dave1 Samba Member
Joined: September 12, 2003 Posts: 477 Location: United Kingdom, London
Posted: Thu Feb 28, 2019 3:10 am Post subject: Shock absorbers |
Help required with shock absorbers for a 52 split window beetle. Not sure what I require or where I can obtain them from. Looking for stock for 16" wheels/crossply tires. Are there any details on type/length of travel up/down or part numbers
Thanks Dave |
sled Samba Member
dave1 Samba Member
Posted: Fri Mar 01, 2019 7:54 am Post subject: Re: Shock absorbers |
Hi Sled,
Thank you for the details. I sent info to the restor & has said that he can machine a new centre
Thanks Dave |
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 971 Location: Bath, England
Posted: Fri Mar 01, 2019 4:19 pm Post subject: Re: Shock absorbers |
I've just been looking for a set of these in view of the information provided above, but this seller's information says that the only VW they are suitable for is an early Type 2 - Transporter. https://www.ebay.com/itm/Monroe-OESpectrum-Shock-Absorber-5752-/161382741030
If true, then the ride characteristics would be different to that required on a Beetle/Bug, certainly on the rear, where the weight is substantially different. |
dave1 Samba Member
Posted: Fri Mar 01, 2019 5:23 pm Post subject: Re: Shock absorbers |
Hi Martin
My restoration guy carried out measurements for the open & closed measurements for a shock absorber needed for the split. These were 310mm & 225 > 250mm.
The shock absorbers that Sled has suggested fit the bill. The open & closed shock measurements are 12.75" (324mm) & 8.625" (219mm). As Sled has mentioned the eyelid hole will need modifying this could be the reason that the company state only type 2
Thanks Dave |
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Posted: Fri Mar 01, 2019 6:04 pm Post subject: Re: Shock absorbers |
dave1 wrote: |
Hi Martin
Thanks Dave |
I can't recall if I bought those exact shocks for a Barndoor Bus but I did have to find sleeves for similar shocks that were listed only as Bus shocks from Monroe. The shocks had no sleeves at all on one side. _________________ How to Post Photos
Posted: Sat Mar 02, 2019 1:49 am Post subject: Re: Shock absorbers |
OK. They might physically fit, but because of the weight difference between a Bus & a Bug, the operating characteristics will be different. The other consideration is whether these units are single or double acting, as preferably single acting is required on the front, and double acting on the rear. This is why VW used to have their front shockers coloured black, and the rears red, so as not to confuse fitment.
Last edited by Martin Southwell on Sat Mar 02, 2019 3:24 am; edited 1 time in total |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
dave1 Samba Member
Posted: Sat Mar 02, 2019 5:44 am Post subject: Re: Shock absorbers |
Hi Martin,
Sled has these fitted to his 51 with no issues & as originals are difficult to get these seem a good alternative. Im going to give them a try. Mika has a set of originals for sale. Always great manufactured stuff from this guy. |
bakersam Samba Member
Joined: November 03, 2006 Posts: 119 Location: Washington DC
sled Samba Member
Posted: Sat Mar 02, 2019 9:14 am Post subject: Re: Shock absorbers |
Martin you're overthinking this. A stock height split on 5.00-16 bias plies is not a performance car and rarely is driven above 62mph or 100kph. The handling characteristics of the shock are overshadowed by the poor performance of the tires and suspension. If you were actually pushing your split hard, like some of the European rallye guys do, then yes maybe you would look for a different shock but at that point it would be much better to use a beam with taller shock towers.
As for a stock height Barndoor bus on bias ply tires, the same could be said. If you're looking for road performance then I agree maybe some additional care could be paid. When shocks are shown an application, they are referring to its physical dimensions. A Barndoor bus is NOT equal to a 1950 Chrysler Imperial Crown 4-door. The Chrysler weighs approx 4430lbs and the bus 2400lbs, so how could the shock be suitable for both?
for the price of the Monroe shocks it is worth trying them compared to $350 for just a pair of shocks. If the black color bothers you, buy some red spray paint and squirt them.
Not criticizing Mika's asking price at all, as I'm sure someone wants to use NOS parts on their car.
as a side note, I have actually driven my all-original 51 at over 120kph down a twisty canyon road trying to catch up to a couple slammed buses with big motors, it performed very nicely even with the 5.00-5.25 excelsiors.
_________________ drive your split. |
Markosz Samba Member
Joined: September 24, 2011 Posts: 3 Location: Netherlands
Posted: Tue Aug 27, 2019 5:38 am Post subject: Re: Shock absorbers |
Do you have any pics from the adjustments? what u did? |
