epowell Samba Member
Joined: September 23, 2015 Posts: 4733 Location: Czech (mostly) Vancouver (sometimes)
Posted: Sun May 05, 2019 12:21 pm Post subject: Re: Humidity levels - what is the max humidity for storing parts? |
dobryan wrote: |
...you'd have to be a contortionist to rebuild in there. |
...or Hercules to build it in the attic.
Maybe best to build it in the basement with some form of humidity control. _________________ www.edwardpowell.com |
Merian Samba Member
Posted: Sun May 05, 2019 12:49 pm Post subject: Re: Humidity levels - what is the max humidity for storing parts? |
depends on the material - for everything, a non-condensing atmosphere is paramount
oil steel, Al and esp. any Mg
keep out of the sun (UV)
Mg will eventually corrode no matter what (eventually means in a year or so) but not if you store it in a N or Argon atmosphere
rubber will continue 'vulcanizing' no matter what - even in N or Ar as the side chains will continue to bond to each other; the surface will be harmed by UV, O3, O2
and... glass will cold flow just like some suspension bushings - but it takes decades for glass _________________ .... |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22573 Location: NYC/Upstate/ROW
Posted: Sun May 05, 2019 1:10 pm Post subject: Re: Humidity levels - what is the max humidity for storing parts? |
just hot box it in the basement, Ed. Build a box around it, dehumidify the box locally around the motor. _________________ .ssS! |
Posted: Sun May 05, 2019 1:18 pm Post subject: Re: Humidity levels - what is the max humidity for storing parts? |
Abscate wrote: |
just hot box it in the basement, Ed. Build a box around it, dehumidify the box locally around the motor. |
That's a good idea.... could probably put moisture absorbent stuff in the box.
At the moment I think I can store the motor in a closet on the main floor... my thinking now is shifting to wondering where I can actually build the motor. Probably not a good idea to build it in a damp place also... It could be quite a trick trying to get the full motor down from the attic. _________________ www.edwardpowell.com |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32433 Location: Reading Pennsylvania
Posted: Sun May 05, 2019 2:04 pm Post subject: Re: Humidity levels - what is the max humidity for storing parts? |
djkeev wrote: |
You need a proper garage boy!
You've been building parking spaces around the globe, time to switch to garages!
Dave |
haha... so what to build first: a garage or the engine? _________________ www.edwardpowell.com |
Merian Samba Member
Posted: Sun May 05, 2019 2:20 pm Post subject: Re: Humidity levels - what is the max humidity for storing parts? |
you can rebuild your motor in your carpeted living room - l like I did on my Bay _________________ .... |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4717 Location: Bemidji, MN
Posted: Sun May 05, 2019 3:07 pm Post subject: Re: Humidity levels - what is the max humidity for storing parts? |
rebuilt a 74 Bultaco in my bedroom... _________________ -dan
www.thefixitworkshop.com |
tjet Samba Member
Posted: Sun May 05, 2019 3:35 pm Post subject: Re: Humidity levels - what is the max humidity for storing parts? |
DanHoug wrote: |
rebuilt a 74 Bultaco in my bedroom... |
That's the best place to rebuild a motorcycle
https://www.thesamba.com/vw/gallery/pix/1859249.jpg |
Posted: Sun May 05, 2019 3:39 pm Post subject: Re: Humidity levels - what is the max humidity for storing parts? |
djkeev wrote: |
My Brother as a newlywed rebuilt an MG midget engine in his kitchen.
She divorced him shortly thereafter............
Dave |
'Unca Joel' from the old vanagon list @gerry, had his entire glass front kitchen cupboards neatly organized with Vanagon parts. and yes, he was divorced too. _________________ -dan
