j10nbom Samba Member
Joined: February 14, 2007 Posts: 262 Location: Philly
Posted: Mon Mar 11, 2019 12:55 pm Post subject: Fuel Leak in my '71 |
Hi All, I searched but I'm still trying to determine the cause of a pretty big fuel leak yesterday in my '71. I filled up with gas before I started driving any real distance. I went a few miles down a fairly windy road and started smelling fuel. So I pulled over the side only to find a sizable puddle of gas in front of the rear passenger side tire as well as around the fuel filler inlet after I opened the flap. To be on the safe side I killed the engine and I had the bus towed back to my garage to deal with it. I noticed after towing the bus back that a bunch of fuel puddled on the roll-up tow truck in a similar spot (many wide turns taken, bumps, etc.)
I believe the gas cap is original so I thought possibly that I overfilled it and fuel may have been sloshing around and escaping that way. I also thought maybe because I moved the fuel filter out of the engine compartment and under the bus where it comes out of the tank...maybe that was the issue? But the line appeared to be appropriately clamped and no evidence of fuel leakage. I'm leaning towards the gas cap and overfilling it being the culprit but I know some of the fuel lines are likely to be originally and I don't believe the EVAP canister and lines are present. I'm pretty confused to be honest and couldn't determine the exact source yesterday.
So any thoughts, help, or advice would be greatly appreciated! |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Mon Mar 11, 2019 1:07 pm Post subject: Re: Fuel Leak in my '71 |
it is the line that goes from the fill port to the tank. cracked, and damage escalates when you shove the gas nozzle in deep. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5995 Location: Brooklyn
Posted: Mon Mar 11, 2019 1:08 pm Post subject: Re: Fuel Leak in my '71 |
Gasket in fuel filler cap.
Filler neck.
Vent lines.
Probably gonna want to pull the firewall panel to get a good look at what's going on with the filler system.
I mean the easiest thing would be if the gasket in the cap is bad. But beyond getting lucky and fixing it with that, good time to pull the engine out and the firewall panel and see what's up. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Mon Mar 11, 2019 1:19 pm Post subject: Re: Fuel Leak in my '71 |
on the filler neck, the repop I read is crap. Skills will tell you. he cut a hole to have easy access because it needs replaced every couple of years. Someone else on here took the filler neck to the FLAPS and found an off the shelf piece that did the job, but time will tell. I don't recall if they had to add an elbow.
someone here will correct me, but is there not a round pie plate cover in the engine compartment that pops out that the OP could have a peek? |
Angus II Samba Member
Joined: June 01, 2016 Posts: 707 Location: Mammoth Lakes Ca. 93546
Posted: Mon Mar 11, 2019 1:31 pm Post subject: Re: Fuel Leak in my '71 |
Hello,
Fuel/gas cap seal... most likely.
Filler tube to tank, doubt it. You wouldn't get fuel back up stream at the fuel cap area.
Yet, maybe a vent line..
Cheapest fix is try another fuel cap or seal. Other wise you may be pulling your engine if it's the filler too tank hose piece.
Hell, just fill to half a tank then, problem solved... No... |
Posted: Mon Mar 11, 2019 1:39 pm Post subject: Re: Fuel Leak in my '71 |
Sounds like the cheap fix is to throw on a new gas cap on and not overfill it. I'm probably going to end up dropping tank because I have to replace the sending unit anyway. I think that'll be a good opportunity to replace it all with new rubber. |
Posted: Mon Mar 11, 2019 1:52 pm Post subject: Re: Fuel Leak in my '71 |
Could be a block tank ventilation system that is forcing the fumes to find another way out and carrying liquid gasoline with them. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Mar 11, 2019 3:30 pm Post subject: Re: Fuel Leak in my '71 |
Mine pulled that move a few years ago when the OG filler neck hose shrank enough to partially pull itself off the tank end.
New hose, vapor line connectors and a sender internal ground rework and it's good for another 45 years _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Mon Mar 11, 2019 8:18 pm Post subject: Re: Fuel Leak in my '71 |
The smoking gun here is that it did it after you filled the tank. When the fuel backs up into the filler neck that forces fuel out the vents that live on the left and right side of the top of the tank. This usually isn’t a problem unless they are old hoses and leak.
The solution is:
1) pull the engine, then the firewall, and replace the vent hoses or
2) only fill the tank to less than full
You can live a long time only filling to 3/4 _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Zed999 Samba Member
Posted: Tue Mar 12, 2019 1:46 am Post subject: Re: Fuel Leak in my '71 |
busdaddy wrote: |
New hose, vapor line connectors and a sender internal ground rework and it's good for another 45 years |
A customer of mine once accused me of dislodging the filler hose from the tank by jacking up one front corner to attend to the brakes. When I'd stopped laughing it became apparent even to him that he'd done it himself by ramming the pump nozzle in and wiggling it about to get it far enough in. The old filler hose had shrunk until it was only luck keeping it in place |
Posted: Tue Mar 12, 2019 10:24 am Post subject: Re: Fuel Leak in my '71 |
All really good info here. I guess I'll be putting the fuel line/sending unit repair on the list a little sooner than I thought. Granted, I could always keep the fuel level a bit lower and carry a jerry can on me. |
