dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Thu Mar 28, 2019 8:52 am Post subject: Reinz gasket/seal kit washer and o-ring identification |
i recently purchased a Victor Reinz full gasket/seal kit. there are several o-rings and washers that are confusing me.
there are six o-rings:
1. small green - dipstick tube
2. large - breather tower
3. largest - water pump
4. small D shaped - distributor shaft
5. small - t-stat housing to 3&4 head
6. large - flywheel/flex plate o-ring
not included in the kit:
pulley o-ring
oil cooler o-ring
there are six washers:
1. copper head drain washer (1&2 head)
2. copper head drain washer (3&4 head)
3. copper large - oil drain plug
4. copper medium - oil pickup tube bolt
5. copper small - unknown
6. small steel - unknown
edited to add confirmed usages _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC
Posted: Thu Mar 28, 2019 11:43 am Post subject: Re: Reinz gasket/seal kit washer and o-ring identification |
took the time to make what i could not find on the internet - feel free to add corrections!
Victor Reinz Vanagon Gasket Set
A cork valve cover gaskets (2)
B rubber head gaskets (2)
C intake manfold gaskets (2)
D rear main seal (flywheel/flexplate end)
E front main seal (pulley end)
F exhaust gasket (4)
G carb gasket (not used on FI models)
H intake gasket (not used on FI models)
I coolant flange gasket
J water pump o-ring
K oil pump gasket
L oil pump cover gasket
M intake gasket (not used on FI models)
N cylinder metal top rings (4)
O top jug o-ring (green) (4)
P bottom jug o-ring (black (4)
Q pushrod tube seal (head) (4)
R pushrod tube seal (case) (4)
S flywheel\flexplate o-ring
T distributor o-ring (D shaped)
U fuel pump gasket (only one used on FI models for cover plate)
V coolant gasket
W oil filler tube gasket
X felt pilot bearing gasket
Y breather tower o-ring
Z t-stat housing to 3&4 head
AA head drain plug washer (2)
BB oil drain plug washer
CC oil pickup tube bolt washer
DD oil dipstick tube o-ring
EE UNKNOWN
FF UNKNOWN
1 Reinzosil black sealant
2 Yellow sealant _________________ 1991 Vanagon GL Camper
BiWerks Design, LLC
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1890 Location: Sidney B.C. Canada
Posted: Thu Mar 28, 2019 1:00 pm Post subject: Re: Reinz gasket/seal kit washer and o-ring identification |
Hi,
No help with your direct question but a heads up on the oil pump gaskets. There are two, one for the back of the pump and one to go between pump body and cover plate. The latter, in two kits I’ve had experience with, were thicker than they should be. Just going by faulty memory , the cover plate gasket was closer to 0.010” than the expected 0.004” or so.
I ended up with lower than expected oil pressure due to this. Finally I discarded the gasket and used locktite gasket sealing compound.
I did lap the cover plate aswell.
Alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
Posted: Thu Mar 28, 2019 2:40 pm Post subject: Re: Reinz gasket/seal kit washer and o-ring identification |
the Reinz set i received has a single thin oil pump gasket for between the pump and case. _________________ 1991 Vanagon GL Camper
BiWerks Design, LLC |
Zeitgeist 13 Samba Member
Posted: Thu Mar 28, 2019 3:26 pm Post subject: Re: Reinz gasket/seal kit washer and o-ring identification |
You could probably use Reinzosil between the pump and cover. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
bobhill8 Samba Member
Posted: Thu Mar 28, 2019 3:31 pm Post subject: Re: Reinz gasket/seal kit washer and o-ring identification |
Thanks Dabaron - I wish I had this a month ago, but still, now I know why I had so many extras that I couldn't find a home for. Hope you're having luck getting them all on. |
Posted: Fri Mar 29, 2019 5:57 am Post subject: Re: Reinz gasket/seal kit washer and o-ring identification |
bobhill8 wrote: |
sorry, i've been distracted by life (aka 17year old son) or i would have gotten to this about a month ago...
still haven't figured out what the small copper and small steel washers are for, i'm guessing not for my 2.1 FI engine.
hope your rebuild went! _________________ 1991 Vanagon GL Camper
Posted: Fri Mar 29, 2019 5:59 am Post subject: Re: Reinz gasket/seal kit washer and o-ring identification |
Zeitgeist 13 wrote: |
You could probably use Reinzosil between the pump and cover. |
that is the plan. everything looks to be in good shape and damn near 0.000 clearance. _________________ 1991 Vanagon GL Camper
jberger Samba Member
Posted: Fri Mar 29, 2019 8:19 am Post subject: Re: Reinz gasket/seal kit washer and o-ring identification |
dabaron wrote: |
that is the plan. everything looks to be in good shape and damn near 0.000 clearance. |
You do want a bid of end play here IIRC, like three thousandths.
I like the anaerobic gasket maker at this location though.
J |
ajdenette Samba Member
Joined: February 15, 2009 Posts: 768 Location: Hope Valley RI
Posted: Fri Mar 29, 2019 5:37 pm Post subject: Re: Reinz gasket/seal kit washer and o-ring identification |
I think FF might be the small crush washer that goes on the fuel pressure test port on the fuel injection T, I would also say that the fuel pump gasket is used on the FI vans to seal the block off plate to the block. _________________ 1985 2wd Westy with 2000 Subaru 2.2 current driver
https://www.thesamba.com/vw/forum/viewtopic.php?t=685635
1986 Syncro Doka Project next in line
https://www.thesamba.com/vw/forum/viewtopic.php?t=732777
1990 Vanagon Syncro Base awaiting body work |
Posted: Mon Apr 01, 2019 10:03 am Post subject: Re: Reinz gasket/seal kit washer and o-ring identification |
ajdenette wrote: |
I would also say that the fuel pump gasket is used on the FI vans to seal the block off plate to the block. |
i concur, one is used for that purpose. _________________ 1991 Vanagon GL Camper
tencentlife Samba Member
Posted: Tue Apr 02, 2019 2:53 pm Post subject: Re: Reinz gasket/seal kit washer and o-ring identification |
G are Type4 exhaust gaskets.
FF is aluminum, it's for the fuel pressure test port screw.
Going by looks, I'd say you mixed up S and Y. Anyway, breather tower is fat black, f/w is silvery.
AA and EE are all just M8 coppers, for oil pickup bracket bolt and head drain plugs.
The fat pulley o-rings are often good for another go, but VanCafe has them. OWHX eared o-ring also has to be bought separately, VC once again.
There's a lot left over after you build a US wbx, don't think you have to account for everything.
Oil pump gear endplay should be as small as you can get it while the gears still turn freely. 0.001" would be ideal. The clearance opens up at temp, so no need to have .003" cold, it'll be that big when it runs. Reinzosil is great for direct sealing of the cover without a gasket. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Wed Apr 03, 2019 7:31 am Post subject: Re: Reinz gasket/seal kit washer and o-ring identification |
tencentlife wrote: |
Oil pump gear endplay should be as small as you can get it while the gears still turn freely. 0.001" would be ideal. The clearance opens up at temp, so no need to have .003" cold, it'll be that big when it runs. Reinzosil is great for direct sealing of the cover without a gasket. |
thank you for the updates...
my oil pump endplay was between .002 and .003, i used Reinzosil between the case and pump and the thin gasket for the cover based on a previous post comment. _________________ 1991 Vanagon GL Camper
Posted: Wed Apr 03, 2019 7:54 am Post subject: Re: Reinz gasket/seal kit washer and o-ring identification |
dabaron wrote: |
my oil pump endplay was between .002 and .003, i used Reinzosil between the case and pump and the thin gasket for the cover based on a previous post comment. |
You'll want to pull that gasket out and use your sealant of choice.
J |
