Vargus Samba Member
Posted: Thu Apr 11, 2019 2:48 pm Post subject: Air shocks for a 1960 23 window |
I need to be able to raise and lower my bus. The spindles have been flipped. Has anyone used Gabriel air shocks on the front and back to raise or lower a bus.
Thanks Dan |
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Thu Apr 11, 2019 6:07 pm Post subject: Re: Air shocks for a 1960 23 window |
https://www.thesamba.com/vw/forum/viewtopic.php?t=66927 _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
EmpiGT Samba Member
Posted: Thu Apr 11, 2019 6:35 pm Post subject: Re: Air shocks for a 1960 23 window |
I'm not sure the thread Thom posted will help you much on the subject. I would only use air shocks to temporarily raise a bus. If your bus is lowered with a straight axle, the shocks will fight against the torsion of the springs front and rear (depending on how high), so the ride will be really rough. And if running no gear reduction boxes, raising it too much in the rear, your camber will be very bad and dangerous.
But if you keep the raise sensible and use it to just raise for clearance on occasion you should be fine. |
don.ville Samba YardMan
Joined: February 07, 2008 Posts: 2829 Location: West Palm Beach, FL
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Fri Apr 12, 2019 6:54 am Post subject: Re: Air shocks for a 1960 23 window |
I think you need to explain for what purpose do you need to temporarily raise the bus.
Air shocks will raise it a certain amount as already explained, however you need access to air pressure. So, doing this on the daily ( like a crappy driveway ) means you need an air compressor and tank in the bus. Also, air shocks have small air lines, unlike true air ride, and the lift will be slow.
Perhaps in the rear you could take out the bump stop and install Firestone air assist springs. They are similar to the ones used on pick-ups that carry campers.
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13269 Location: Tejas!
Posted: Fri Apr 12, 2019 8:26 am Post subject: Re: Air shocks for a 1960 23 window |
If you do, the front shocks have to be mounted upside down, they rub otherwise.
they will all have to be drilled and tapped for larger lines. out of the box they are not strong enough to lift. Also agree with what empigt said, had a friend that bought a bus with them on, pretty useless to be honest. he ditched all of it
I tried with the rear of a bug a long time ago, doesn't work... _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Vargus Samba Member
Posted: Sat Apr 13, 2019 8:22 pm Post subject: Re: Air shocks for a 1960 23 window |
I want to be able to raise the bus about one to two inches. I am not happy with the fact that the front tires are rubbing when turning or when I have four people in the bus. I will want to carry 8 people at certain times. Currently there is no way the bus will take the weight and not rub.
Thanks
Vargus Samba Member
Posted: Sat Apr 13, 2019 8:24 pm Post subject: Re: Air shocks for a 1960 23 window |
I also have read that Gabriels will fit without a modification. |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2171 Location: Graz, Austria, Europe
Posted: Sun Apr 14, 2019 12:26 am Post subject: Re: Air shocks for a 1960 23 window |
remember they put additional strain on parts that were not intended to carry the load, such as mounting studs on trailing arms, upper frt axle threads aso.
I used gas shocks in the frt of an oval beetle and they helped raise it about 3/4"along with a little stiffer ride. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Erik G Samba Member
Posted: Sun Apr 14, 2019 4:47 pm Post subject: Re: Air shocks for a 1960 23 window |
your bus isn't so low that it cant carry people, your front tires are pretty big for a lowered bus though
what beam? just spindle flip? what size tires do you have? front and rear. where is the rub, just the front? you may be able to just get by with smaller front tires _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Sun Apr 14, 2019 5:08 pm Post subject: Re: Air shocks for a 1960 23 window |
Now you know why people go with a narrower beam.
If you look above the front tire you will see The fender has more vertical room for travel the closer the front tires are to the center. _________________
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
Vargus Samba Member
Posted: Mon Apr 15, 2019 9:08 am Post subject: Re: Air shocks for a 1960 23 window |
The front and rear tires are 195s. Stock front beam with only flipped spindles. |
Vargus Samba Member
Posted: Mon Apr 15, 2019 9:09 am Post subject: Re: Air shocks for a 1960 23 window |
The tires rub when four or more people are in the bus and when the bus is turning. |
