JBH Samba Member
Posted: Tue May 21, 2019 1:36 pm Post subject: Wiring identification help |
I pulled a new harness from the engine forward in my 73' Ghia. Under the back seat I have (1) new large red wire, coming in from the right, and an existing large red wire with a small black wire exiting into the motor box. See photo.
Can someone tell me what these are?
Also, in the engine compartment, I have a large red/white wire with a small red. Can someone tell me what these are? Also, there are two sets of generator wires: red, brown, & green. I thought one set would have gone into the car and come out under the back seat where the new large red wire is. Does the Ghia have the voltage regulator in the engine compartment? Thank you in advance. I didn't have an existing harness to compare.
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
JBH Samba Member
Posted: Tue May 21, 2019 2:52 pm Post subject: Re: Wiring identification help |
Thank you for that. Is the regulator located in the engine compartment, or under the rear seat like a beetle? |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
JBH Samba Member
Posted: Tue May 21, 2019 4:49 pm Post subject: Re: Wiring identification help |
sputnick60 wrote: |
JBH wrote: |
Yes, In the engine compartment on that small bar atop the wassowheel tub
Nicholas |
Thank you! Couldn’t figure out why the harness seemed too short. So the large red wire coming out under the rear seat: what is it for? |
Posted: Tue May 21, 2019 7:46 pm Post subject: Re: Wiring identification help |
Just plug them together. It runs from the ignition switch to the starter _________________ Volkswagen!
(Compression 8.7:1) |
JBH Samba Member
Posted: Tue May 21, 2019 8:59 pm Post subject: Re: Wiring identification help |
jeffrey8164 wrote: |
Just plug them together. It runs from the ignition switch to the starter |
