fleetwood41 Samba Member
jocoman Samba Member
Joined: August 11, 2016 Posts: 427 Location: Ottawa, Canada
Posted: Fri Feb 22, 2019 1:56 pm Post subject: Re: why is my fuel pump still buzzing? |
I have new pump and tank and still the buzz. I just did the resistor fixed as noted and forgot about it. _________________ '86 Westfalia 2.0L Zetec
'97 Volvo 850 AWD Turbo
" The fun never stops" |
ekitel Samba Member
Posted: Fri Feb 22, 2019 9:15 pm Post subject: Re: why is my fuel pump still buzzing? |
wesitarz wrote: |
With the gas cap off does the pump sound better? |
Yeah I thought of that and tried it last night but no difference... _________________ 1986 Vanagon GL 2.1 |
ekitel Samba Member
Posted: Fri Feb 22, 2019 9:28 pm Post subject: Re: why is my fuel pump still buzzing? |
I figure that a resistor slows the pump enough so that it doesn't over-heat enough to cavitate which would be good if it doesn't lower the fuel pressure too much to affect the injectors and that would keep it from getting burned out and failing on the road.
I just wonder why the pump never made a sound for many months after I bought the van and then all of a sudden started making a little buzz and then more and more. It doesn't start buzzing right away, but as the engine warms up it gets louder and louder. _________________ 1986 Vanagon GL 2.1 |
E1 Samba Member
Joined: January 21, 2013 Posts: 6528 Location: Westfalia, Earth
Posted: Fri Feb 22, 2019 10:00 pm Post subject: Re: why is my fuel pump still buzzing? |
I'd still try a tank of fuel drier.
It seems water in gas is more common in the winter, in humid climates, or after long wet spells (knowing you'd said it hasn't rained lately).
It's possible, too that you got a "wet" fill of gas and some is stuck in the pump. That happens.
Fuel drier is cheap and easy, I do it every few thousand miles as a preventative.
I'll add... sometimes it's easy to not notice the buzz until you do, and once you do it seems louder in focusing on it.
Regardless, it shouldn't do it, as you know. It'd be interesting to clean the front end of the pump with a Q-Tip, and also (temporarily!) fit some clear line into the pump to look for air bubbles. Motorcycle shops should have some clear fuel line (or racing kart shops, which is what we raced with and air leaks were really obvious). _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1487 Location: Victoria,B.C.Canada
Posted: Sun Feb 24, 2019 8:18 am Post subject: Re: why is my fuel pump still buzzing? |
Did you replace the original hard fuel line? When I did mine I used FI rated hose if that makes any difference. Pre-pump I use 1/2 inch marine fuel hose. I have been running a pre-filter with hose size adapter because I have an old tank and have noticed some fine sediment in the filter. Did replace my old pump and noticed the new one buzzing, but found a loose connection to the pre-filter so it was sucking air. My fuel pump is grounded to the engine ground point in the engine bay which is original I think. Recently I noticed a performance problem and checked the fuel pressure which was not holding it's normal 40 psi when cycling the fuel pump.(Subaru test mode). A quick pinch on the return line spiked the fuel pressure so the fuel pump was OK. I replaced the fuel pressure regulator and performance is much better, but haven't re-checked the pressure yet. Maybe running a fuel system cleaner through it would be worth a try? I've run some Seafoam and the GumOut product (Techron?) through it. I've mostly used Chevron with Techron and added a little fuel injector cleaner with each fillup, although lately I've been using Shell Nitro 92 with no ethanol. |
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
ekitel Samba Member
Posted: Sun Feb 24, 2019 7:58 pm Post subject: Re: why is my fuel pump still buzzing? |
ftp2leta wrote: |
It's made in China, that is why. I have to buy 4 before I get one that doesn't buzz. |
I already got another one off Amazon, I could return the one I just installed and on and on until I find a winner... _________________ 1986 Vanagon GL 2.1 |
Posted: Sun Feb 24, 2019 11:35 pm Post subject: Re: why is my fuel pump still buzzing? |
[quote="ftp2leta"]It's made in China, that is why. I have to buy 4 before I get one that doesn't buzz. BOSCH is not what it use to be.
Split one in 2, you will see China inside
Ha! Maybe that's why you see Bosch pumps at $250 CAN from one supplier and $100 from another. I got the cheaper one but keeping the old one as a spare. |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Mon Feb 25, 2019 6:48 am Post subject: Re: why is my fuel pump still buzzing? |
I too had the buzzing fuel pump on my 1991 2.1 Vanagon..bugged me.
I replaced the fuel pump (which was working fine but had about 100K miles on it) with a new Bosch from one of our favorite online vendors. New fuel filter also.
The buzz was still there.
As an experiment I started using ethanol free fuel about a year ago. Available at the local QT here in Georgia.
After about 200/300 miles (two tankfuls) the buzz was almost gone.
Just yesterday I filled up again with ethanol free and noted that the buzz was completely gone..zero..no buzz.
My guess is our older fuel pumps were designed around ethanol free fuel at a certain density..with the changes in fuel the pumps just buzz like crazy.
I also get a few more MPG with ethanol free fuel. |
ekitel Samba Member
Posted: Mon Feb 25, 2019 4:51 pm Post subject: Re: why is my fuel pump still buzzing? |
interesting to note that buslab does not sell the Bosch pump, they say:
"We moved to the Pierberg brand a few years back when Bosch started producing new pumps that were very noisy." _________________ 1986 Vanagon GL 2.1 |
