amyshannon Samba Member
Posted: Wed Apr 17, 2019 11:59 am Post subject: torque spec for front caliber bracket bolt? |
Anyone have proper torque spec? it was on dam tight.....info I am getting from google search is all over the place from 115 to 225 |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Mon Apr 22, 2019 4:16 am Post subject: Re: torque spec for front caliber bracket bolt? |
Year and model car helps a lot on these requests, since this forum covers T4, T5, T6 with chassis breaks, too.
For my 2002 T4 it’s 280Nm
I lube the crap out of them and set them to 180Nm _________________ .ssS! |
Posted: Mon Apr 22, 2019 6:50 am Post subject: Re: torque spec for front caliber bracket bolt? |
Abscate wrote: |
I lube the crap out of them and set them to 180Nm |
It is a 2002 Eurovan MV weekender |
Posted: Mon Apr 22, 2019 1:12 pm Post subject: Re: torque spec for front caliber bracket bolt? |
amyshannon wrote: |
Abscate wrote: |
YEah, but what colour is it? Colorado Red?
Same year and model as mine - see torque spec above (from Alldata)
I live in the salty Northeast so I lube everything, which reduces required torque for tightening. _________________ .ssS! |
garthg Samba Member
Joined: January 22, 2015 Posts: 10 Location: New Jersey
Posted: Fri Apr 26, 2019 8:33 am Post subject: Re: torque spec for front caliber bracket bolt? |
amyshannon wrote: |
It's 355Nm/261 foot lbs, for the large brakes with 16" wheels. This is from the factory manual.
I don't have a torque wrench that goes that high (only 250 ft-lbs), so I just use a 25" breaker bar with 27mm socket, and tighten it as much as I can.
I have a set of new bolts that I'll be using on the next brake job. $8 each at VW. |
Posted: Fri Apr 26, 2019 5:42 pm Post subject: Re: torque spec for front caliber bracket bolt? |
The brake caliper bolt on mine is not 27mm socket size.
Are we on the same page of the manual as OP? _________________ .ssS! |
garthg Samba Member
Posted: Sat Apr 27, 2019 6:39 am Post subject: Re: torque spec for front caliber bracket bolt? |
Abscate wrote: |
Are we on the same page of the manual as OP? |
VW used several different brake calipers, using Lucas, Ate and others.
My Eurovan is 2002, late model, brakes referred to in the manual as "FNR" for 16" wheels. Brake disc diameter is 313mm.
The bolts are definitely 27mm; I just double-checked the replacement bolts. I also remember that's what the originals are also, because I cracked an impact socket trying to remove them in the first instance.
The torque spec is 355Nm. I've attached a screen grab of the manual.
And to the OP, I would add that you shouldn't be "lubing" the brake caliper bracket bolts. Those are the last bolts on the car that you would want to come loose.
Posted: Sun Apr 28, 2019 7:59 am Post subject: Re: torque spec for front caliber bracket bolt? |
garthg wrote: |
Abscate wrote: |
Garth, thanks for the primary reference post back. Good reminder to me that sourcing parts is not a year / model game any more. _________________ .ssS! |
