Posted: Fri Feb 08, 2019 8:52 am Post subject: Re: Bringing a stored 2.1L WBX back to life |
It sounds like you may have a valve(s) seized in its guide. You could try spraying some penetrating oil on the stems and then give it a hour or two to soak in and try it again.
No time like the present to pull the heads and have them gone through though. |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Fri Feb 08, 2019 9:30 am Post subject: Re: Bringing a stored 2.1L WBX back to life |
Wildthings wrote: |
the valves seem to close with the rockers off. i want to get a leak down test done with the rockers in place before i pull the heads. once that is done, the heads are coming off.
is doing the leak down test a waste of time? i figured any issues with the valves would present themselves with the leak down. _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
Posted: Fri Feb 08, 2019 10:20 am Post subject: Re: Bringing a stored 2.1L WBX back to life |
dabaron wrote: |
Wildthings wrote: |
is doing the leak down test a waste of time? i figured any issues with the valves would present themselves with the leak down. |
A leak down test would help let you know the condition but might also give meaningless results. If a valve isn't closing because there is carbon between the valve and the seat the leakdown test may indicate a bad valve when there actually isn't one. This is a very common problem when the intake manifolds have been removed from the engine breaking carbon loose which then falls down into the ports, it can take several minutes of running to get the last of the carbon to clear itself. If your test indicates a leaking valve then you can take a brass drift and a hammer and tap on the end of the valve repeatedly, this may or may not do the job 100%. |
Aryana Samba Member
Joined: November 09, 2015 Posts: 568 Location: Southern CA
Posted: Fri Feb 08, 2019 10:38 am Post subject: Re: Bringing a stored 2.1L WBX back to life |
Subscribed!!! I have a similar engine sitting in my shop waiting for me to do the same.
Thanks for posting pics, they’re great for me as a lurker on your thread. |
Posted: Fri Feb 08, 2019 10:55 am Post subject: Re: Bringing a stored 2.1L WBX back to life |
Aryana wrote: |
here are some more pictures. it's tough to remember to get photos while your doing stuff. i'll try to get more.
Posted: Fri Feb 08, 2019 11:32 am Post subject: Re: Bringing a stored 2.1L WBX back to life |
No one wasted any money on oil changes on this one.
The lifters probably beat themselves to death for thirty minute each time it was started. Don't think I have had one of my own engines come close to looking that bad EVER, even aircooled engines back in the seventies running the crappy oil SF that was available back them. I did run straight weight oils during the heat of summer which helped a lot.
Zeitgeist 13 Samba Member
Posted: Fri Feb 08, 2019 1:49 pm Post subject: Re: Bringing a stored 2.1L WBX back to life |
Yep, that needs to come apart. Way too much muckety-muck for my liking. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Fri Feb 08, 2019 4:16 pm Post subject: Re: Bringing a stored 2.1L WBX back to life |
Think I found a problem
Here's the engine in my bench stand
And some glass that fell out of the metal dizzy case
TDC
Posted: Fri Feb 08, 2019 4:37 pm Post subject: Re: Bringing a stored 2.1L WBX back to life |
dabaron wrote: |
Think I found a problem |
The problem is not the bent pushrods, but whatever caused the pushrods to bend, likely a couple of valves seized to their guides.
The glass is likely a none issue, it didn't come from your engine and most likely didn't hurt anything at all. |
Posted: Sat Feb 09, 2019 8:26 am Post subject: Re: Bringing a stored 2.1L WBX back to life |
Wildthings wrote: |
dabaron wrote: |
tapped on all the valves with a rubber mallet and they are moving, tested with my other set of push rods. something to remember for the next engine...
that glass is from the accident Dave mentioned, it's amazing that i found more glass when i cleaned around the pulley. _________________ 1991 Vanagon GL Camper
Posted: Mon Apr 01, 2019 11:49 am Post subject: Re: Bringing a stored 2.1L WBX back to life |
making progress on the rebuild. Saturday i sealed the case, yesterday i added the pistons and jugs and sealed the head on 1 and 2.
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2797 Location: North Carolina
Posted: Mon Apr 01, 2019 12:09 pm Post subject: Re: Bringing a stored 2.1L WBX back to life |
mikemtnbike wrote: |
You missed a spot, keep cleaning. |
perfect is the enemy of my vanagon getting off my lawn. _________________ 1991 Vanagon GL Camper
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Tue Apr 02, 2019 4:33 am Post subject: Re: Bringing a stored 2.1L WBX back to life |
were the case and heads soda blasted? whatever it was did a nice job. _________________ -dan
www.thefixitworkshop.com |
Posted: Tue Apr 02, 2019 5:20 am Post subject: Re: Bringing a stored 2.1L WBX back to life |
DanHoug wrote: |
were the case and heads soda blasted? whatever it was did a nice job. |
case was hot dipped then painted. the heads are AMC replacements. _________________ 1991 Vanagon GL Camper
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Tue Apr 02, 2019 5:22 am Post subject: Re: Bringing a stored 2.1L WBX back to life |
Man that looks GOOD! And the thread post count looks good too _________________ Brandon
Instagram @joannthevan |
Posted: Tue Apr 02, 2019 5:27 am Post subject: Re: Bringing a stored 2.1L WBX back to life |
shagginwagon83 wrote: |
Man that looks GOOD! And the thread post count looks good too |
i'm going to post a complete writeup once i get it in the bus and running. i'm waiting for some hippies to ship me the oil cooler o-ring _________________ 1991 Vanagon GL Camper
90Doka_Guy Samba Member
Joined: April 08, 2007 Posts: 548 Location: South Jersey
Posted: Tue Apr 02, 2019 9:16 am Post subject: Re: Bringing a stored 2.1L WBX back to life |
Can I ask where you got the case hot dipped? I have a case I am looking to get done. _________________ -'87 Westy
-'90 Tintop
-'90 DOKA |
Posted: Tue Apr 02, 2019 9:20 am Post subject: Re: Bringing a stored 2.1L WBX back to life |
90Doka_Guy wrote: |
Can I ask where you got the case hot dipped? I have a case I am looking to get done. |
ECAM in Glenside, PA.
http://ecamracing.com/ _________________ 1991 Vanagon GL Camper
