Vnyd Dog Samba Member
Posted: Mon Feb 25, 2019 10:10 pm Post subject: Re: CLK wheels |
shagginwagon83 wrote: |
Thanks man! This is a turning point and its time to kick ass
I bought these 4 black ones for $200 and I also bought 2x silver ones for $75.
Vnyd Dog - those tires/wheel setup looks awesome. That's a real clean set. I don't really have the money to buy a set. What's up with those green tire caps :O |
Hey thanks. I’m happy. So it turns out my Costco exclusively Nitrogen fills. The green caps are to indicate N in the tire. Lemme know if you part with an extra silver wheel. I need a spare! _________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
https://www.thesamba.com/vw/forum/viewtopic.php?t=713391&highlight=life |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3794 Location: VA/TN
Posted: Tue Feb 26, 2019 6:10 am Post subject: Re: CLK wheels |
Vnyd Dog wrote: |
Hey thanks. I’m happy. So it turns out my Costco exclusively Nitrogen fills. The green caps are to indicate N in the tire. Lemme know if you part with an extra silver wheel. I need a spare! |
Thought so on the Nitrogen. My research shows since air is 78% nitrogen it won't hurt to use an air compressor on them.
Have you tried car-part.com to find a spare? To be honest I'll probably just keep one on hand in case I bend/crack one. _________________ Brandon
Instagram @joannthevan |
toomanyveedubs Samba Member
Joined: November 26, 2007 Posts: 596 Location: Great White North
Posted: Tue Feb 26, 2019 8:35 am Post subject: Re: CLK wheels |
225/75R16?? |
Posted: Tue Feb 26, 2019 8:58 am Post subject: Re: CLK wheels |
Looks like 215/65. 2wd with 1.5" lift?? _________________ Brandon
Posted: Tue Feb 26, 2019 3:55 pm Post subject: Re: CLK wheels |
They are the 215/65s. Currently on new Schwenk springs and older Bilstein HDs. I ordered the smallest spacers from Chris in the event I need em, but won't know till I get them on. I guess some 215s fit without spacers depending on level etc. _________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2795 Location: North Carolina
Posted: Tue Feb 26, 2019 6:45 pm Post subject: Re: CLK wheels |
Vnyd Dog wrote: |
They are the 215/65s. Currently on new Schwenk springs and older Bilstein HDs. I ordered the smallest spacers from Chris in the event I need em, but won't know till I get them on. I guess some 215s fit without spacers depending on level etc. |
Nokian entryes “fit” my van with no spacers in that size, but it was so incredibly close at the front UCA that I did a wee bit of grinding to gain clearance. Working great for almost 3 years now. The grinding was suggested by crazyvwvanman somewhere earlier in this thread.
This is with original, need to be replaced springs and "OEM" Spectrum (which I believe is just another word for Monroe) replacement shocks. . _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
ELO78 Samba Member
Joined: September 18, 2015 Posts: 167 Location: Oak Park, IL
Posted: Wed Mar 20, 2019 6:42 pm Post subject: Re: CLK wheels |
Alright finally
Got my tires mounted after my trip and got the spacers and wheels on. Cruised around the vineyard a bit to break in the BFGs. Running the 215/65s. Need to take up the highway to get a feel for how they handle. I’ll be reprimanded for not searching but can anyone recommend tire pressures for the BFGs for a typical unloaded Westy? The load rating on them is pretty high, 103 I think!!
The Story:
beach_creature Samba Member
Posted: Wed Mar 20, 2019 9:18 pm Post subject: Re: CLK wheels |
Nice!
I have 215/70r16 KO2s. I run 40 psi in the front and 50 psi in the rear. My tires seem to have even wear. Not so plush on the bumps. I air down for extended dirt road travel. _________________ 84 Westy
1.9TD AAZ
5spd manual with Locking Peloquin TBD |
Posted: Thu Mar 21, 2019 10:36 am Post subject: Re: CLK wheels |
beach_creature wrote: |
Nice!
I have 215/70r16 KO2s. I run 40 psi in the front and 50 psi in the rear. My tires seem to have even wear. Not so plush on the bumps. I air down for extended dirt road travel. |
Ah thanks. And my search did end up coming through...
crazyvwvanman wrote: |
The BFG LT215/65R16 has way more max carrying capacity than is required by the weight of our vans so it doesn't need to be inflated to its max.
The needed pressure versus weight carrying capacity of a given tire can be looked up.
If you locate the appropriate inflation table for the tire in question you can match the max rated weight of each axle/wheel to the pressure required to safely support that weight for long drives.
For the BFG Load D 103 LT215/65R16 the inflation table I have lists about
42 front
46 rear
to carry our vans when fully loaded to the allowable weight.
Some people overload their vans and would need more pressure.
Most people would be able to use less.
Mark
llilibel03 wrote: |
I have more tire questions
Say you have BFG KO2s (I'm thinking 215/65r16) and they're rated 65psi. The door placard on your van says 39psi front, 48 psi rear. How much would you inflate them? If you're inflating them less than 65 psi, say you do 40-50, how much load carrying are you losing? ..... |
The Story:
surfer6900 Samba Member
Posted: Sun May 05, 2019 1:25 am Post subject: Re: CLK wheels |
I've acquired 4x CLK 16 ET37 & 2 x CLK 16 ET33.
Should I just bolt on all the same ET or is there an advantage of mixing different ET for front & back ? _________________ 1990 Westy Atlantic Hightop, 1.9 AAZ conversion.
At the beginning of a long, long journey... |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sun May 05, 2019 2:50 am Post subject: Re: CLK wheels |
I suppose some could perceive an advantage.
With all 37et we are limited to approximately 205 width tires in the front if wanting to run without spacers.
With 37et a 225 width tire will definitely rub on the inside of the tire in the front w/out a spacer, and depending on the size of the spacer we can be pushed into needing longer lug bolts and longer studs pressed into the rear hubs.
So for someone who wants a little wider tire without paying any extra I guess there's that. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Posted: Sun May 05, 2019 9:46 am Post subject: Re: CLK wheels |
I have 215/70 on my clk et37. No rubbing. No spacers. 84 year. _________________ 84 Westy
1.9TD AAZ
vtmtber Samba Member
Joined: June 22, 2016 Posts: 20 Location: Charlottesville, VA
Posted: Tue Jul 30, 2019 3:46 pm Post subject: Re: CLK wheels |
I bought two more locally for $80. Perfect because I picked up like two silvers a year ago for $75.
So far a silver set for $155 and a black set for $200. I don't know which set I'll end up using right now. I'll make that decision after I tint the windows. _________________ Brandon
Posted: Tue Aug 06, 2019 8:40 am Post subject: Re: CLK wheels |
I'm on the lookout for a single wheel as my spare should anyone find anything. Keep this thread going! _________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
vik Samba Member
Joined: January 13, 2005 Posts: 204 Location: back in Czech
Posted: Mon Aug 26, 2019 10:38 pm Post subject: Re: CLK wheels |
Got mine on the car. It looks much better than the 15¨ rims with oversize tires previous owner put on the car.
Not sure why, but on the picture the color looks different (it is graphite gray) but still I'm not sure if I should stay with silver
Tires are Nokian Rotiiva A/T 215/70 R16 and finally I can fully open the rear door as the car had something like 235/75 R15 from previous owner
_________________ T3 Syncro camper in progress |
Posted: Tue Aug 27, 2019 5:30 am Post subject: Re: CLK wheels |
Those look awesome, vik- I would 100% leave the rims graphite gray, I really like it. If you're talking about the lugs being silver, I'd make them match.
Not sure about shipping to the emerald isle, but T3 makes some really nice caps for the hubs. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
vik Samba Member
Posted: Tue Aug 27, 2019 1:57 pm Post subject: Re: CLK wheels |
mikemtnbike wrote: |
Not sure about shipping to the emerald isle, but T3 makes some really nice caps for the hubs. |
Thank you Mike,
I know about them, but they were out of stock last time I was looking. Have to solve the engine rebuild now, than ¨bling¨. _________________ T3 Syncro camper in progress |
kiltedhiker Samba Member
Posted: Mon Sep 09, 2019 12:53 pm Post subject: Re: CLK wheels |
I am looking for a set of CLK's if you hear or know of any for sale. Thanks! |
