What did YOU do to your van today?
Page: Previous  1, 2, 3 ... 501, 502, 503 ... 561, 562, 563  Next
Gnarlodious Premium Member
Gnarlodious is offline
PostPosted: Fri Apr 26, 2019 3:05 pm    Post subject: Powdercoat glossy black Bully side steps! Reply with quote
I thought the aluminum ones looked stupid, so I had them powdercoated!
Vanagon í83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD.
4mymalamute
4mymalamute is offline
PostPosted: Sat Apr 27, 2019 3:37 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Put in the rear abs panels.....had to take both the bench and the middle seats out to get all the panels in place. Looks nice and no more warped and worn out panels.
1989 Sally the Syncro.....she is a work in progress.
fxr
fxr is offline
PostPosted: Sun Apr 28, 2019 4:52 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Re-keyed the slider door lock, which was different to the other doors. Now I only have two keys - one for the ignition and then one for all the doors.
The ignition one seems to be a slightly different blank - I'm loath to re-key that one unless I can get my hands on another barrel.
Jim Crowther
Vespa GTS 300
BCE56
BCE56 is offline
PostPosted: Mon Apr 29, 2019 3:07 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
I'm currently working on a similar issue: the tail of the ign lock mechanism that rotates the switch broke. Ordered a "quality replacement "lock assy.
Simple, right?
No.
That assy does not fit the factory column mount housing correctly, and does not actuate the steering column lock or the start switch.
Nor does it accept the factory "N" profile key- so re-coding the lock tumbler to match my key is not possible.
Swap the old lock cylinder you say?
Nope. Incompatible, totally different designs.
So I ordered a Hella assy. Not an N-profile cylinder but I may be able to swap it for the old one.
And it just might work better with the column bracket...
We shall see.
=BCE56=
'86 Syncro tintop
OBD II Frankenmotor
Early SC adapter plate conversion
SC header, 3-way cat, VW muff.
stock springs, OME shocks*
VC, rear locker**
215-75 BFG AT/TAs on Rhein rims
*OMEs a bit too stiff in front, OK in rear or on heavier vans. Will try Bilsteins. Someday.
**PO installed taller top gear before Subie install. Not recommended.
82westyrabbit
82westyrabbit is offline
PostPosted: Mon Apr 29, 2019 7:54 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Aftermarket versus factory lock cylinders. I made all my locks match last fall. It was a pain mix and matching aftermarket door handles and factory lock cylinders. John
jlrftype7
jlrftype7 is offline
PostPosted: Tue Apr 30, 2019 1:16 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Finally broke down and applied 3M Glass Urethane Sealant to my Front Windshield Seal. I had been hoping to hold off and just replace the glass and seal, while performing any needed metal work hiding under the seal.
BUT, my Vanagon had other ideas and wouldn't stop dripping water into the interior with all this Rain we've been having.
So far, no water seen puddling on my black rubber floor mats anymore.... Progress... Rolling Eyes
'67 Type 3 Fastback, my 2nd car- also long gone
'69 Semi-Auto Stick Shift Beetle, my wife's first car= yep. still long gone....
Ď84 Tin Top - Hilga....Auto
a2wolfsburggli
a2wolfsburggli is offline
PostPosted: Tue Apr 30, 2019 4:13 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
So far this spring, these are the "things," I've done to my 87 which got pulled out of a garage after sitting for 15+ years.
Dropped Fuel Tank and re-resealed
Discover hard lines from fuel pump to engine compartment (through firewall gromet)
New Marco injectors installed
New Bosch Cap and Rotor. Older style cap for wire compatibility.
New plug wires
New plugs
All new fuel lines
Added sheathing over fuel line.
Removed ISM.
Propane tank rust removal, prime and paint. New fill and 80% valve, reused shut off and regulator.
Added computer fan to rear blades and cooling sink on fridge, cleaned propane burn chamber. Switch for internal fan.
Confirm 12v, 120v and Propane work on fridge.
New front rotors and pads Zimmerman & Mintex reds
New wheel bearings
New Koni front shocks
New Gabriel HiJackers wtih indivdual air hoses.
New Gauge cluster kit
New heater control decal
Used Stereo install
New internal antenna
Cleaned all grounds in engine compartment
Still a bunch of fun things to come.
One thing I've come to enjoy is that may of the upkeep / upgrade / maintenance jobs are sub $250 for parts and easy day or weekend jobs. So it makes it easy to buy and work incrementally without needing to break the bank all at one time. (Although, I admittedly have close to a grand into stuff since I bought the van last Oct....lol.)
Current: '87 Westfalia | '16 Audi Q5 3.0T S-Line w/sport package.
Past: '09 CC 3.6L 4motion "R36 wannabe" | '02 Audi TT "ALMS Edition" | '84 Jetta GLI with Autotech Supercharger | '89 Helios Jetta GLI 16v's (x2) | '95.5 URS6 | and the list goes on.
Never underestimate the entertainment value of OCD overruling Common Sense
leecat
leecat is offline
PostPosted: Tue Apr 30, 2019 9:30 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Worked on scrubbing up and salvaging a new pop-top for our Westy; it sat on a wrecked van in coastal B.C. for 20 years and looked like Treebeard's toilet seat - cleaned up amazingly well though with a ton of elbow grease, these are some tough tops.
Steve Arndt
Steve Arndt is offline
PostPosted: Wed May 01, 2019 7:22 am    Post subject: Re: What did YOU do to your van today? Reply with quote
That is an awesome image :p
Steve
Steve's 87 Syncro project
jlrftype7
PostPosted: Mon May 06, 2019 8:19 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Installed my rebuilt Air Flow Meter from Fuel Injection Corp.
Changed my Walker O2 sensor to a new NGK version.
revolution337
revolution337 is offline
PostPosted: Tue May 07, 2019 5:20 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Started resealing my transmission the other day...figure better to do it while I have the trans out!
Also installed my VL center console, with added battery kill switch. Had to drill two 1" holes in the right seat pedestal leading into the battery compartment for the ground cable leads. Also had to remove the weird false wall in the battery compartment, by drilling out the 5 or so rivets. Ran a new starter cable, and replaced the wiring at the positive terminal for the front fuse box lead, as well as added a new heavy gauge wire to power my newly added radiator fan (previously air cooled).
dhaavers
dhaavers is offline
PostPosted: Tue May 07, 2019 6:42 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
^^^[email protected] nice...VERY clean install. Love it! Cool
Are you available for contract work...???
Wink
- Dave
86 White Westy Weekender
"The WonderVan"
revolution337
PostPosted: Tue May 07, 2019 7:28 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Wink
- Dave
Thank you! Iíve always found a great amount of joy in automotive wiring/rewiring. I know how weird that may sound, but itís almost zen like to me. I could spend hours out in my garage building harnesses, fixing old wiring, installing terminals, etc. With the proper tools and supplies at hand, thereís no reason one canít make a harness just as good, if not better than factory.
But maybe Iím just crazy? haha
jlrftype7
PostPosted: Fri May 10, 2019 9:24 am    Post subject: Re: What did YOU do to your van today? Reply with quote
Cut out the Dry rotted Seam Sealer in the Nose Seams with my Pneumatic Harbor Freight Oscillating Tool[ it's smaller than either one of my Fein Corded MMs] , added Rust Converter and pushed it gently in with very low air pressure after brushing the Converter in to the Seams.
Once that dried, I added 3M Urethane Seam Sealer, Black, to the seams.
Smoothed it out, cleaned up the mess. Now I need to prime and Paint the Seams to blend them in.
I had already worked on the Windshield seal for slow leaks, but still had open gaps in the seams that were letting water into the interior. Once I added Blue Painters Tape over the Seams as a test, I stopped getting water into the dash area. So it was time to attack those Seams... Rolling Eyes
I also had the Classic o2 sensor shield wire into the Signal Wire, inside the black boot covering the connector. The green insulation had cracked and opened up about a 1/16" gap of bare wire, and the shield strands were neatly adhered to the signal wire.... Embarassed
jlrftype7
PostPosted: Fri May 10, 2019 8:43 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Removed the exterior mirrors; sanded them, cleaned and primed them. Painted them Satin Black after that.
Glass Beaded the headlight buckets and the wiper arms to remove rust and corrosion.
Primed all parts, top coat is tomorrow.
AndyBees
AndyBees is offline
PostPosted: Sat May 11, 2019 4:36 am    Post subject: Re: What did YOU do to your van today? Reply with quote
After a number of weeks with the dash out of my 89 tin-top to repair the heater blower, I reinstalled it. But, while I had it out, I modified the housing to re-route the fresh air venting to by-pass the heater core to the vents on the dash. This was the original set-up on the early Vanagons. I liked it much better. Ironically, as those of you who've been there and seen, VW left the original vent fittings on the housing, however it was plugged.
I also eliminate the Buzzing & Flashing Oil Pressure Light by disabling the circuit on the back of the Cluster. I'd previously determined that the oil pressure is fine throughout the range, cold and hot engine, using a mechanical gauge, as well as changing the pressure switches...!
Oh, and pressure washed the engine....
'84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
torbot
torbot is offline
PostPosted: Sat May 11, 2019 9:38 am    Post subject: Re: What did YOU do to your van today? Reply with quote
I modded my rear my rear closet with siding doors, based off of campism and frank condelli's excellent work:
Campism:
https://www.thesamba.com/vw/forum/viewtopic.php?p=4627653#4627653
Frank Condelli
http://www.frankcondelli.com/closet.htm
Also mounted my Estwing hatchet and trench shovel to the back using QwikFists and some leftover rubber moulding from the rear closet door (to keep things from rattling).
'82 Westy w/2012 Subaru EJ25 (AKA "Dave").
campism
campism is offline
PostPosted: Sat May 11, 2019 4:55 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Looks good with the contrasting doors!
'87 Westy in Wolfram Grey Metallic
dhaavers
dhaavers is offline
PostPosted: Sat May 11, 2019 5:12 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
torbot wrote:
Ahhhh...sweet, sweet, sweet, and...SWEET!
Cool
- Dave
"The WonderVan"
torbot
torbot is offline
PostPosted: Sat May 11, 2019 10:17 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Thanks man, my wife talked me into leaving them bare wood and I'm really glad we did (she handles interior decisions). Big thanks to you too! can't tell you how many times I looked at your photos to figure things out. Laughing
Cool
- Dave
Very Happy
Page 502 of 563
