Brake Caliper Rebuild -Photos-
Page: Previous  1, 2
SSWesty
SSWesty is offline
PostPosted: Tue Aug 11, 2009 9:39 am    Post subject: Reply with quote
Westylife, right now both Bus Depot and Van Cafe have them for $10. You need to make sure you get the kit to match your calipers.
http://busdepot.com/view.jsp?model=43&category=5&group=58&prodgroup=870
http://www.van-cafe.com/home/van/smartlist_641/caliper_rebuild_kit.html
westylife
westylife is offline
PostPosted: Tue Aug 11, 2009 10:16 am    Post subject: Reply with quote
SSWesty,
Thanks for the links. I have a 1983.5 so I guess need this one.
http://www.van-cafe.com/home/van/page_708_195/caliper_rebuild_kit.html
Bummer! But more seals = more $
1983.5 Westfalia Bostig RG1
floggingmolly
floggingmolly is offline
PostPosted: Tue Aug 11, 2009 3:01 pm    Post subject: Reply with quote
I don't get that...if the dust seals don't fit the Girling (which I have), what's the point? What if my dust seals are bad?
'85 Wolfsburg Weekender
JunkYarDog
JunkYarDog is offline
PostPosted: Thu Oct 22, 2009 3:53 pm    Post subject: Reply with quote
Bumped again Wink This is a job I'm doing now too. I have the dual piston girling calipers to work on.
As for the paste, someone correct me if this is wrong. I had a German mechanic tell me to lightly lube the pistons with copper paste before I load them back into the cylinder.
I thought the same of mine, as it turns out I was wrong. The problem was there are four metal rings, one for each cylinder lip. They are used to secure the dust seal inplace.
I'd love to powdercoat these calipers but it's not gonna happen. So High temp paint it is. This has been a good thread for me to read prior to this job though. I'd never had thought to use both bleaders. Smile
syncrodoka
syncrodoka is offline
PostPosted: Thu Oct 22, 2009 6:02 pm    Post subject: Reply with quote
I powdercoated and rebuilt 2 sets of audi dual piston girling calipers and stock vanagon calipers. I lightly lubed the piston and seal with brake fluid and pressed it back in place. I got the audi rebuild kits from http://www.autohausaz.com/index.html Good luck.
JunkYarDog
PostPosted: Sun Oct 25, 2009 11:35 am    Post subject: Reply with quote
Can anyone advise on the use of copper paste as I was told???
82WestyMan
82WestyMan is offline
PostPosted: Sun Oct 25, 2009 12:27 pm    Post subject: Reply with quote
I guess the thing I question is the compatibility of the copper paste with brake fluid.
Brake fluid is one of the last fluids you want compromised
I've always just used brake fluid and some care to reassemble caliper pistons without any problems
"The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine
syncrodoka
PostPosted: Sun Oct 25, 2009 12:59 pm    Post subject: Reply with quote
Brake fluid works fine.
Masta Shake
Masta Shake is offline
PostPosted: Sun Feb 06, 2011 5:57 pm    Post subject: Reply with quote
That looks good. I assume the powder coating didn't cause any fitment issues? PC can be a little thich from time to time.
As a good friend told me when I got the Syncro: "Welcome to the an intense love/hate relationship".
ragnarhairybreeks
ragnarhairybreeks is offline
PostPosted: Sun Feb 06, 2011 6:16 pm    Post subject: Reply with quote
I had nipple breakage this last week when trying to bleed. I couldn't salvage the caliper and I got a rebuilt unit. Putting it in I found the slider to interfere slightly with the backing plate and I trimmed the plate. I'm thinking there must be some slight differences in the sliders between Girlings. This is on '86 syncro
story here
http://shufti.wordpress.com/2011/02/05/replacing-that-buggered-caliper/
interference pics:
plate trimmed and caliper installed:
alistair
'86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
jwallis
jwallis is offline
PostPosted: Sun May 10, 2015 6:05 pm    Post subject: Reply with quote
I made a video of rebuilding ATE calipers last week. Trying to do this more to add to the collective knowledge base
https://www.youtube.com/watch?v=8gHecTdC35Q
50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more...
Merian
Merian is offline
PostPosted: Sun May 10, 2015 8:31 pm    Post subject: Reply with quote
do not use copper paste
the best thing to use is Unisilikon TK 44 N brake paste - Porsche part # 000.043.117.00 for a 50 g tube
if not, then any good quality brake paste, labelled as such
use brake fluid in an emergency
shagginwagon83
shagginwagon83 is offline
PostPosted: Tue Mar 12, 2019 1:15 pm    Post subject: Reply with quote
Heck yeah man. I have to rebuild mine soon. I not only watched your video but I also glanced through your multithreading c# video Laughing multithreading gets fun when you share data structures between threads.
Merian
Merian is offline
PostPosted: Thu Mar 14, 2019 4:45 pm    Post subject: Re: Brake Caliper Rebuild -Photos- Reply with quote
great time to replace those 20 year old rubber hoses Exclamation
shagginwagon83
PostPosted: Thu Mar 14, 2019 7:34 pm    Post subject: Re: Brake Caliper Rebuild -Photos- Reply with quote
For sure! Braided Stainless Steel, plus doing new Nickel copper hard lines.
Anybody know what to torque the 4 bolts holding the two pieces of an ATE caliper together? Will have to scan the Bentley to see if that info is there.
Rebuilding them wasn't bad. I probably spent roughly 1 hour per side. $13-17 a kit. I'll post pictures tomorrow
shagginwagon83
PostPosted: Wed May 01, 2019 7:44 am    Post subject: Re: Brake Caliper Rebuild -Photos- Reply with quote
I have one caliper leaking. I tightened it to 50 ft-lbs. I should have just bought a rebuilt set.
ATE wise. You can do this without splitting the calipers. My O-rings between the two halves of the caliper were fine.
bobhill8 Premium Member
bobhill8 is offline
PostPosted: Sat Apr 10, 2021 12:00 pm    Post subject: Re: Brake Caliper Rebuild -Photos- Reply with quote
Been working on this today Just reinserted the piston into my Girling calipers and this technique worked well:
For me, the key was to be patient and feed the back end of the seal in all the way around with the front outer part of the seal about halfway down the piston. I used the wood to apply even pressure, but even then, I stopped every couple of turns and took the wood out to see if things were really even. If it feels hard to turn, then something is not right. Once the piston was more than halfway in, you could feel it sliding in nicely and you could move the outer edge of the seal into its groove.
1986 Westy
1971 Squareback
Page: Previous  1, 2
Page 2 of 2
