busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Apr 23, 2019 6:33 pm Post subject: Re: The Stupid Question Thread |
a-marshal wrote: |
Still trying to figure out how carbs work and am now wondering about idle cut off circuits. My carbs have them but it seems as though the replacement part is a simple jet without the solenoid, what is the difference between the solenoid version and the simple replacements? What benefit is the solenoid?
Following up to that question the cutoffs are marked 52.5 and the simple replacements are (apparently) sold as either 50 or 55 .. so if I'm understanding things correctly if I replace the 52.5 with 55's I'll be enriching my idle mixture, causing my idle to increase and I will have to turn in the volume screws to bring it down to 900rpm again...I think ... I hope.. |
The electric cutoff prevents run on if you have some glowing carbon in a cylinder that continues combustion after you turn off the key, you can stall it with the clutch if it happens.
A 2.5 idle jet increase won't effect much, it mat even improve how it behaves with modern gas. You may have to adjust the idle mixture screws slightly to compensate. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
NorCalWeekender Samba Member
Joined: April 13, 2000 Posts: 6531 Location: East Bay, CA
Posted: Wed Apr 24, 2019 10:34 am Post subject: Re: The Stupid Question Thread |
So my bus has a few parts that have been painted over (shore power inlet, Volkswagen script on the back, etc) at least once (if not three times).
What's the best thing to get that paint off with these days? Easy-Off? Grafitti remover? Just sandblast the crap out of it?
Cheers, folks! _________________ 9th Owner of a 1971 Tintop Westy
"Eventually, we sold to a guy for $500 who towed it away to live in it in his parents' driveway. We didn't think it would ever avoid the junk heap on that day." -The 3rd Owner, 1995 |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Wed Apr 24, 2019 10:44 am Post subject: Re: The Stupid Question Thread |
NorCalWeekender wrote: |
Cheers, folks! |
If you have access to a media blaster then I'd go that route. I like to use glass beads because it leaves the metal smooth and makes for a great base for a primer or for powder coating. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Wed Apr 24, 2019 10:48 am Post subject: Re: The Stupid Question Thread |
ivwshane wrote: |
Cheers, folks! |
If you have access to a media blaster then I'd go that route. I like to use glass beads because it leaves the metal smooth and makes for a great base for a primer or for powder coating. |
I've a friend who has one, but not sure what media he's got in it. _________________ 9th Owner of a 1971 Tintop Westy
Manfreds78bay Samba Member
Posted: Wed Apr 24, 2019 12:55 pm Post subject: Re: The Stupid Question Thread |
Anyone install LED turn signals in a late bay have any trouble with them? I've installed the no load relay as well.
When i don't have my running or head lights on, they work fine.
When I turn on my running or head lights the front turn signals won't flash.
The rear turn signals work fine in both scenarios. _________________ 1978 2.0L FI Campmobile
1982 AMC Eagle SX4 4.2L FI |
Posted: Wed Apr 24, 2019 1:06 pm Post subject: Re: The Stupid Question Thread |
Manfreds78bay wrote: |
The rear turn signals work fine in both scenarios. |
Sounds like a ground issue to me. |
Posted: Wed Apr 24, 2019 1:22 pm Post subject: Re: The Stupid Question Thread |
Wildthings wrote: |
I replaced my turn signal housing on both sides. They worked as described with the old and the new housings. I'm not sure where the ground issue would be.
However, I do think the issue has more to do when the running lights are turned on. They share a ground. I may need to run separate grounds for each light. _________________ 1978 2.0L FI Campmobile
Posted: Wed Apr 24, 2019 1:40 pm Post subject: Re: The Stupid Question Thread |
Wildthings wrote: |
However, I do think the issue has more to do when the running lights are turned on. They share a ground. I may need to run separate grounds for each light. |
It wouldn't hurt. _________________ 9th Owner of a 1971 Tintop Westy
Posted: Fri Apr 26, 2019 10:57 am Post subject: Re: The Stupid Question Thread |
Anyone have a source or find something very similar to the late bay helsinki hinge that props the stove/sink lid open? _________________ 1978 2.0L FI Campmobile
notchboy Samba Member
Joined: April 27, 2002 Posts: 22449 Location: Escondido CA
Posted: Fri Apr 26, 2019 11:36 am Post subject: Re: The Stupid Question Thread |
Anyone have a source or find something very similar to the late bay helsinki hinge that props the stove/sink lid open? |
You mean Berlin? You have a Berlin floor plan. I have a set of the real hinges I could sell you for the cooker/sink. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Fri Apr 26, 2019 11:38 am Post subject: Re: The Stupid Question Thread |
notchboy wrote: |
You mean Berlin? You have a Berlin floor plan. I have a set of the real hinges I could sell you for the cooker/sink. |
PM sent _________________ 1978 2.0L FI Campmobile
Posted: Fri Apr 26, 2019 1:13 pm Post subject: Re: The Stupid Question Thread |
Got another stupid question. Who is a good source for access hatches? My PO hacked up the area over the gas tank sender. I've looked at jegs, amazon, etc and I can only find gas tank access hatches. I need something that is square. _________________ 1978 2.0L FI Campmobile
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Fri Apr 26, 2019 6:07 pm Post subject: Re: The Stupid Question Thread |
SamboSamba22 wrote: |
Anyone have leads or information on the proper jet sizes to get a Weber 32/36 running nicely (to the best it can for a single carb) on a 75 type 4 engine?
Currently running 50 and 55 idle jets. Air/fuel mixture screw doesn't seem to do much. |
Settle in for a long read: https://www.thesamba.com/vw/forum/viewtopic.php?t=217070&highlight=suck _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2329 Location: Southeast Kentucky
Posted: Sat Apr 27, 2019 3:18 pm Post subject: Re: The Stupid Question Thread |
Okay 002 Transmission Experts, I need some help.
I've disassembled three 3-rib transmissions, all late models (post-71/72).
Two of those transmissions had a rather thick shim (really a washer) behind the retaining nut on the Pinion Bearing (talking pinion & ring gear side of the case). One transmission never had this thick shim/washer.
The Bentley is not really clear on this. I know on the other side (gears side) there is a shim which is generally fairly thin and thickness depends on adjusting, etc.
Thoughts?
Edit: found the answer at Weddle's website..
Tech Tip: Around 1971 or 1972, VW started using a washer under the large pinion bearing retainer nut in Type 1 and Type 2 transaxles. This required a slight change to the design of the main case (to accommodate the 2mm thick washer). If you are not sure which type of case you have, you can use calipers to measure the thickness of the case at the pinion bearing bore. If the thickness is approximately 22.2mm (.875") a washer is required. If it is approximately 24.2mm (.950") a washer should not be used. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003.
Posted: Sat Apr 27, 2019 5:11 pm Post subject: Re: The Stupid Question Thread |
Does anyone have a picture or diagram on how this light is wired. My gut says something isn't wired right because doesn't the lens have two switches on it? I need to source that lens. _________________ 9th Owner of a 1971 Tintop Westy
CanStan Samba Member
Joined: October 16, 2005 Posts: 1037 Location: Calgary, AB
Posted: Sat Apr 27, 2019 6:34 pm Post subject: Re: The Stupid Question Thread |
Does anyone have a picture or diagram on how this light is wired. My gut says something isn't wired right because doesn't the lens have two switches on it? I need to source that lens. |
The cover should have 2 switches on it. 1 operates the outer 2 bulbs, and the other operates the middle bulb. Once you get the lens it should make sense. If you can find one! |
Posted: Sat Apr 27, 2019 6:36 pm Post subject: Re: The Stupid Question Thread |
CanStan wrote: |
There are a few in the classifieds, but not as many with the switches. _________________ 9th Owner of a 1971 Tintop Westy
Angus II Samba Member
Joined: June 01, 2016 Posts: 707 Location: Mammoth Lakes Ca. 93546
Posted: Sat Apr 27, 2019 6:53 pm Post subject: Re: The Stupid Question Thread |
Hello.
Does it work when you use the dome switch on the dash?
There is one that showed up today in the classifieds, it looks complete: fixture and lens, with both push buttons. Only $35
