Cold weather and oil cooler seal failure.
Forum Index -> Eurovan Share: Facebook Twitter
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Fri Dec 29, 2017 1:27 pm    Post subject: Cold weather and oil cooler seal failure. Reply with quote
Well, here it is, I always get customers coming in on the first few really cold days with oil cooler seal failure & this time it happened to me. I fired up the Eurovan this morning & set off on my way to work when I noticed a burning oil smell, & noticed the cloud of blue smoke behind the van. I pulled over & checked under the van & saw that the stream of oil had coated the bottom of the van and the exhaust so I poured in the quart & a half that I keep on hand & bought another 5 quarts to limp the beast back home which was just enough for the 1.5 miles back. (And I just took the family on a four hour road trip over Christmas.)
If you haven't changed your oil cooler seals in the last 3-5 years, go ahead & do it now. $5 in parts & 1/2-1 hour is worth having the piece of mind of not having a failure on the road.
On a positive note, I don't have to worry about under coating it this year.
VAEV1993
VAEV1993 is offline
PostPosted: Thu Jan 03, 2019 7:03 am    Post subject: Re: Cold weather and oil cooler seal failure. Reply with quote
Just a bump on this thread.
I think I am experiencing this, though the oil leak seems small, and I am seeing some coolant leaking, but not all the time. I noticed the oil smell though. Only when really cold.
Going to pull the belly pan this weekend and take a look.
1993 Weekender - Hula
2002 Golf TDI
2017 Golf Alltrack
VAEV1993
VAEV1993 is offline
PostPosted: Fri Mar 01, 2019 9:03 am    Post subject: Re: Cold weather and oil cooler seal failure. Reply with quote
Just updating here:
my issue turned out not to be the oil cooler, but two separate issues.
Cold temperature coolant leak coming from thermostat housing, and oil leak at valve cover gasket.
2002 Golf TDI
2017 Golf Alltrack
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sat Mar 02, 2019 10:05 am    Post subject: Re: Cold weather and oil cooler seal failure. Reply with quote
For the VR6 folks, I recently replaced the seals on the cooler and the two between the block and oil filter bracket. The latter were rock hard and came out in pieces. I would plan on replacing those the next time you're in there.
Casey--
'01 Weekender --> full camper
y u rune klassik?
d_walküre
d_walküre is offline
PostPosted: Tue Feb 23, 2021 2:38 pm    Post subject: Re: Cold weather and oil cooler seal failure. Reply with quote
I guess it's my turn to do this repair. I went to start up the Eurovan last week to scrape off ice and snow (-10 degrees outside) and oil just comes gurgling and spewing out of the engine... I thought I had cracked the engine block starting it up in these temps! Well, I put in some cheapy oil today to see if I could recreate what happened and sure enough oil come gushing out from between the oil filter bracket and oil cooler.
I'm just glad it wasn't something more serious.
JesusV
1987 Vanagon GL Syncro SVX NAHT "Valkyrie"
1993 Eurovan Weekender "Camper van Beethoven"
1959 Bug
MrPulldown
MrPulldown is offline
PostPosted: Mon Mar 01, 2021 2:41 pm    Post subject: Re: Cold weather and oil cooler seal failure. Reply with quote
Which o-rings are people using as replacements?
2002 EVC
MrPulldown
PostPosted: Mon Mar 15, 2021 1:29 pm    Post subject: Re: Cold weather and oil cooler seal failure. Reply with quote
Are these the o-rings in question. Is there a write up?
https://www.eurocampers.com/EuroVan-Automatic-Tran..._2480.html
2002 EVC
wannabecamper
wannabecamper is offline
PostPosted: Mon Mar 15, 2021 1:34 pm    Post subject: Re: Cold weather and oil cooler seal failure. Reply with quote
using the same website, here is the gasket in discussion.
https://www.eurocampers.com/EuroVan-Engine-Oil-Cooler-Seal-1992--2003--all-models_p_2487.html
Here is a good link on DIY.
d_walküre
PostPosted: Wed Mar 17, 2021 8:30 pm    Post subject: Re: Cold weather and oil cooler seal failure. Reply with quote
076-117-069-A Oil Cooler Seal $4.21
038-117-070-A Engine Oil Cooler O-Ring $4.37
Here's what I bought from VW*ortex. I ended up replacing both of these o rings since I didn't want to have to go in there twice, but the oil cooler seal was still in pretty good shape and probably did not need replacing.
JesusV
1959 Bug
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
