nilza Samba Member
Joined: May 21, 2007 Posts: 342 Location: brisbane australia
Posted: Thu Sep 24, 2015 3:04 am Post subject: |
_________________ still floating around the web somewhere |
clift_d Samba Member
Joined: December 02, 2012 Posts: 265 Location: Hackney innit, UK
Posted: Thu Sep 24, 2015 4:15 am Post subject: |
Ooh. Shiney! How would we go about getting hold of one of these?
Also, as you have everything on CAD, it would really simplify installation if you could make a PDF drilling template with badge outline overlaid with the pin locations. _________________ 1988 LHD T25 1.6TD Westfalia Club Joker syncro |
nilza Samba Member
Posted: Fri Sep 25, 2015 1:19 pm Post subject: |
clift_d wrote: |
Also, as you have everything on CAD, it would really simplify installation if you could make a PDF drilling template with badge outline overlaid with the pin locations. |
Good idea Clift, shouldn't be a drama.
They are getting closer to being available, but I am having a few dramas at the moment in regards to material quality. So at this point chroming is still being looked into, unfortunately this will bring the price above the fast forward product. _________________ still floating around the web somewhere |
Posted: Mon Sep 28, 2015 8:21 am Post subject: |
I like the stainless, but I'm sure there are those that will go for the chrome bling.
Is the idea that these will be fitted using stainless starlock washers, or glued, or both? If they aren't already then perhaps the pins could be sized to work with a starlock washer so that people have the choice - probably 2mm or 3mm would work. _________________ 1988 LHD T25 1.6TD Westfalia Club Joker syncro |
nilza Samba Member
Posted: Tue Oct 06, 2015 2:35 pm Post subject: |
Currently the pins on the rear are the same placement as the original and are 2mm in diameter. How you fasten them is up to the individual. The tinnerman nuts used on the original are cheap and plentiful, surely there is a stainless alternative. But right now I am concentrating on getting the first batch out the door.
. On that note they are now in the process of being chromed and should be available in the states next month.
The advantage Clift of the 3D print is if you have a specific requirement for say, the size of the pin or placement of the pins (perhaps some numpty drilled holes in you van in the wrong place) in a few minutes that can be altered to suit. _________________ still floating around the web somewhere |
Posted: Wed Oct 07, 2015 7:17 am Post subject: |
nilza wrote: |
Currently the pins on the rear are the same placement as the original and are 2mm in diameter. How you fasten them is up to the individual. The tinnerman nuts used on the original are cheap and plentiful, surely there is a stainless alternative. |
Sounds ideal. I'm guessing tinnerman nuts are very similar to starlock washers in the way they work
nilza wrote: |
On that note they are now in the process of being chromed and should be available in the states next month. |
Any thoughts about availability for the UK? _________________ 1988 LHD T25 1.6TD Westfalia Club Joker syncro |
nilza Samba Member
Posted: Wed Oct 07, 2015 4:56 pm Post subject: |
clift_d wrote: |
Any thoughts about availability for the UK? |
Sorry Clift I didn't realise you were in the UK, that should not be a problem really, just a matter of time.
Ideally they need to be purchased in lots of 20 otherwise the price for plating gets out of control in singles. A fellow in the states was just the first to put his hand up to distribute.
Once the details are complete and a true costing can be established, I will advertise in the samba classifieds the single unit cost. _________________ still floating around the web somewhere |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1730 Location: Portland
Posted: Mon Apr 25, 2016 6:56 am Post subject: Re: Syncro Puch Badge |
Any update on these? _________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
nilza Samba Member
Posted: Mon Apr 25, 2016 1:09 pm Post subject: Re: Syncro Puch Badge |
There is a fellow in the states that purchased a pile of these,
His name is Ben, you should be able to contact him
His name on the forum is BenTsyncro, send him a PM. _________________ still floating around the web somewhere
BenT Syncro Samba Member
Joined: January 07, 2005 Posts: 1085 Location: San Francisco
Posted: Mon Apr 25, 2016 1:15 pm Post subject: Re: Syncro Puch Badge |
I got the message from Otis. I'm traveling this weekend and haven't had a chance to answer all my messages. _________________ BenT |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Mon Apr 25, 2016 11:50 pm Post subject: Re: Syncro Puch Badge |
Me thinks there will be an ample supply of them at Syncofest this weekend. A little birdie told me that the plastic gods have been busy.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
bizarre Samba Member
Posted: Fri Mar 09, 2018 7:16 pm Post subject: Re: Syncro Puch Badge |
I git one off Nils a while back for my steering wheel
Great quality
B-bear604 Samba Member
Joined: August 16, 2014 Posts: 118 Location: Delta BC
Posted: Sun Mar 11, 2018 11:31 pm Post subject: Re: Syncro Puch Badge |
what about http://www.van-cafe.com/adhesive-backed-puch-emblem _________________ Brent H
1991 Westfalia Multivan "Vicki"
1986 Westfalia "Wolfsburg Edition" Lowered, RIP😭
2005 Jetta Wagon TDI
1985 Mercedes 380sl |
Posted: Mon Mar 12, 2018 12:09 pm Post subject: Re: Syncro Puch Badge |
Yes, I got a couple of those as well. The only thing is that they are missing the mounting pins for those that want the original style. _________________ 1978 Sage Green P22 Westfalia
JED THE SPREAD Samba Member
Joined: July 14, 2009 Posts: 626 Location: South London UK
Posted: Thu Sep 14, 2023 9:43 am Post subject: Re: Syncro Puch Badge |
The Syncro script on the rear of the vehicle is adhesive backed.
I understand that the Van and Doka "Syncro" badges are different sized, with the truck version being smaller.
I think these are the slightly smaller truck version
https://gowesty.com/products/syncro-rear-hatch-emblem
I think I found the correct size differences on this website.
https://www.areacamper.es/en/59-custom-accessories?page=3
