Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Tue Apr 16, 2019 6:52 pm Post subject: Brake woes |
So over the last couple months ive replaced the rubber hoses with braided ss, new shoes and wheel cylinders, new master cylinder and the front hard likes today since one was leaking. Everything bled great with shoes adjusted all the way out to the drums no bubbles when done and shoes adjusted. Brake pedal moves 3inches before any braking takes place, I've adjusted the push rod to 5mm at the top of the pedal. Only thing I can think of is bad front drums.[/u] |
YDBD Samba Member
Joined: February 25, 2017 Posts: 891 Location: Bavaria, Germany
Posted: Tue Apr 16, 2019 8:54 pm Post subject: Re: Brake woes |
Could be...somewhere on the drum is the max diameter in raised numbers. If you take it to a brake shop they can mic it for you.
When you say all the way out you did adjust both stars the right way? I usually adjust each one until the drum can't be turned, then back of two or three clicks and do the other star and then back it off. The wheel should be able to spin but only about one revolution if you spin it hard. _________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
Posted: Tue Apr 16, 2019 9:00 pm Post subject: Re: Brake woes |
YDBD wrote: |
When you say all the way out you did adjust both stars the right way? I usually adjust each one until the drum can't be turned, then back of two or three clicks and do the other star and then back it off. The wheel should be able to spin but only about one revolution if you spin it hard. |
Yeah, first I locked the shoes to the drum and bled the system. Then I adjusted them till they dragged just a bit. |
YDBD Samba Member
Posted: Tue Apr 16, 2019 10:44 pm Post subject: Re: Brake woes |
pull the drum off and step on the pedal to check wheel cylinder movement?
If they are dragging the wheel cylinder should push out enough to engage fairly quickly. _________________ '56 pan Dune Buggy since '69
'67 bug
'64 baja
'60 dune buggy
Posted: Tue Apr 16, 2019 11:01 pm Post subject: Re: Brake woes |
YDBD wrote: |
If they are dragging the wheel cylinder should push out enough to engage fairly quickly. |
Easier said then fine when your alone lol. I have some brakes for now and I'll try to find someone to help push the pedal. |
sicksforeveedub Samba Member
Joined: August 28, 2008 Posts: 68 Location: Central CA
Posted: Wed Apr 17, 2019 5:26 am Post subject: Re: Brake woes |
When you replaced the wheel cylinders, did you go with original sizes? I have a similar issue, and it took me a while to realize that my huge (super beetle front) wheel cylinders on my type 3 rear conversion take so much fluid to move that the pedal has to travel that much further. Just a thought. _________________ "...What, like the back of a Volkswagen?" |
Posted: Wed Apr 17, 2019 12:29 pm Post subject: Re: Brake woes |
sicksforeveedub wrote: |
When you replaced the wheel cylinders, did you go with original sizes? I have a similar issue, and it took me a while to realize that my huge (super beetle front) wheel cylinders on my type 3 rear conversion take so much fluid to move that the pedal has to travel that much further. Just a thought. |
Yes I did. |
