kingkitesurf Samba Member
Joined: June 17, 2018 Posts: 81 Location: Haarlem, Netherlands
Posted: Sat Apr 27, 2019 2:30 am Post subject: Big red wire disconnected. Where should this go? |
I find this big red wire from the fuse box disconnected. Usually this means something is not working. Haven’t found it yet. But does anybody know where it should go? It seems to start somewhere in the middle of the fusebox. The number 9 and 12 fuse have a spare connector space... I do not just want to connect it there and mess something up..
plimthing Samba Member
Joined: March 29, 2014 Posts: 278 Location: West Midlands UK
Posted: Sat Apr 27, 2019 2:44 am Post subject: Re: Big red wire disconnected. Where should this go? |
Has anything stopped working? Do you have an electrical meter? If so see if you have 12v on it with ignition off then try with ignition on... might help deciding where on fuse box it goes. It might just be an unused PO install. If its an original wire check out the wiring diagrams on here for your year of bus, that should get you in the right area!
Good Luck |
Posted: Sat Apr 27, 2019 3:01 am Post subject: Re: Big red wire disconnected. Where should this go? |
Good Luck |
Posted: Sat Apr 27, 2019 5:59 am Post subject: Re: Big red wire disconnected. Where should this go? |
Red is typically part of the #30/B+ circuit. If connected to the fuse box it will likely have 12v on it, while if not connected it may not. It may be unfused so could make bigs spark and lead to a fire if it touches ground.
Posting the year of your rig would help. |
Posted: Sun Apr 28, 2019 12:00 am Post subject: Re: Big red wire disconnected. Where should this go? |
It is a dec '76 produced Westfalia T2 2L FI |
Posted: Sun Apr 28, 2019 4:45 am Post subject: Re: Big red wire disconnected. Where should this go? |
-Find out if it has or doesn't have power on it
-Determine if something isn't working
-Trace the wire to see where it goes
-Tape it off for now until you know what it is for and where it goes.
Likely suspects it might power:
-Interior lights
-Parking lights
-Emergency flashers
-Ambulance fans |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Apr 28, 2019 7:11 am Post subject: Re: Big red wire disconnected. Where should this go? |
What's that blue Scotchlock tap doing down there in the lower left of the pic? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
cellobus1 Samba Member
Joined: June 10, 2014 Posts: 284 Location: East Tennessee
Posted: Sun Apr 28, 2019 6:43 pm Post subject: Re: Big red wire disconnected. Where should this go? |
Perhaps the wire to the parking brake warning light? I removed my switch and reinstalled it in the front of the sliding door frame so the rear dome light could come on when you opened the slider, and there is a vacant wire there now that powered a radio for a while. Maybe your PO had the same idea. _________________ 1976 unrestored daily driver Standard bus, "Stella"
formerly, 1959 Standard bus
formerly, 1973 transporter which was 4 years old when it taught me to drive |
