bwaz Samba Member
Posted: Thu Apr 11, 2019 7:43 am Post subject: Re: '58/'59 Beetle Discussion |
VeeDubKev wrote: |
New to this thread. Im told I have a 58’ but I dont really know anything else got it as a bare shell with wrong fenders (for now). My number is 1805440 can anyone tell me some info from that ? |
It looks like it's a January 58 build, so officially a 1958 model year (Aug 57-end of July 58 ) https://www.thesamba.com/vw/archives/info/bugchassisdating.php
remember the numbers are for the last vehicle made in the month so 1815 645 was the last made in January. |
VeeDubKev Samba Member
Joined: November 09, 2015 Posts: 29 Location: Miami,fl
Posted: Thu Apr 11, 2019 11:26 am Post subject: Re: '58/'59 Beetle Discussion |
bwaz wrote: |
VeeDubKev wrote: |
Thanks a million |
AlohaBuggin Samba Member
Joined: July 03, 2018 Posts: 6 Location: Edmond, OKLA
Posted: Fri Apr 12, 2019 9:11 am Post subject: Re: '58/'59 Beetle Discussion |
Much appreciated. Thanks for the help. I’ll give it a shot |
IndyDave Samba Member
Posted: Wed Jun 26, 2019 7:27 pm Post subject: 59 Euro 3-wire turn signal switch |
Gurus:
Is there a proper name for this type of switch housing?
I can't find a 3-wire replacement switch. Anyone know of a source for the 3-wire switch for this semaphore EuroBug?
If not, does anyone have experience fitting the WW 6-wire Repro into this housing?
Thanks--
IndyDave
mukluk Samba Member
Posted: Wed Jun 26, 2019 7:34 pm Post subject: Re: '58/'59 Beetle Discussion |
The same switch used for US market Oct '52 through mid '55 was also the one used for European/semaphore cars Oct '52 through the '59 model. Part number 111953511A. _________________ 1960 Ragtop w/Semaphores "Inga" |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jun 26, 2019 7:36 pm Post subject: Re: 59 Euro 3-wire turn signal switch |
IndyDave wrote: |
Gurus:
Thanks--
IndyDave
A search of the 1958-67 beetle forum for "Semaphore Switch" and "Titles Only" box checked:
https://www.thesamba.com/vw/forum/search.php?searc..._chars=200 _________________ In Stereo, Where Available! |
Posted: Sat Jul 13, 2019 5:54 pm Post subject: Re: '58/'59 Beetle Discussion |
Thanks Eric&Barb, having the correct term made the search more effective.
Thanks also Mukluk, I really appreciate your efforts with the part number.
I can't find the switch anywhere.
I'm planning to use the 6-wire switch from WW combined with LED taillights & parking lights from Chip Birks, along with flasher relays. I usually prefer the original look, but other drivers don't seem to understand the semaphores.
It won't look too original if I get smashed by a giant SUV, and this is a way to get a flashing light in the front without adding fender signals. |
Chase1 Samba Member
Joined: January 26, 2004 Posts: 28 Location: DC Metro
Posted: Wed Sep 18, 2019 1:25 pm Post subject: Re: '58/'59 Beetle Discussion |
IndyDave wrote: |
I have a '58 with semaphores and have an extra 3 wire switch with no strap laying around, as I had to find a complete replacement from the Netherlands (https://www.kieftenklok.nl/shop/index.php/en/). Like you, I was going to switch over to Chip's LEDs with blinkers but the previous owner already switched over to LEDs. Instead, I installed the flashing LEDs for the semaphores. I will eventually add another circuit to the taillights as I agree with your assessment about other drivers.
Good luck. _________________ This we'll defend. |
Dibaltic Samba Member
Joined: May 06, 2007 Posts: 564 Location: Chambersburg, Pennsylvania
Posted: Fri Sep 20, 2019 6:40 pm Post subject: Re: '58/'59 Beetle Discussion |
Okay so I have an April of '59 and my Dad has a June of '59 Beetle. His car had steering box 311 415 131 and mine had steering box 111 415 131. Which steering box is correct for the 58/59 models or are both steering box models we have correct for the car?
This one off of April '59 car
This one off of June of '59 car
cab57 Samba Member
Posted: Fri Sep 20, 2019 11:18 pm Post subject: Re: '58/'59 Beetle Discussion |
I have the same steering box like you on my beetle 59 from april (european model). The date stamped on this box is 18/03/59
_________________ Beetle convertible built 06/66
Beetle ragtop built 28/04/59 |
Posted: Sat Sep 21, 2019 4:51 am Post subject: Re: '58/'59 Beetle Discussion |
I didn't even think to look at the date stamps! My steering box is Jan 28 59 his is Nov 5 62 so it must of been replaced at some point. |
anteatereater Samba Member
Posted: Sat Sep 21, 2019 9:25 am Post subject: Re: '58/'59 Beetle Discussion |
Hi all, I've recently moved from my old 65 into this running and driving all original 58 Canadian custom(Canadian standard). I've just been going over things and after running my engine code it's coming up as 1955. So I'm guessing it's not the original motor unless they tossed these old ones in the super basic model that these Canadian customs are. Either was that doesn't really matter much as it's running quite well for what it is. My question is though is there a way to tell if it's the 25hp or the 36hp?
Posted: Sat Sep 21, 2019 10:16 am Post subject: Re: '58/'59 Beetle Discussion |
anteatereater wrote: |
My question is though is there a way to tell if it's the 25hp or the 36hp?[/img] |
If you mean size of engine, then remove a head to measure piston size and stroke.
If you mean if the exterior parts are 25 HP, would look up parts numbers in the part manuals here:
http://www.oacdp.org/
The 1970s printed type 1 parts manual is available thru the "Upcoming" button at upper right.
The earlier type 2 manual is also a great reference for the type 1 due to using almost the same engine parts as the type 1, with main exceptions of the air cleaner and muffler. Plus does not have the all the later parts to wade thru as the afore mentioned type 1 parts manual.
Even if your engine case is 1955 production, it could easily have been bored (and the heads) open to accept the later 36 HP P&Cs. On other hand it could be a 25 or 36 HP replacement engine case that the original 1955 engine case numbers was stamped into. Original 25 HP engine cases do not have the oil filler bolt mount cast into it. _________________ In Stereo, Where Available! |
stale air Samba Member
Joined: August 23, 2007 Posts: 5154 Location: Senoia Ga, formally NorCal
Posted: Sat Sep 21, 2019 10:56 am Post subject: Re: '58/'59 Beetle Discussion |
Hi all, I've recently moved from my old 65 into this running and driving all original 58 Canadian custom(Canadian standard)?
Always great to see another L245 car! _________________ WANTED: Henry Veale Santa Rosa plate frames
Posted: Sat Sep 21, 2019 2:19 pm Post subject: Re: '58/'59 Beetle Discussion |
Eric&Barb wrote: |
Even if your engine case is 1955 production, it could easily have been bored (and the heads) open to accept the later 36 HP P&Cs. On other hand it could be a 25 or 36 HP replacement engine case that the original 1955 engine case numbers was stamped into. Original 25 HP engine cases do not have the oil filler bolt mount cast into it. |
thanks for that info, my case does not have the oil filler mount bolt as that's something i noticed right away. I was told today that the 25horse only went up to 1953, do you know if that's correct? seems contradicting now to what you said about the 25hp case not having the oil filler bolt mount though. |
Posted: Sat Sep 21, 2019 3:44 pm Post subject: Re: '58/'59 Beetle Discussion |
stale air wrote: |
Always great to see another L245 car! |
what does L245 signify? is that the model? |
smeag Samba Member
Joined: May 17, 2019 Posts: 70 Location: Cooper City, FL
Posted: Sat Sep 21, 2019 5:20 pm Post subject: Re: '58/'59 Beetle Discussion |
paint code |
EverettB Administrator
Joined: April 11, 2000 Posts: 69828 Location: Phoenix Metro
Posted: Sat Sep 21, 2019 6:40 pm Post subject: Re: '58/'59 Beetle Discussion |
It's a Jan. 1955 engine, it's 36hp. _________________ How to Post Photos
Posted: Sat Sep 21, 2019 7:50 pm Post subject: Re: '58/'59 Beetle Discussion |
Yes thanks, i actually just realised that after i posted. light bronze, Same color of the 58 my Opa had back then. |
Posted: Sat Sep 21, 2019 7:52 pm Post subject: Re: '58/'59 Beetle Discussion |
EverettB wrote: |
It's a Jan. 1955 engine, it's 36hp. |
Prefect, thanks. |
