Sodo Samba Member
Joined: July 06, 2007 Posts: 9603 Location: Western WA
Posted: Mon Apr 15, 2019 10:03 pm Post subject: How to change Truckfridge door panel (with pics) |
It's fairly easy to change the panel on the truckfridge door.
From a 2018 thread: DIY installation of laminate panel into door of TruckFridge TF49
Sodo wrote: |
Howesight wrote: |
It is Formica product Number 927-58. The name of the colour is "Folkstone" and it is in the matte finish. Home Depot can order it for you. |
30x96 sheet is $33 at HomeDepot, free delivery to the store. I might buy a sheet, does anyone in Seattle need some? |
Heres some pics with notes.
Sorry they are not in sequence, but I think they show the details that you need to know.
1) Remove the door by removing the lower hinge. The screws are on the bottom pointing up, so you may have to pull the fridge completely out. There are 4 screws, I removed 3 of them, just enough to tip the hinge down and disengage the door.
2) Pry the bottom strip off. It's hard to see where to pry, but just jam a screwdriver or knife into the second groove (where you see it in the pic). Slide the lower trim off. This lets the door panel slide out of the door.
3) Mark your holes for the latch. I did it by carefully marking the latch position but it's simpler to use your old panel as a template. The holes can be large clearance holes because the latch will cover them.
I didn't take pics of the template method but you prob don't need pics, right?.....
4) reassemble in reverse order
....KTMs, GasGas, SPOT mtb |
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Tue Apr 16, 2019 5:27 am Post subject: Re: How to change Truckfridge door panel (with pics) |
Nice job! Not something I’d have thought to document. _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
Sodo Samba Member
Posted: Tue Apr 16, 2019 8:19 am Post subject: Re: How to change Truckfridge door panel (with pics) |
JudoJeff wrote: |
Nice job! Not something I’d have thought to document. |
Seems like nobody else has either, but theres a lot of Truckfridges in Vanagons and I bet some of the owners would like to change the panel.
Some just need a few pics, or the inspiration. _________________
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Tue Apr 16, 2019 3:47 pm Post subject: Re: How to change Truckfridge door panel (with pics) |
Sodo, you rock! Thanks for the pictorial. Even though I did my TF65 many years ago, I forgot how the trim came apart. Nice post! _________________ '86 Syncro Westy SVX |
2dogs1van Samba Member
Posted: Tue Apr 16, 2019 5:33 pm Post subject: Re: How to change Truckfridge door panel (with pics) |
Sodo did this for me on Sunday. It looks so much better. Can't thank you enough Sodo. You're the best! |
koubiak Samba Member
Posted: Sat May 16, 2020 6:17 pm Post subject: Re: How to change Truckfridge door panel (with pics) |
Thanks for the pictures. I am preparing the install of the fridge. and that was super easy to insert a nice laminate.
Looks so much better now
Now I need to finish procrastinating and finish the electricity for my second battery. |
jasonpap2002 Samba Member
Joined: December 18, 2012 Posts: 129 Location: Austin, Texas
Posted: Sun Sep 13, 2020 4:05 pm Post subject: Re: How to change Truckfridge door panel (with pics) |
This was very helpful to me - great post and thank you!
~Jason |
