My first tow - ABA won't start [still not solved]
Page: 1, 2, 3, 4, 5  Next
Paulbeard
Paulbeard is offline
PostPosted: Sun Apr 14, 2019 4:37 pm    Post subject: My first tow - ABA won't start [still not solved] Reply with quote
Waiting for the AAA operative to give me a 1 mile tow. Somehow got a no spark situation that I’ll have to sort out. According to https://www.aa1car.com/library/ignition_coils.htm i have an open coil. I can smell fuel so I feel like that’s working. No way to test at the plug with the tools I have.
I think water got somewhere it shouldn’t when I was degreasing and looking for an oil leak. It ran really poorly, progressively worse before dying altogether. Battery is strong even after extended cranking. Tips and tricks welcome.
Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
Git 'r DONE!
— dhaavers
djkeev
djkeev is offline
PostPosted: Sun Apr 14, 2019 4:39 pm    Post subject: Re: My first tow Reply with quote
Wet wires or water in your distributor cap most likely. Maybe the Hall sender connector?
Dave
Ghia
Vanagon
Beetle
tjet Premium Member
tjet is offline
PostPosted: Sun Apr 14, 2019 4:45 pm    Post subject: Re: My first tow Reply with quote
Don't assume fuel pump is functioning normally if you can smell raw fuel. My fuel pump failed on a road trip. The thing that threw me off was that I assumed is was good because I could smell fuel & the engine was exhibiting a rich-running condition. I threw everything I had at it. ECU, AFM, FPR, throttle body, coil, hall pickup, cap.....
https://www.thesamba.com/vw/forum/viewtopic.php?t=664204&highlight=
Paulbeard
PostPosted: Sun Apr 14, 2019 5:57 pm    Post subject: Re: My first tow - won't start Reply with quote
More time hooking/unhooking for a less than one mile tow…
Something water-y seems likely. I had a similar situation another time coolant gushed out…I'll take up the advice offered and see what I can learn. Is there way to test for spark with just one person? I can't reach that far if I need to see the plug or test light.
Git 'r DONE!
— dhaavers
Paulbeard
PostPosted: Sun Apr 14, 2019 6:28 pm    Post subject: Re: My first tow - won't start Reply with quote
Just took another look…the Hall effect sender looks fine, the wires are intact. No sign of water. It's behind the distributor so maybe didn't get any coolant on it.
This doesn't look right to me:
I have two like this. So I guess plugs are something I need. What's recommended there?
Git 'r DONE!
— dhaavers
Abscate
Abscate is offline
PostPosted: Sun Apr 14, 2019 6:36 pm    Post subject: Re: My first tow - won't start Reply with quote
Yep, those connectors have snapped off. Get all,plugs out and put a new set in and you will Bee all set.
What brand were the old ones?
.ssS!
Paulbeard
PostPosted: Sun Apr 14, 2019 6:57 pm    Post subject: Re: My first tow - won't start Reply with quote
Looks like NGK which I just ordered from my FLAPS. VanCafe offers those or a Bosch but FLAPS only had the NGKs. I doubt this is my problem but it sure ain't helping…
Git 'r DONE!
— dhaavers
tjet Premium Member
tjet is offline
PostPosted: Sun Apr 14, 2019 7:07 pm    Post subject: Re: My first tow - won't start Reply with quote
You can burn out the coil if the spark is forced to make a jump other than where it's supposed to.
Ahwahnee
Ahwahnee is offline
PostPosted: Sun Apr 14, 2019 7:15 pm    Post subject: Re: My first tow - won't start Reply with quote
Paulbeard wrote:
...This doesn't look right to me:
Does the socket on your spark plug wrench have the foam insert? Doesn't look important but if it isn't there it is easy to snap off a plug.
Paulbeard
PostPosted: Sun Apr 14, 2019 7:17 pm    Post subject: Re: My first tow - won't start Reply with quote
That was just from pulling the wire off… ¯\_(ツ)_/¯
Maybe they require a more gentle touch than I used, though they didn't all break.
Git 'r DONE!
— dhaavers
kamzcab86
kamzcab86 is offline
PostPosted: Sun Apr 14, 2019 8:37 pm    Post subject: Re: My first tow - won't start Reply with quote
[pic]
You might want to add your photo to the official tow topic: https://www.thesamba.com/vw/forum/viewtopic.php?t=481782 . Wink
As for the plugs, I highly recommend cleaning the debris out from around the plugs before unscrewing them. Don't want that junk falling into the engine. Confused
And a reminder to be sure to remove the screw-on terminal cap before installing the new plugs.
~Kamz Anxious
2016 Golf GTI S
Paulbeard
PostPosted: Sun Apr 14, 2019 8:52 pm    Post subject: Re: My first tow - won't start Reply with quote
See pg 9…different image, same incident.
Yeah, all that rat exhaust or whatever it is will be cleared away. I wish I had access to power so I should blow it away with a shop vac. A little leery of washing it away with water.
Git 'r DONE!
— dhaavers
kamzcab86
PostPosted: Sun Apr 14, 2019 8:58 pm    Post subject: Re: My first tow - won't start Reply with quote
It's an added expense ($5-10, depending on the store), but there are cans of compressed air you can buy. Office supply stores and many home improvement stores carry them.
~Kamz Anxious
2016 Golf GTI S
Abscate
Abscate is offline
PostPosted: Mon Apr 15, 2019 3:23 am    Post subject: Re: My first tow - won't start Reply with quote
Put a soccer ball fitting on your hand pump and it’s an instant shop air blast.
You have To coordinate the quick hand pump with the holding of the tip in the right place but a bit of practice makes perfect
.ssS!
?Waldo?
?Waldo? is offline
PostPosted: Mon Apr 15, 2019 8:35 am    Post subject: Re: My first tow - won't start Reply with quote
Spark plugs should be able to withstand pulling off the plug wires even if you are not particularly gentle in the process.
When asking for recommendations on engine specific parts (like sparkplugs), you might want to clarify that this is an inline-4 and not a WBX engine.
Paulbeard
PostPosted: Mon Apr 15, 2019 5:07 pm    Post subject: Re: My first tow - won't start Reply with quote
I thought as much. Somewhat surprised to see these fail in this way.
Fair point. I am just going with what's in there now to get things restored to whatever can pass as normal.
Git 'r DONE!
— dhaavers
Paulbeard
PostPosted: Mon Apr 15, 2019 5:28 pm    Post subject: Re: My first tow - won't start Reply with quote
Got new plugs today at FLAPS. Just blew out the crap around the old ones (Kam's canned air solution, FTW) and applied a dab of PBlaster to make sure they come out.
Tested the coil across the terminals and it shows 0 resistance. An open coil. Eso es no bueno. So I guess I need one of those as well. The label on this one is too tatty to make out. I'll see what FLAPS recommends for a MkIII Jetta Vanagon. The Jetta ones don't look remotely similar.
Git 'r DONE!
— dhaavers
fxr
fxr is offline
PostPosted: Mon Apr 15, 2019 6:06 pm    Post subject: Re: My first tow - won't start Reply with quote
Do you mean zero resistance (a short) or infinite resistance (open circuit)? There's a huge difference. Wink
An open coil..
That depends on your answer to the above question...
Jim Crowther
Vespa GTS 300
Paulbeard
PostPosted: Mon Apr 15, 2019 6:13 pm    Post subject: Re: My first tow - won't start Reply with quote
Yeah, I'm wondering about that now as I read up more on this. To be clear, the result is the same as crossing the leads together.
Just read through this and realize my tests and resulting understanding are incomplete.
This — "A failed ignition coil can show up in several ways, ranging from noticeable decreases in power and fuel mileage to severe engine misfires that can sometimes render the vehicle undrivable" — seems like I am on the right track. There was a lot of bogging and slow pickup as well as a few backfires.
Git 'r DONE!
— dhaavers
fxr
fxr is offline
PostPosted: Mon Apr 15, 2019 6:19 pm    Post subject: Re: My first tow - won't start Reply with quote
A good test, that I always do before measuring resistance, as most cheapo meters won't read actual zero when the probes are connected together! However, what range was your multimeter set to? I hope to the most sensitive range (usually 200 ohms full scale for the cheapies) - as the primary of the coil is only a few ohms, and if on any other range you won't get any sensible reading.
Learning can be fun. Smile Possible one reason we all seem to like our Vans - there's always something to figure out from scratch. Smile
Jim Crowther
Vespa GTS 300
Page 1 of 5
