ozzmonaut Samba Member
Joined: November 29, 2008 Posts: 151 Location: mount airy, NC
Posted: Tue May 07, 2019 9:57 am Post subject: Measurement from back of cab to bed |
I have a single cab, and it is rusted out completely where the cab meets the bed. Before I start repair, I just want make sure the distance is right, since at the moment the cab steel can flex in any direction. I have a pretty good idea of where the metal was, but to be sure, could somebody give me the measurement between the cab and header panel at the front of the bed? This little measurement did not seem to pop up anywhere online. Thanks |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Tue May 07, 2019 5:51 pm Post subject: Re: Measurement from back of cab to bed |
B is the measurement I am after. But either will work, as I just have to pull my cab steel toward the bed until I have the right distance. Thanks |
jeremy57ride Samba Member
Posted: Tue May 07, 2019 6:34 pm Post subject: Re: Measurement from back of cab to bed |
ozzmonaut wrote: |
My measurement there is 1 1/8" (inches)... but it is not perfectly consistent, those bed bulk heads take some punishment. _________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
easy e Samba Member
Posted: Tue May 07, 2019 7:48 pm Post subject: Re: Measurement from back of cab to bed |
I measured near the vertical can seam on each side.
Both sides the same. Neither over an inch.
I’d call “A” a fat 24 mm, or a fat 15/16”
I’d call “B” a fat 21 mm, or a fat 13/16”
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
b-man Samba Member
Posted: Tue May 07, 2019 7:51 pm Post subject: Re: Measurement from back of cab to bed |
A - 1.030”
B - 1.00”
Measurements (using a dial caliper) taken from my ‘66 single cab that never had a hard life as a commercial vehicle. _________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
easy e Samba Member
Posted: Tue May 07, 2019 8:30 pm Post subject: Re: Measurement from back of cab to bed |
Your number is more precise.
In case the channel varies in width (at all) over it’s length, please say at what location the measurement was taken... ie. 1/4” to the outside of the vertical cab seam.
I think a measurement closer to the side would be more convenient for the OP to use in reassembly (vs. directly below the center of back window). _________________ aka: Evan
b-man Samba Member
Posted: Tue May 07, 2019 8:37 pm Post subject: Re: Measurement from back of cab to bed |
I took my measurements on the drivers side just below the rear window corner and a little ways toward the middle of the window. Actually was getting some pretty consistent readings in that area and right next to the gate latch. _________________ 1956 Dove Blue Panel
Posted: Tue May 07, 2019 9:50 pm Post subject: Re: Measurement from back of cab to bed |
Thanks everyone for checking. Looks like the number will vary quite a bit from truck to truck. Looks like if I shoot for about an inch, I can't really get it wrong. |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Wed May 08, 2019 4:12 am Post subject: Re: Measurement from back of cab to bed |
I’ll say it again, these buses were put together by hand. No 2 buses are identically the same. Or as I always figure, if you can’t see that from an airplane, it’s okay! _________________ Some people are so busy being clever they don't have time enough to be wise. |
