speedo needle replacement
Henrik_K
Henrik_K is offline
PostPosted: Thu Mar 28, 2019 4:23 am    Post subject: speedo needle replacement Reply with quote
My speedo needle is broken and I have a backup Speedo - missing the little pin the needle rests on - not activated.
So I have to move needle from one - to the other speedo.
I've tried to pull the needle off with a pair of pliers. But it wont come off.
Any tips and tricks for this?
Rgds, Henrik
spacebiscuit
spacebiscuit is offline
PostPosted: Thu Mar 28, 2019 6:23 am    Post subject: Re: speedo needle replacement Reply with quote
I've done this on a Golf speedo, I had to be quite firm but it did pop off, I had to literally prise it off. I'm not sure if it is the same with the bus needle but likely so I would imagine.
Pretty sure I managed it with my fingers to avoid any damage to the needle itself.
T2 '72 1600cc / T2 '70 1600cc
LeeE
LeeE is offline
PostPosted: Thu Mar 28, 2019 7:12 am    Post subject: Re: speedo needle replacement Reply with quote
I also would like to know if anyone has been able to get the speedo needle off.
I have tried pulling with fingers and carefully prying with needlenose pliers and have not yet been able to even move the needle. Penetrating oil doesn't help.
They are very brittle and I don't want to break another.
1978 Westfalia stock 2.0 FI
Welcome to the Okeedokee Swamp
rustbus
rustbus is offline
PostPosted: Thu Mar 28, 2019 8:09 am    Post subject: Re: speedo needle replacement Reply with quote
use the thickest paper you can cut to protect the face
May of '72 Deluxe. Red Bay Bus 2.0L L-Jet CS & 091 trans conversion
my Bus thread
vwwestyman
vwwestyman is offline
PostPosted: Thu Mar 28, 2019 11:19 am    Post subject: Re: speedo needle replacement Reply with quote
One other tip.
If you aren't careful, you'll put the new one on in the wrong spot and your speedo will read way off.
Gently lift the needle up and over over the stop (the post at the 10 MPH spot) and note where it rests before trying to pry it off.
Reinstall the new needle in the same position and you then gently lift it up and over the stop again and you should end up with a correct-reading speedometer.
That is probably why the needle in the pic with the wrenches is pointing at about the 100 MPH position.
Dave Cook
Stuartzickefoose wrote:
I'm gonna punch vwwestyman then shake his hand when I meet him.
notchboy wrote:
Ill just punch you in the face. Wink
1973 Wild Westerner
My Thing
www.thefosterdads.com
LeeE
LeeE is offline
PostPosted: Thu Mar 28, 2019 11:23 am    Post subject: Re: speedo needle replacement Reply with quote
Perfect, I'll try that
10-Q very much
