Carburetor and Fuel Pump Numbers/Date codes?
hazetguy
hazetguy is offline
PostPosted: Sun Aug 02, 2009 7:49 am    Post subject: Carburetor and Fuel Pump Numbers/Date codes? Reply with quote
does anyone have a listing of the month/year of production and corresponding serial number ranges of early carburetors and fuel pumps? i'm trying to get a few engines as close as possible to the correct carbs and fuel pumps for their production dates.
the carbs have the numbers on the front of the float bowl.
the fuel pumps have the number along the flange of the base.
looking for 25hp and 36hp fuel pump info and 26VFIS and 28PCI carb info, up to 1960.
any info or links to previous threads would be greatly appreciated.
Your crystal ball ain't so crystal clear
Parts and mechanical restoration services available. I restore and rebuild fuel pumps, distributors, spindles, etc.
Check my ads or send a PM.
RickC
RickC is offline
PostPosted: Tue Nov 17, 2009 8:52 pm    Post subject: Reply with quote
Hey Hazetguy,
Just saw your thread and since I'm working on some early engines that need to be correct, I will start searching some of the numbers on carbs and fuel pumps. Great idea ... thanks.
Rick Clark in Monterey County, CA USA
... where the surf is happening and the lightweights are standing on the beach, checkin' it out...
nlorntson Premium Member
Crazy VW Lady
nlorntson is offline
PostPosted: Wed Nov 18, 2009 8:45 am    Post subject: Reply with quote
I asked this same question in a different thread. I'd love to know about this carb. It was mounted on a factory rebuilt engine that appears to have been rebuilt in the 50's
Nessy
Nessy is offline
PostPosted: Tue Jul 06, 2010 12:43 pm    Post subject: Reply with quote
Thought I'd resurrect this thread in the hope that more info might be available today..... Very Happy
I'm trying to date a zwitter/53-only carb that is numbered 853189 and would very much like to hear from anyone that can possibly give me a date as to when it was produced......
Thanks.
Wink
1972 1302LS Convertible RHD
1963 Type 1 Karmann Ghia Coupe RHD
Volumex
Volumex is offline
PostPosted: Mon Jan 17, 2011 6:28 am    Post subject: Reply with quote
May 1954 original motor - carb number 1159744 motor number 1-77197? Car built on 18 May 54 according to Birth Certificate. (motor number not confirmed on b/c as it is a CKD car.)
Kick me if I haven't posted my Oct 55 numbers by the end of the year.
Anyone can feel free to join in posting their numbers Smile
tasb Premium Member
The Distributor Distributor
tasb is offline
PostPosted: Sat Dec 05, 2015 10:54 am    Post subject: Re: Carburetor and Fuel Pump Numbers/Date codes? Reply with quote
I have an early cogwheel 26 VFI carburetor that I sure wish there was some date code data on. The serial nur: 11837 that's a pretty early number.
Roads Scholar & distributor restorations
1956 oval third owner 36 hp- slow drag Champion 2012, 2014, 2015, 2017
1957 Kombi low mileage 36 hp governor equiped M 178 Slow Drag Winner 2014, 2015, 2018
1960 sunroof beetle owned since 1991 36 hp
1965 hrdtop Deluxe Microbus owned since 1990 M 620 factory 12 v 1500cc
VolkzBitz Premium Member
VolkzBitz is offline
PostPosted: Mon Dec 07, 2015 12:12 am    Post subject: Re: Carburetor and Fuel Pump Numbers/Date codes? Reply with quote
Here are a selection of my own early carburetors with their serial numbers. It would be great to find the dates of the changes etc.
http://volkzbitz.com
Quality VW Solex carburetor restoration
[email protected]
1969 1600cc Karmann Ghia
1969 1641cc Beetle
1965 restored to stock 65 Beetle (sold)
1957 Oval (sold)
1957 Lowlight Karmann Ghia (sold)
1966 restored stock 1966 Beetle (sold)
rod_vw
rod_vw is offline
PostPosted: Thu Dec 17, 2015 1:05 pm    Post subject: Re: Carburetor and Fuel Pump Numbers/Date codes? Reply with quote
Is this an early VW carburettor?
The throat measures 26mm at the base and the stud spacing fits a 25ps manifold.
The only markings are a stamped in number [9087] on the front face of the main body just below the top flange and a cast in number of 08.102 on the left side of top part below and behind the fuel feed union thread. The thread for the fuel union is correct for 8mm fuel pipe.
Does anyone have knowledge of this type please?
Yes I know there is some damage but until I know if it's possibly an early VW carb I'm not getting it restored.
Rod,
www.vwbooks.co.uk -- www.historicvws.co.uk -- www.vintage-volkswagens-lavenham.co.uk
1946 Beetle (Back on the road after over 50 years! Drove from England to Bad Camberg 2019, interesting 1200 mile round trip)
2013 T5 Selfbuild Camper.
2016 T6 Selfbuild Camper completed.
Crazy VW Lady
PostPosted: Thu Dec 17, 2015 1:11 pm    Post subject: Re: Carburetor and Fuel Pump Numbers/Date codes? Reply with quote
Looks to be an early industrial carb.
PostPosted: Thu Dec 17, 2015 6:08 pm    Post subject: Re: Carburetor and Fuel Pump Numbers/Date codes? Reply with quote
Thats interesting Rod. It could be an industrial carburetor as they generally come without the raised band around the fuel bowl. The numbers on the top are very similar to on my Huf carburetor in the picture above, mine say 08.102.8.
They may be too different carbs, the top being a Huf. The lower part looks very course, and the area where the idle jet screws into the carb is larger than all I have seen. Maybe your base is an early cast base?
[email protected]
1969 1641cc Beetle
1957 Oval (sold)
tasb Premium Member
tasb is offline
PostPosted: Sun Dec 20, 2015 12:48 pm    Post subject: Re: Carburetor and Fuel Pump Numbers/Date codes? Reply with quote
Or it could be a Huf carburetor with the throttle and choke linkage borrowed from a Solex carburetor. I believe they are interchangeable.
PostPosted: Sun Oct 16, 2016 12:53 am    Post subject: Re: Carburetor and Fuel Pump Numbers/Date codes? Reply with quote
Does anyone know anything about this carburetor? I did see one on eBay that they called a VFI II.
[email protected]
1969 1641cc Beetle
1957 Oval (sold)
virtanen
virtanen is offline
PostPosted: Sun Oct 16, 2016 1:11 am    Post subject: Re: Carburetor and Fuel Pump Numbers/Date codes? Reply with quote
Typ 166 carb.
Mika
Split beetle restoration panels
Oval beetle restoration panels
[email protected]
JERRY63VW@YAHOO.COM is offline
PostPosted: Fri Mar 08, 2019 9:19 pm    Post subject: Re: Carburetor and Fuel Pump Numbers/Date codes? Reply with quote
Does anybody have more pics of those type 166 solex vfi ll carburetor..
56samba
56samba is offline
PostPosted: Sat Mar 09, 2019 3:28 am    Post subject: Re: Carburetor and Fuel Pump Numbers/Date codes? Reply with quote
Maybe that helps:
https://www.ebay.de/itm/VW-166-Schwimmwagen-SdKfz-...7675.l2557
BulliBill
BulliBill is online now
PostPosted: Tue Sep 03, 2019 1:49 pm    Post subject: Re: Carburetor and Fuel Pump Numbers/Date codes? Reply with quote
I also have three 26 VFIS carbs (all with the raised cast-in "band" around the bowl), and one 26 VFI carb without the raised "band".
There are no apparent serial numbers on two of them and the other two have serial numbers (#678521 and #750325).
Trying to decide which one to focus on for a mid 1952 engine...
Inquisitively yours,
Bill
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
originalo
originalo is offline
PostPosted: Thu Sep 05, 2019 2:02 am    Post subject: Re: Carburetor and Fuel Pump Numbers/Date codes? Reply with quote
Recently I found this SOLEX 26VFI carburetor, both halves KdF logoed and stamped with serial number 1759. That seems to be very early.
