karladaune Samba Member
Posted: Sat May 19, 2012 10:11 am Post subject: Flat top pistons vs dish top pistons? Advice needed! |
ok, advice needed. I am in the process of rebuilding Ruby's engine (75 Rivi, with a 79 2.0.) I followed the advice of a friend and bought a "VW Porsche 2.0 94mm x 71mm Flat Top Piston & Cylinder Kit 914 for Type 4." Now I am having a bit of buyers remorse as I have heard from multiple people now that I should have got the standard dish top pistons because the flats run too hot. Does anybody have any experience with this? |
Posted: Sat May 19, 2012 10:46 am Post subject: |
I would put it together and be prepared to run high test. You should be able to offset the cost of the better fuel with the better gas mileage you will be getting. |
Bleyseng Samba Member
Posted: Sat May 19, 2012 11:39 am Post subject: |
I am running the 94mm flat tops and really its all about setting your compression ratio right. This of course depends on the combustion chamber size and your deck ht.
Measure your combustion chamber and mock up the deck ht so you can calculate the CR. Mine is set at 8 to 1 and runs great. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat May 19, 2012 11:56 am Post subject: |
Agreed, you can run nearly any piston you like if you set the CR correctly, VW went dished to save on shims and measuring at the factory and keep the production line moving along with standarized parts. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
chazz79 Samba Member
Posted: Sat May 19, 2012 12:02 pm Post subject: |
Yes, you need to get it to someone familiar with vw engines. Those will work fine with proper cylinder shimming. I think running those straight up net cr of 8.8. Anything over eight is short lived in a bus. _________________ One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster |
Posted: Sat May 19, 2012 2:35 pm Post subject: |
chazz79 wrote: |
Anything over eight is short lived in a bus. |
Maybe Colin will chime in with how long his lasted. Don't think it was exactly short lived. |
Posted: Sat May 19, 2012 5:31 pm Post subject: |
much appreciated, guys! I really didnt want to have to buy another set! Poor Ruby has been sitting WAY too long, time to get the ball rolling!
Bleyseng - you are in my neck of the woods...do you do all your own work or do you have a shop you would recommend for make sure everything is a-ok? |
Posted: Sat May 19, 2012 10:19 pm Post subject: |
I do my own work.
Setting up and measuring is pretty easy and kinda fun...readup on it to see if you can do it. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Sun May 20, 2012 12:04 am Post subject: |
Wildthings wrote: |
chazz79 wrote: |
Colin wasn't 8:1 or more CR either. More like stock 7.3:1
As for the CR in a bus...IMO don't go over 8:1 |
Posted: Sun May 20, 2012 2:50 am Post subject: |
udidwht wrote: |
Wildthings wrote: |
chazz79 wrote: |
Colin at one time had a high compression engine 1700 in the Road Warrior, probably an 8.2:1. At least that is what I got from his posts on this subject. |
cdesaul Samba Member
Posted: Sat Mar 23, 2019 7:08 am Post subject: Re: Flat top pistons vs dish top pistons? Advice needed! |
I have the same problem. Do you use the shims between cylinder and bloc. I read that one should not use gaskets or shims between head and cylinder |
Posted: Sat Mar 23, 2019 7:42 am Post subject: Re: Flat top pistons vs dish top pistons? Advice needed! |
Check the volume of your heads combustion chamber first and then deck ht so you can figure out the compression ratio. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
Posted: Sat Mar 23, 2019 7:48 am Post subject: Re: Flat top pistons vs dish top pistons? Advice needed! |
So, shims under cylinder and no head gaskets? |
Posted: Sat Mar 23, 2019 8:21 am Post subject: Re: Flat top pistons vs dish top pistons? Advice needed! |
cdesaul wrote: |
No cylinder head gaskets. VW put out a tech bulletin back ~1990 calling for them to be removed.
https://www.ratwell.com/mirror/www.dolphinsci.com/techbull.html
Don't forget to notch the rods. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
HAM Inc Samba Member
Joined: May 09, 2011 Posts: 161 Location: Watkinsville,GA
Posted: Sat Mar 23, 2019 10:12 am Post subject: Re: Flat top pistons vs dish top pistons? Advice needed! |
If your heads have stock 2.0 bus chambers they will be in the ballpark of 51cc's.
If your deck hight is in the neighborhood of 1.25mm (common value) it will = 8.7cc's
With flat top pistons with no valve reliefs your total unswept volume will = 59.7cc's
59.7 + 492.7 (swept volume) =552.44
552.44/59.7= 9.25:1 CR
Factory bus pistons had a 15cc dish.
If your goal is 8.0:1 you will need a total unswept volume of 70cc's.
If your chambers are indeed stock 2.0 bus and your pistons have no reliefs or dish then you will need 19cc's of deck ht volume. That will require 2.74mm of deck ht.
That's a recipe for detonation, decreased power and increased heat. _________________ Len Hoffman
Hoffman Automotive Machine Inc.
www.hamheads.com |
Posted: Sat Mar 23, 2019 2:31 pm Post subject: Re: Flat top pistons vs dish top pistons? Advice needed! |
Then you will just run 100 Octane race gas at that CR... _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
timvw7476 Samba Member
Posted: Sat Mar 23, 2019 7:33 pm Post subject: Re: Flat top pistons vs dish top pistons? Advice needed! |
Run the head gaskets.
Machine out dish in the flat tops. (8-10cc)
Now you can run 93 octane. Maybe.
I believe the camper top drag makes it more difficult to run higher CR anyhoo. |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Sat Mar 23, 2019 8:50 pm Post subject: Re: Flat top pistons vs dish top pistons? Advice needed! |
My type 1 1776 has 9.25 to 1 CR, I run 93octane and just have to retard max timing to 29 deg or I get ping. Might be a le to increase now with my new 40idfs but haven't tasted yet.
But, if I were you I would just set my engine up for lower compression while you have it out. Even if you hit 8.5 to 1 you'll likely be fine. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Sun Mar 24, 2019 6:19 am Post subject: Re: Flat top pistons vs dish top pistons? Advice needed! |
Keep in mind that the volume created by using the headgaskets (4.9cc's) factors as deck ht.
More deck ht = less squish
At 2.7mm (the amount required to get the CR down to 8.0:1 with stock 2.0 Bus heads ) we are well into the excessive deck ht zone.
Less squish = less efficient combustion.
The more inefficient the combustion the more heat and detonation.
The more heat and detonation the more likely the crappy laminated headgaskets are to fail.
At 2.7mm's of deck, squish is reduced to dangerously low levels on a low speed engine. Detonation is a certainty. The knee jerk tuning response
of fuel enrichment and retarded timing to prevent detonation will lead to off the charts EGT's. Engine life and performance will suffer greatly.
My advise would be to suck it up and get the proper bus pistons with the 15cc dish. The dish in the pistons is part of the overall combustion chamber design. Bus heads rely on it for the proper CR. Other means of achieving that CR will prove unsatisfactory.
As for octane and T4's in bays, here's my two cents. Even with a CR of 7.5:1 all bus owners should be running the highest octane grade available. This statement may illicit howls of protest and plenty of folks who say they run low-test with no issues. That may be fine for around town with no heavy load and no long full throttle running.
But load that beast of burden to the penultimate straw and start climbing mountains or tacking into headwinds with long sustained full throttle running and even at a low CR you'll need every bit of detonation resistance you can get.
Like a cardiologist who's seen the effects of too many bacon cheeseburgers on arteries, so have I seen the effects of poor gas and headgasket shuffling and blown T4 head gaskets on the inherently weak T4 head. These heads consume themselves when conditions aren't right. _________________ Len Hoffman
www.hamheads.com |
