deltabrent Samba Member
Posted: Fri Apr 12, 2019 11:29 am Post subject: Reduction box cruising engine. |
I posted a question in the engine forum awhile ago about building an engine and it got really confusing really fast. I have several engine, carbs, parts, pieces and most of what I need to build an engine for my 62 bus with Reduction Boxes. I want a good reliable cruising engine that isn't going to break a land speed record, require advanced building skills and won't break the bank.
I have a 1500cc that needs a crank grind, a couple other single ports in unknown condition, a 1600DP I haven't looked at, a Zenith NDIX, 2 Bug sprays, 3 early Bosch mechanical Distributors and lots of other smaller parts.
Whats a good no machining required torquey engine I could put together that a new builder could cobble together? (I"m not going to build a 2000cc+ dual carb, super engineered engine!) |
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Fri Apr 12, 2019 12:15 pm Post subject: Re: Reduction box cruising engine. |
I liked my 1600 single port I had in my SC with big nut RGBs. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Fri Apr 12, 2019 1:46 pm Post subject: Re: Reduction box cruising engine. |
Culito wrote: |
I liked my 1600 single port I had in my SC with big nut RGBs. |
This is exactly what I'm considering putting in my '59 SC. Stock big-nut and a single-port 1600 from our Thing. How was it on hills vs. flat-land? _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Erik G Samba Member
Posted: Fri Apr 12, 2019 2:05 pm Post subject: Re: Reduction box cruising engine. |
62DoKaGuy wrote: |
Culito wrote: |
This is exactly what I'm considering putting in my '59 SC. Stock big-nut and a single-port 1600 from our Thing. How was it on hills vs. flat-land? |
I daily drove mine from sacramento to the motorcycle shop that used to be on 49 in auburn. I did fine around sacramento, would have to floor it getting close to auburn on the freeway to get up, but then once in auburn driving around at normal speeds was fine. It's the "get around the slow vw" mentality other people have that will get you. _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Fri Apr 12, 2019 2:14 pm Post subject: Re: Reduction box cruising engine. |
Erik G wrote: |
62DoKaGuy wrote: |
Culito wrote: |
I daily drove mine from sacramento to the motorcycle shop that used to be on 49 in auburn. I did fine around sacramento, would have to floor it getting close to auburn on the freeway to get up, but then once in auburn driving around at normal speeds was fine. It's the "get around the slow vw" mentality other people have that will get you. |
Perfect, you know what hills I meant! Going up towards Auburn and then out 50 East to Placerville...and beyond. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
4/62 Double Cab
5/61 Panel (sold)
Culito 11010101
Posted: Fri Apr 12, 2019 3:20 pm Post subject: Re: Reduction box cruising engine. |
Mine was fine on the flats but big hills were 40-ish mph (sometimes top of 3rd gear) while giving apology waves to the people behind / passing me.
It's the VW way...
Also why I'm building a 2.0L type 4. _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Fri Apr 12, 2019 4:06 pm Post subject: Re: Reduction box cruising engine. |
Culito wrote: |
It's the VW way...
Also why I'm building a 2.0L type 4. |
Just go bay and build a 2.3
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Fri Apr 12, 2019 4:08 pm Post subject: Re: Reduction box cruising engine. |
This was so reasonable and straightforward. Thanks. I instantly was overwhelmed with endless custom ideas on the engine thread. No offence to them but I was lost. Maybe I'll sell the NDIX to fund a crank grind and just rebuild the 1500, put a 30pict1 on there (I like those), maybe a bit more interesting cam and a simple header exhaust. |
Manfred58sc Samba Member
Posted: Fri Apr 12, 2019 4:19 pm Post subject: Re: Reduction box cruising engine. |
I love a 1500 with OG P@C, cool running, plenty of torque, PICT 30-1, 009, some type of free flow exhaust. Everything just lines up perfect,reliable,durable. Roll an enormous fake spliff and have it hanging out of your mouth as people pass you and wave weakly.... _________________ Fat chick owner/operator |
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Fri Apr 12, 2019 5:19 pm Post subject: Re: Reduction box cruising engine. |
Erik G wrote: |
62DoKaGuy wrote: |
Culito wrote: |
What distributor are y’all using? |
Culito 11010101
Posted: Fri Apr 12, 2019 5:59 pm Post subject: Re: Reduction box cruising engine. |
zozo wrote: |
Erik G wrote: |
62DoKaGuy wrote: |
Culito wrote: |
I used a Bosch 010 with a H30/31. Good combo. Have that on my bug, too. _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Sat Apr 13, 2019 9:22 am Post subject: Re: Reduction box cruising engine. |
Bruce Amacker wrote: |
1600DP
New Chinese counterweighted crank
CB 2280 cheater cam
Whatever carb you like, I'd do a 34Pict. I have another engine with a 32NDIX but I like simplicity, the throttle linkage setup on that was not simple.
I've run several different SP and DP engines in busses, I'll never do a SP again. |
I have had much good luck with a stock 1600 SP and big nut trans. I have also run many miles with a similarly set up DP. Curious about your SP issues.
Balancing is the key. Make things smooth while spinning, and everything just works better. _________________ nothing |
Posted: Sat Apr 13, 2019 11:19 am Post subject: Re: Reduction box cruising engine. |
I have a small nut reduction box setup. I think? Isn't that whats in a 62? I'm guessing it doesn't make a huge difference? |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sat Apr 13, 2019 12:04 pm Post subject: Re: Reduction box cruising engine. |
deltabrent wrote: |
At 60 mph your engine would spin close to 275 RPMs less if you changed just your small nut reduction boxes to big nut reduction boxes. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Sat Apr 13, 2019 12:37 pm Post subject: Re: Reduction box cruising engine. |
Joey wrote: |
deltabrent wrote: |
At 60 mph your engine would spin close to 275 RPMs less if you changed just your small nut reduction boxes to big nut reduction boxes. |
A slightly taller tire would have a similar effect, if available. _________________ nothing |
Posted: Sat Apr 13, 2019 5:22 pm Post subject: Re: Reduction box cruising engine. |
I just rebuilt my reduction box rear end. I'm not switching it out. |
Erik G Samba Member
Posted: Sat Apr 13, 2019 5:31 pm Post subject: Re: Reduction box cruising engine. |
deltabrent wrote: |
you'll be much happier at 60mph with small nut redux boxes. Big nuts are comfortable at 65 _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Sat Apr 13, 2019 5:35 pm Post subject: Re: Reduction box cruising engine. |
Erik G wrote: |
deltabrent wrote: |
you'll be much happier at 60mph with small nut redux boxes. Big nuts are comfortable at 65 |
Agreed. _________________ nothing |
