Making my 1961 Riviera syncro
Page: 1, 2, 3 ... 10, 11, 12  Next
KrisBalfe
KrisBalfe is offline
PostPosted: Tue Feb 05, 2019 8:26 pm    Post subject: Making my 1961 Riviera syncro Reply with quote
Purchased this double door riviera out of California earlier this year and was planning on replacing belly pans, cargo floors and some other common rusted areas. Unfortunately the bus was much more of a basket case than I’d been planning on.
So I started coming up with a game plan and purchased from a friend a shorty ‘57 with much of the metal that would be required to piece the bus back together, unfortunately I’d still be required to patch in the missing frame sections from the shorty and was looking at going backwards as far as the torsion housing and transmission were concerned. So with that and some other problems in mind I scrapped hope of returning this bus to stockish. At this point it would have been more replacement metal than original which wasn’t what I was looking for in a split this time around.
I left all those plans behind and decided to use the chassis of a late bay westy I have kicking around. Reasoning could have been misguided but I believed there were benefits to doing so... then I thought to myself, I am already doing something fairly stupid here may as well go for it and make this thing a syncro.
I have purchased the shell of an ‘87 syncro and will be starting down this path if there is any interest in this project I’ll put up the progress here.
Thanks, Kris
sub-hatchtim
sub-hatchtim is offline
PostPosted: Tue Feb 05, 2019 9:06 pm    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
Why not just build out the syncro? I'm a split and vanagon owner, the vanagon is a far superior vehicle driving and comfortable wise
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
KrisBalfe
PostPosted: Tue Feb 05, 2019 9:45 pm    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
Fair question, I thought for some time on doing exactly that, in the end I didn’t see two better vehicles to attempt this with than a parted out syncro and rusted out camper... also I’ve always wanted an awd split camper.
nineteensixtyfiveVG
nineteensixtyfiveVG is offline
PostPosted: Tue Feb 05, 2019 11:31 pm    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
consider me interested
sub-hatchtim
PostPosted: Tue Feb 05, 2019 11:36 pm    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
Yes an 4wd split would be rad but I have a feeling for all your efforts its not going to handle as well as a vanagon
76 911S
Busstom
Busstom is offline
PostPosted: Tue Feb 05, 2019 11:50 pm    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
One reason I'd pursue the split route is to avoid the smog-check nazis...and Utah goes back to '67...ouch.
I can't tell for certain, but it also looks like you may require the safety inspection based on the stipulation for vehicles that expired in 2017 (if that includes 2017 and earlier...I'm not clear on their 2018 legislation eliminating passenger vehicle inspections).
Blue Baron
VW Aficionado
Blue Baron is offline
PostPosted: Wed Feb 06, 2019 12:43 am    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
Isn't the Vanagon wheelbase longer and the track a lot wider? You would either have to lengthen and widen the body, or shorten and narrow the chassis.
At any rate, let's see what you build.
Heinz Nordhoff
kermie
kermie is offline
PostPosted: Wed Feb 06, 2019 2:12 am    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
Wheelbase of a Vanagon is 2.4" longer. The track is a little over 8" wider. So some adjustment is needed Laughing
1962 Campmobile
1964 Swedish Police sold
1965 Double Door Panel sold
1966 Sundail Camper sold
KrisBalfe
PostPosted: Wed Feb 06, 2019 6:24 am    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
I hear you all, quality points.
The ace up my sleeve is that I’ve already done this to my bay window. The wider track is my biggest concern. I don’t want to hack the wheel wells. It looks like I’ll need to remove 3” from the middle of the vanagon chassis to avoid doing so. The brake booster and pedal cluster will also have to be in the cab and I may have to put a bay window steering column in. Which would aesthetically speaking be the worst part for me, I’d like to keep the split steering wheel.
edgood1
edgood1 is offline
PostPosted: Wed Feb 06, 2019 6:32 am    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
I'm very interested. I've thought about how I would do this conversion in the past.
If I were to do it , I'd build out a custom front subframe or modify the syncro subframe up front. This would lift the bus quite a bit since there's not a lot of room under there for the front diff. I'd relocate a lot of stuff and run most of the syncro suspension components, modified or custom to fit the custom subframe.
This would likely require a complete solution for the rear suspension as well.
A few things work towards your advantage. The gas tank is in the right place and theres a lot of room in the engine bay for an adequate power train. The frame horns would have to come out for sure.
Its a cool concept. Keep us posted. I never went forward with it because vanagons and syncros are my favorite buses and I'd rather fix them up before parting them out.
1987 Syncro Westfalia powered by Subaru
'65 Westfalia
Bulli Klinik
Bulli Klinik is offline
PostPosted: Wed Feb 06, 2019 9:22 am    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
Widen the Split to fit the Vanagoon chassis. Just like they did with the Race Taxi Bus.
Sound like a cool project.
I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs
vwuberalles
vwuberalles is offline
PostPosted: Mon Feb 11, 2019 10:45 am    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
Do it!
cdennisg
cdennisg is offline
PostPosted: Tue Feb 12, 2019 10:53 pm    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
I am so in on this build. DO IT!
nothing
mr white
mr white is offline
PostPosted: Tue Feb 12, 2019 11:42 pm    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
Some bits from a 85-87 Audi 4000cs Quattro may help you on your quest. Good luck!
KrisBalfe
PostPosted: Wed Feb 13, 2019 6:19 pm    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
I haven't been able to get a real start on this yet.
Right when the donor syncro showed up, so did the snow.
Which is not necessarily a bad thing. It has been great for
Driving my other bus in.
Here is the meager start of the project. Should move a lot
Faster once work and snowfall slow down.
That's as far as I've gotten besides stripping the syncro down.
j.pickens
j.pickens is offline
PostPosted: Wed Feb 13, 2019 9:54 pm    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
With the chassis that rusted, I like the suggestion to widen the whole bus. You could make it with three front windshields. Use a deluxe skylight sideways as the center window.
BeaterBarndoor wrote:
Red Fau Veh wrote:
KrisBalfe
PostPosted: Wed Feb 13, 2019 10:16 pm    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
I like your creativity, my goal though is to hopefully end up with a bus that looks like a split with a mild lift. The vanagon track isn’t excessively wider than the split body, maybe 1.5” on each side. I left the vanagon chassis stock on my bay conversion and didn’t even mess with the rear wheel wells, front I played with the idea of adding the vanagon dogleg flare. One side is done, the other isn’t until I decide which way to go.
With the split though I don’t want the wheels outside of the body so I will likely remove 3” from the T3 chassis.
Spike0180
Spike0180 is offline
PostPosted: Thu Feb 14, 2019 9:06 am    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
You may be able to make up the difference in width with wheel offset. Just a thought, it'd make getting CVs much simpler, and not mess with any of your geometry.
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic"
KrisBalfe
PostPosted: Thu Feb 14, 2019 10:27 am    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
That is worth some looking into.
I really want to keep stock wheels on this though. Hopefully the weather will cooperate this week and I can dig into it a little more
notchboy
notchboy is offline
PostPosted: Fri Mar 22, 2019 10:12 am    Post subject: Re: Making my 1961 Riviera syncro Reply with quote
Shocked
Another one? Has the welds even cooled off on the bay? Laughing This is going to be very cool indeed Cool Gona piss off some of the stock Nazis for sure Shame on you Dancing :fist:
I love it Kris - keep pluggin along. A lifted, syncro early split will be a nice treat to see. Especially with a nice retro wood camping interior. Wink
Popcorn
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Page 1 of 12
