gitchesum Samba Member
Joined: November 10, 2003 Posts: 513 Location: North Cali
Posted: Mon Feb 25, 2019 3:37 pm Post subject: Back up light switch. |
I’ve got a 57 bus with a 67 bus trans in it. For the life of me I can’t find the BU switch. I know where it is on all the other cars, but not this one.
Any ideas ? _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33991 Location: Conejo Valley, CA
Posted: Mon Feb 25, 2019 3:47 pm Post subject: Re: Back up light switch. |
Should be on the nosecone like all other stickshift models. I was not aware the split Bus was any different. See 'em on the left sides at the bottom of the photo?:
Someone could have replaced the switch with some plug if they weren't using it; no reason to, but it's been done. Also, maybe there wasn't room for it in the older chassis, so it was removed/plugged? Could be hard to see with the usual crud, but a '67 tranny should have it there. |
Posted: Mon Feb 25, 2019 4:04 pm Post subject: Re: Back up light switch. |
Yep, that’s where I see them usually. However on my bus there is a crossmember that goes across there very close to the nose cone. Wondering now if the 67 crossmmember is in a slightly different location, or configuration. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Mon Feb 25, 2019 4:08 pm Post subject: Re: Back up light switch. |
I have the switch on my stock 65 transaxle. Its close but the switch clears. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20264 Location: Sandpoint, ID
Posted: Mon Feb 25, 2019 4:18 pm Post subject: Re: Back up light switch. |
This is a photo stolen from the samba gallery. It is the ERCO aftermarket nose cone with the plug for the switch. I have not dug into one for awhile, but I am pretty sure fitting that switch onto an early (non-tunnel trans) bus won't really work.
_________________ nothing |
Posted: Mon Feb 25, 2019 5:06 pm Post subject: Re: Back up light switch. |
I’ll look again, but looking at that aftermarket nose cone it looks like there’s no way a switch could go in that housing. The crossmember is almost butting up to it. I wonder if the 57 crossmemeb is different than the later splittie ones. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
Posted: Mon Feb 25, 2019 5:08 pm Post subject: Re: Back up light switch. |
I have a friend coming over tomorrow to work on her bus. A 67....I’ll check hers out too. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
Posted: Mon Feb 25, 2019 6:29 pm Post subject: Re: Back up light switch. |
gitchesum wrote: |
I’ll look again, but looking at that aftermarket nose cone it looks like there’s no way a switch could go in that housing. The crossmember is almost butting up to it. I wonder if the 57 crossmemeb is different than the later splittie ones. |
Pretty sure it is the way the crossmember and the front mount adaptation all fits together that makes the switch an impossibly tight fit. Unless your 57 has had a later front mount setup welded in, you likely won't be able to use the switch. _________________ nothing |
Posted: Mon Feb 25, 2019 8:50 pm Post subject: Re: Back up light switch. |
I think you're right...Funky pic, but you can see how close that bung where the switch usually goes. Maybe 3/8 clearance...don't see how you could get a switch in there.
I'll have to add a manual switch. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2204 Location: UK (South)
Posted: Tue Feb 26, 2019 6:16 am Post subject: Re: Back up light switch. |
I was in a similar position with my Oct '56 Single Cab. There was no room to fit a switch in the nosecone.
The original reverse light for early busses and trucks used an external push/pull switch that had nothing to do with the gearbox.
It was mounted on the transverse frame rail just forward of the nose cone. A finger was clamped round the long shift rod and acted on that switch, pulling it to make the circuit when reverse was selected. I think it was an option for Ambulances.
I semi-replicated that by mounting a switch on one of the cross-members under the floor as there is more space to work under there. I used a NOS Bosch switch like the ones used on Beetles. They turn up on ebay from time to time and aren't expensive. It is a push-to-make, rather than pull-to-make switch.
I fabricated a 'finger' from a couple of woodworking corner brackets that clamps around the long shift rod.
The shift rod is at its furthest forward point when reverse is selected, so it's easy to put the gear shift in reverse and move the clamped finger to contact the switch. Then run wires across and along the frame rail to power the light.
If you have belly pans, the long shift rod is mostly hidden, so you'd need to fit a switch further back as per the original accessory switch. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Tue Feb 26, 2019 8:36 am Post subject: Re: Back up light switch. |
Or buy one of those VW reverse light switches, an ambulance part number, that screws on to the speedometer and the speedo cable screws onto it. When you start to move in reverse the cable which is now turning the opposite way trips the switch to light up your back-up light. I've got one on my '59 DC... works great.
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Tue Feb 26, 2019 9:33 am Post subject: Re: Back up light switch. |
Who.Me? wrote: |
If you have belly pans, the long shift rod is mostly hidden, so you'd need to fit a switch further back as per the original accessory switch. |
Good call...my thought too on the clearance issue...just no way. Good wor around you came up with tho. Thanks. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
Posted: Tue Feb 26, 2019 9:36 am Post subject: Re: Back up light switch. |
BulliBill wrote: |
Bill |
I've thought about that too. I've got an extra one of those. Have one on an early bug and it takes a bit of distance backing up to operate the light , but that will work.
Thank you. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
