puvanjp Samba Member
Posted: Mon Mar 11, 2019 5:55 am Post subject: 1969 RHD wiring schematic diagram ? |
Been looking for a schematic diagram for my RHD 1969 beetle. anyone here with it? |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Mon Mar 11, 2019 7:41 am Post subject: Re: 1969 RHD wiring schematic diagram ? |
puvanjp wrote: |
The RHD and LHD wiring diagrams are the same.
However, for most years the wiring diag posted is for the US version. The Euro/RoW versions differed slightly for the Deluxe sedan (parking lights in head lamps vs turns), emergency flasher wiring (perhaps), and differed more for the 1200 Standard which trailed in features -- was still 6V.
What model do you have? Deluxe? Standard? _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
bluebus86 Banned
Posted: Mon Mar 11, 2019 8:24 am Post subject: Re: 1969 RHD wiring schematic diagram ? |
Welcome to Samba!
Many wire diagrams can he found under the "technical " tab at top of the samba page. as prior person stated, there are US versons, and others. mainly do to differences in lighting requirements. But most of the wires are the same regardless.
please post a photograph of your Bug!
Good luck, and a big Samba Welcome!
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15985 Location: North Florida, USA
Posted: Mon Mar 11, 2019 2:15 pm Post subject: Re: 1969 RHD wiring schematic diagram ? |
There are three wiring diagrams in the Tech section of this site that apply to the ‘68-69 Beetles. Specifically look at the E-flasher relay and the brake switches. You may need to combine two diagrams to cover all your components. For example, your car may have come with three brakes switches (early style) but over the decades the master cylinder was replaced with a 2-switch MC. Or your E-flasher system may have been upgraded from the early 7-prong flasher relay to the later 4-prong style.
Also, with a non-US Beetle your turn signal+parking light assemblies may be different. The wire colors will be the same but the assemblies may be different.
Other than these things the rest of the wiring should be pretty much the same. The RHD car places the steering column further away from the main harness that comes up from the left A-column well so harness wise you need a RHD specific harness with longer leads that will reach across the back side of the dash to reach the speedo and column located on the right side. But the entire steering column is identical to the LHD model. The turn signal lever is STILL on the left of the wheel (which is odd for a RHD car). _________________ AshMan40
Posted: Mon Mar 11, 2019 10:34 pm Post subject: Re: 1969 RHD wiring schematic diagram ? |
bluebus86 wrote: |
Welcome to Samba!
Bug On!
Thank you for the warm welcome. Will definitely look it up here later in the day. Hope to find my answers. |
Posted: Mon Mar 11, 2019 10:35 pm Post subject: Re: 1969 RHD wiring schematic diagram ? |
puvanjp wrote: |
bluebus86 wrote: |
Welcome to Samba!
Bug On!
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Mon Mar 11, 2019 11:46 pm Post subject: Re: 1969 RHD wiring schematic diagram ? |
Not for rhd but for 68&69.
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Tue Mar 12, 2019 2:06 am Post subject: Re: 1969 RHD wiring schematic diagram ? |
Here is an alternative to the normal US only Bentley wiring diagram for VW 1500 August '67 onwards i.e 1968 model.
It was printed in black and white so that is all I've got. It should be the same for your vehicle in Malaysia.
Most of the RHD's of your vintage did not have the emergency flashers which were commonplace in the US so most of those comments regarding them are not relevant. But of course you may have something different.
Posted: Tue Mar 12, 2019 4:36 am Post subject: Re: 1969 RHD wiring schematic diagram ? |
Vanillagurilla wrote: |
Thank you for this one! Answers my question on emergency light switch and back up light switch. Now I will have to get the measurements for RHD. |
Posted: Tue Mar 12, 2019 6:18 am Post subject: Re: 1969 RHD wiring schematic diagram ? |
viiking wrote: |
Mine did come with emergency flashers. Thanks for your print! |
bluebus86 Banned
Posted: Tue Mar 12, 2019 9:11 am Post subject: Re: 1969 RHD wiring schematic diagram ? |
puvanjp wrote: |
puvanjp wrote: |
bluebus86 wrote: |
Welcome to Samba!
Bug On!
thank you for posting a very nice Bug you have there!
