Artur Samba Member
Posted: Wed Feb 20, 2019 10:44 am Post subject: Re: -52 Ravin |
Thank you blink.
It’s not a fast build but I’m trying to get forward bit by bit every week.
Today after work I had some time over so I did these reinforcement things.
Don’t know the correct name for them.
blink Samba Member
Joined: September 07, 2011 Posts: 90 Location: Australia
Posted: Fri Feb 22, 2019 5:16 am Post subject: Re: -52 Ravin |
Doesn’t have to be fast just has to have photos lol
But really all the little bits all add up you will get there
They look really nice, are they for the parts near the pedals? |
Artur Samba Member
Posted: Fri Feb 22, 2019 9:02 am Post subject: Re: -52 Ravin |
blink wrote: |
Yes exactly. KlassicFab call them supporting plate. So I guess that’s the name. |
Artur Samba Member
Posted: Sun Mar 31, 2019 1:37 am Post subject: Re: -52 Ravin |
Starten to fresh’en up the mid plate between the frame.
This is from a newer center steering.
I’m planing on having the center steering so this should be a 55+ model, right?
How have you guys done it on your Bds driving steering in center?
Do you just cut the Bd plate so the steering clears, or should this be a good way to go?
Artur Samba Member
Posted: Thu Jul 09, 2020 3:26 am Post subject: Re: -52 Ravin |
I have been welding some, learning more and more.
I’m not that good of a story teller.
But I thought maybe I should update this thread.
The frame/chassi came together.
Have seen that a few ppl have broke there nose-cone.
I shopped it Like you where going to.
But I also took a extra bit out in front. Got much more clearance now.
Will see.
Made a centre steering beam.
Trying if I can rescue some of metal.
Went ok. But yeah.....
Fixed a -69 beetle gearbox.
Flipped spindles.
Got a bit carried away with how the metal press was on different bits.
From 50-55 especially this piece.
Really don’t have much to do with the build.
But..
I have at this point decided that I want as much metal from the Wolfsburg factory as possible. Not the best idea maybe.
But I’m learning and trying.
I have a pretty bad bus so if I make it I’ll make it.
Here are the dog legs I paired to make one.
Just realized I did not have a picture of when it was done.
The. Some friends wanted to come and have a look.
Now here is a pretty big jump in work.
Don’t know why I didn’t take more pictures.
The bus looks more ready then what it is there.
The og firewall was in really bad condition. Maybe worse then the air intake.
So I made a new one.
Did not have the cabin metal piece. Between the B-posts.
So in d end I ended up doing one.
Got a bit ballzy ended up trying to make more metal parts.
Some good parts.
Trying out what colors I like. Flat gold or gold and black.
Me and the daughter doing some Easter fun.
Eh she was painting and I really was in the mood to fold some paper.
This was a really fun piece to try out.
And this is the last picture. Taken 2days ago.
The strange, to some, weel arc in the front is a raise arc. I got 15mm extra room for the tire that way. And that’s dubbel as much as I had before.
Now the supports for the front sofa will go in.
I’m going to smoth out some parts and check for errors. Then paint it again. |
Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 878 Location: Cornwall, UK
Posted: Thu Jul 09, 2020 6:30 am Post subject: Re: -52 Ravin |
Awesome work dude. Looks amazing! _________________ 1951 Samba 20-017894
1952 Samba 20-028952 |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2172 Location: Graz, Austria, Europe
Two Glove Boxes Samba Member
Posted: Fri Jul 10, 2020 7:57 am Post subject: Re: -52 Ravin |
Damn that looks dope! Keep with the updating. |
Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Tue Jul 14, 2020 7:23 am Post subject: Re: -52 Ravin |
Good work Artur! _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
Artur Samba Member
Posted: Thu Jul 16, 2020 11:47 am Post subject: Re: -52 Ravin |
Thanks guys!
Hi Scotty, hope I’ll se you next year.
Where working on the transmission mounting at nose-cone and realized that you have to shorten the right sides bolt head.
It sort of work with a normal bolt-head but then you don’t get any clearance.
It’s a good thing too check for if your bolting in a beetle gearbox.
Maybe obvious, and well known. But yeah.
Artur Samba Member
Posted: Tue Jul 28, 2020 1:47 pm Post subject: Re: -52 Ravin |
Soooo checked for errors....
And painted it again.
Have been looking for a front sofa.
But haven’t found one.
So I made one.
Built a frame, then took some springs from a T3 DC sofa.
Will have this until I find a og one.
The seat is done as well. But did not have a good picture of it.
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Tue Jul 28, 2020 4:52 pm Post subject: Re: -52 Ravin |
nice work. Would it not have been easier to make a frame and put foam on it instead? give you some height back? _________________ regards
Uli
Artur Samba Member
Posted: Tue Jul 28, 2020 11:37 pm Post subject: Re: -52 Ravin |
There will be foam and that brown hairy stuff Mandrake.
Just a really boring photo with that on top. |
Artur Samba Member
Posted: Sat Aug 01, 2020 3:29 am Post subject: Re: -52 Ravin |
The (hopefully) temporary seat.
Artur Samba Member
Posted: Sat Aug 29, 2020 11:55 am Post subject: Re: -52 Ravin |
Had a friend over. We where trying some door options.
The OG doors I have is in very bad condition.
So to fix the MoT I will use these doors for that.
Talking about rim color options. Real fun talk.
Thanks for the help pushing the bus out Gb.
And thanks Mange for the help pushing it back in.
Scotty Samba Member
Posted: Tue Sep 01, 2020 8:53 am Post subject: Re: -52 Ravin |
Ahh so you decided to have safaris then! _________________
EverettB wrote: |
busben Samba Member
Joined: March 07, 2008 Posts: 527 Location: Somerset, UK
Posted: Tue Sep 01, 2020 10:17 am Post subject: Re: -52 Ravin |
Killing it dude I’m really glad this bus ended up with you and not some foolish kid from England
My thought ...... I prefer the solid gold wheels |
Artur Samba Member
Posted: Thu Sep 03, 2020 2:18 pm Post subject: Re: -52 Ravin |
Yeah went for the safari windows.
Really glad I did. I really like the look of them.
Let’s see how I feel about them after the first ride in bad weather.
Thanks Ben, appreciate it!
Haha if it had gone too “some kid” in England the bus would
have had a more killer look.
And I way better project tread.
Congrats on the Radiohallen build. MAD! |
Artur Samba Member
Posted: Mon Nov 09, 2020 12:56 pm Post subject: Re: -52 Ravin |
Passed the MOT. I can now drive it. Almost.
Just waiting on the plates.
bathtub57 Samba Member
Joined: August 31, 2004 Posts: 155 Location: Ascot, UK
Posted: Mon Nov 09, 2020 1:02 pm Post subject: Re: -52 Ravin |
Awesome job, hope the plates arrive soon you must be itching to get out on the road. _________________ Aircooled since 1988 |
