nice work. Where did you find the replacement plastic flange? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Thu Feb 07, 2019 5:57 am Post subject: Re: automatic stick shift output seal replacement |
I didn’t find any, what you see is the original, just cleaned up. I spoke to some people who have pressed metal rather than the plastic. |
sb001 Samba Member
Posted: Thu Feb 07, 2019 10:53 am Post subject: Re: automatic stick shift output seal replacement |
Nice job, and thanks for the photos too pictures are worth a zillion words to me for whenever I have to do this job. In fact mine are probably leaking as well right now but ehhh it can wait until spring/ summer _________________ I'm the humblest guy on this board.
1600 SP engine
sb001 Samba Member
Posted: Thu Feb 07, 2019 10:56 am Post subject: Re: automatic stick shift output seal replacement |
also I'm not at all familiar with the workings of the CV axle joint there- what is the purpose of that plastic piece? Does it just act as a seal? _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Thu Feb 07, 2019 8:44 pm Post subject: Re: automatic stick shift output seal replacement |
I was told they are called locking plates, but there isn't anything to "lock". As far as I can tell it isolates (protects) the seal from dirt and grime. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Sat Feb 09, 2019 2:31 am Post subject: Re: automatic stick shift output seal replacement |
They are to prevent the screw-in bearing support from unscrewing. _________________
