aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Mon Feb 11, 2019 8:10 am Post subject: 1979 Cali fuel vapor canister hoses |
Guys,
For the life of me I can’t figure out where the lower canister hose connects to the engine. There should be an air pressure port somewhere on the right side to push the vapors out of the can. The top hoses I can figure out. It’s just the bottom, clear, 1/2 inch hose I need to figure out. TIA _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
honestcharlie56 Samba Member
Joined: September 24, 2017 Posts: 87 Location: Houston, Tx
Posted: Mon Feb 11, 2019 8:36 am Post subject: Re: 1979 Cali fuel vapor canister hoses |
EDIT: I DID IT!
Let me see if I can figure out pictures. I just walked outside and took one of what I think you are talking about. _________________ 1982 Vanagon Westy
1974 Transporter
1971 Tin Top Westy |
Posted: Mon Feb 11, 2019 9:03 am Post subject: Re: 1979 Cali fuel vapor canister hoses |
I don’t think our tin has that nipple _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Mon Feb 11, 2019 9:05 am Post subject: Re: 1979 Cali fuel vapor canister hoses |
Good God. Looking at my pics I do see the nipple. If it was a snake it would have bit me. Thanks for the help. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent Samba Member
Posted: Mon Feb 11, 2019 11:10 am Post subject: Re: 1979 Cali fuel vapor canister hoses |
for the record - the 76 - 77 late bays had the hose on the shroud on the left side. The 78 - 79 had it on the tin on the the 1-2 cylinder side.
On 76-77 the canister was mounted to the firewall. On 78-79 the canister was mounted near the battery.
If you are using a 76-77 style canister one has to remove the end and the piece of gauze designed as a flame trap because it will have turned to gel and will block the outlet. You can use a piece of chemically resistant scotch pad to replace it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Feb 11, 2019 11:19 am Post subject: Re: 1979 Cali fuel vapor canister hoses |
It’s correct for 1979 _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
