Mike Robinson Samba Member
Joined: June 18, 2010 Posts: 386 Location: Nanaimo BC Canada
Posted: Wed May 08, 2019 6:46 am Post subject: Re: I want a simple way to have a switch to control the rad fan |
I do this for my AAZ diesel Westy, when I start climbing a hill and the temp starts going up, flick the switch and it stops it from getting too hot. Over heating my Diesel engine is right up there on things I don't want to experience.
I am sure the switches work, but it is nice to have a bit of control just in case.
When you look at the switches there are two wires going into each switch. As the switch is activated the circuit closes, and power to the fan happens.
So get a couple of piggy back spade connectors and attach them to each of the terminals. The old wiring stays in place so the 'auto' function still is there, then run two wires back to a toggle switch you have mounted somewhere on the dash. Activating the switch does the same as the auto temp thing.
Super easy.
If I remember correctly on the '82 model that I have the switch is an earth switch ie negative so no current goes through it so any toggle switch from you FLAPS will do.
Mike
'82 Westy Diesel. |
Paulbeard Samba Member
Posted: Wed May 08, 2019 7:17 am Post subject: Re: I want a simple way to have a switch to control the rad fan |
| DuncanS wrote: |
| Marcq--There is a lot of negativity happening here. It seems to break down into two separate categories which are worth listening to. |
To add on/amplify this…what makes you think you need to do this at all? Your thermostat is very different from your van's. 100°F is nothing to it but the 180°F it enjoys would be very uncomfortable for you.
If you haven't experienced:
• a boilover
• a pegged temp gauge, with or without flashing red light
• a sudden roar from your fan as it tries to dump heat
• an oil pressure buzzer warning
I suspect you are trying to fix something that isn't broken. Have you tested your pressure cap? Are your coolant levels good? Have your checked temps, fore and aft, with an IR gun? _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
DuncanS Samba Member
Posted: Wed May 08, 2019 8:12 am Post subject: Re: I want a simple way to have a switch to control the rad fan |
| Mike--He has a WBX--Not the diesel you have. Confused as you said the the '82 has a ground switch--82 was air cooled. Just checked Bentley--the '87 is definitely NOT ground activated. As I said, this is not a simple job to be reliable and safe. Yes, you can just bypass the thermostat switch, but dealing with this and making sure you get the right wires can also cost you your ECU if you make a mistake. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10463 Location: Orbiting San Diego
Posted: Wed May 08, 2019 8:44 am Post subject: Re: I want a simple way to have a switch to control the rad fan |
He is mistaken about the 82 diesel watercooled rad temp switch switching the ground side. Also it is false that the earth/negative side carries less current than the positive side, since we are talking about DC automotive circuits.
It is simple to hot wire a switch to turn on the fan but there is some risk to doing so and thought should be put into it. I would prefer a switch using a separately fused diode protected alternate power source, tied to the high speed fan relay control pin wiring. So a key-on power wire to the switch, through a fuse and diode, then a single wire from the new switch run to the red/blue wire at the 3 pin rad temp switch wiring. (this is for 83+, as 82 is a little different )
Mark |
Marcq Samba Member
Joined: June 15, 2015 Posts: 231 Location: Corona, CA
Posted: Wed May 08, 2019 9:21 am Post subject: Re: I want a simple way to have a switch to control the rad fan |
| fxr wrote: |
| Marcq wrote: |
| skills@eurocarsplus wrote: |
| decide what speed you want (hi or low) and tap into that wire |
Tap into that wire? What does tap means?
Marc.. |
"join on to"
Preferably with a proper crimped splice or soldered and heat-shrinked.
Frankly, if you have to ask how to do this, best to find someone who knows exactly how to do it to show you. You do know to disconnect the battery negative first? |
Sorry my native language is French, I don't know all the terms and yes I know about disconnecting the battery, I have installed a kill switch
Marc.. |
Marcq Samba Member
Posted: Wed May 08, 2019 9:54 am Post subject: Re: I want a simple way to have a switch to control the rad fan |
Thanks for all the feedback. it's just that I have heard of people doing it and thought it was a good idea specially in my case where I live, not uncommon to be faced with traffic and 100-120 degree temp in the summer
I ear a lot about how great the system works and yet you see people doing all king of engine conversions, weird!
Marc.. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19068 Location: Retired South Florida
Posted: Wed May 08, 2019 10:02 am Post subject: Re: I want a simple way to have a switch to control the rad fan |
I have found the stock 2 speed rad fan system to work quite well. There are very few operating conditions where the first speed rad fan can't keep up with the heat idling in 110 F degree in a traffic jam. Going down the highway on the same day, the fan is probably not even running and engine temp is maintained by the air flow across the radiator.
I have been in two situations where the high speed radiator fan does operate. One is when I have been tooling down the highway and decide to stop for fuel. If I get hung at a couple stop lights at the exit, the fan has clicked to high, but very rare.
The other time the high speed fan kicked on was climbing Pikes Peak. Slow speed and gaining altitude. Low speed was working fine and a few times high speed would click on and the fan would cycle between high and low as expected. A pressurized cooling system with the proper mix should be fine to 250F before boiling over. Its a bit startling when the rad fan does come on high. As I said its very rare and sounds like a hover craft. Don't know that I would want that running continuosly.
I'm with the others that if you are not familiar with automotive electrical probably best not to learn on the one system you need functioning correctly to keep the engine alive.
edit: engine conversions have nothing to do with the Vanagon's cooling system. As far as I know, including my engine conversion, I am using the stock vanagon cooling system as designed. I am probably making twice the HP and torque of the stock engine, yet the cooling system works fine. If anything the Vanagon cooling system is over designed based on my experience. |
kamzcab86 Samba Moderator
Posted: Wed May 08, 2019 10:49 am Post subject: Re: I want a simple way to have a switch to control the rad fan |
| Marcq wrote: |
| Thanks for all the feedback. it's just that I have heard of people doing it and thought it was a good idea specially in my case where I live, not uncommon to be faced with traffic and 100-120 degree temp in the summer |
Most (not all, but most) folks who add manual fan switches are those who don't care to fix a broken cooling system.
I live in Phoenix... from June to September, the daytime temps are 105-120°F. My Vanagon and Cabriolet have zero issues, although their fans run a lot, as designed.
Like Mark, my '90 has only had the jet-engine fan turn on only a few times, all in AZ and during the summer: Once when there was a problem coming back from Calif., and a couple of times driving up the Bumblebee Pass fully loaded. _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Dampcamper Samba Member
Joined: October 07, 2013 Posts: 789 Location: Rainy Portland, Oregon
Posted: Wed May 08, 2019 11:54 am Post subject: Re: I want a simple way to have a switch to control the rad fan |
The only fan-related cooling issues I've ever had were when the high-speed relay failed (in my diesel Rabbit), and when a thermal switch failed on a Vanagon. In both cases I made up and used a jumper wire to force the fan on and completed my trip that way.
I've thought about an emergency forced-fan switch for my Vanagons (The Rabbit met a deer at highway speed so is no more but neither is Bambi) only because the thermal switch is kind of awkward to access.
But as noted above the system works pretty well as designed so haven't worried about it enough to implement a permanent circuit. I do carry jumper wires for the fan thermal switches just in case. A scrap of #16 wire, some crimp lugs, and away you go. I'd wrap electrical tape around the connectors after installation to minimize risk of shorts.
A switch would allow you to turn the fan off when you stopped instead of having to pull the jumper wire, there is some attractiveness to that. |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17295 Location: Brookeville, MD
Posted: Wed May 08, 2019 12:37 pm Post subject: Re: I want a simple way to have a switch to control the rad fan |
If you think you need a switch because you think it is overheating there is a problem with the stock cooling system or the temp gauge is not giving you accurate info. Either issue should be rectified vs adding a switch IMO. The stock cooling system is very robust, but old, and may need some components replaced.  _________________ Dave O
The Western Syncro build
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
Posted: Wed May 08, 2019 1:34 pm Post subject: Re: I want a simple way to have a switch to control the rad fan |
| MarkWard wrote: |
| I have found the stock 2 speed rad fan system to work quite well. I am probably making twice the HP and torque of the stock engine, yet the cooling system works fine. If anything the Vanagon cooling system is over designed based on my experience. |
Ditto. I've never had any overheating issues with either van, 85HP or 165HP.
Super cooling system on these vans when everything is working correctly. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
