unclebilly Samba Member
Posted: Wed Apr 10, 2019 8:16 pm Post subject: Firewall mount rear bumper from cracking my firewall |
My firewall mount rear bumper has cracked my firewall at both mounts. I’m going to fish plate this, probably on the inside this and run the plate across the firewall.
I can’t be the only one with this issue.
How have you prevented this (apart from installing a cage and putting the pickup points there)? |
dustymojave Samba Member
Posted: Wed Apr 10, 2019 8:31 pm Post subject: Re: Firewall mount rear bumper from cracking my firewall |
By connecting the inside plates to the back bars of the roll cage. That's the ONLY way to prevent making holes and cracks in the firewall.
Aside from connecting the bumper to the cage, I hate firewall mount bumpers.
And NOPE, you are NOT the only one around here who's had that trouble. Like Ricosuave. He just about tore the whole back of the body out. _________________ Richard
SoCalBajas Member
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Apr 11, 2019 7:12 am Post subject: Re: Firewall mount rear bumper from cracking my firewall |
Bumper should connect to chassis/cage... Putting bumper to fiberglass is like mounting bumper to a potato chip...
OOPS!.... Misread firewall for fiberglass....
Posted: Thu Apr 11, 2019 8:38 am Post subject: Re: Firewall mount rear bumper from cracking my firewall |
The firewall is steel (it’s the factory stamped steel).
My car has no cage. And I didn’t want to cage it. If I put in a Roll Bar, it will limit the use of the back seat which was a big reason I got a baja over a side by side.
I guess I will have to come up with something. Maybe I can triangulate the inside of the firewall down to the floor behind the rear seats. I guess I could tie shoulder harnesses into this too... |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
cbeck Samba Member
Posted: Thu Apr 11, 2019 5:21 pm Post subject: Re: Firewall mount rear bumper from cracking my firewall |
very lite hit. notice oil under push rods.
2 small dents in the ram truck. Took out frame and motor.
_________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Posted: Thu Apr 11, 2019 9:13 pm Post subject: Re: Firewall mount rear bumper from cracking my firewall |
Multi69s wrote: |
Instead of reinventing the wheel and to go through a hell of a lot of work. I would go with a different bumper. One that connects to the shock area. That's what I have always used. In fact I was rear ended with this setup. On my car it mutilated the license plate and its light. The other car, thousands of dollars in damage. |
Do you have a picture of your setup? |
YDBD Samba Member
Joined: February 25, 2017 Posts: 891 Location: Bavaria, Germany
Posted: Fri Apr 12, 2019 2:19 am Post subject: Re: Firewall mount rear bumper from cracking my firewall |
When I got my '64 baja it was one of the first things I removed and went with the shock mounted.
here is the one mounted on my dune buggy:
_________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
Posted: Fri Apr 12, 2019 5:16 pm Post subject: Re: Firewall mount rear bumper from cracking my firewall |
The shock tower mount bumper multi69s is talking about and shown bent on the back of cbeck's Baja is available as the standard EMPI shock mount bumper. Check your friendly (internet) neighborhood VW supply house for bumpers. Also available with 2 cross tubes.
I had one on my Baja for many years when my dad owned it.
That one was made by Hobrecht company who have not been around for years. But the design is imitated and carried on by EMPI. They added a pair of side bars for a little more engine protection. _________________ Richard
SoCalBajas Member
Posted: Fri Apr 12, 2019 8:06 pm Post subject: Re: Firewall mount rear bumper from cracking my firewall |
I’m going to see if I can modify mine to be shock mount. It should just be a modification of the top tube. Thank you for all of the info and photos. |
