oildrip Samba Member
Joined: November 13, 2013 Posts: 5 Location: Laguna Beach, CA
Posted: Mon May 20, 2019 5:57 pm Post subject: Early vent trim holes - measurements needed |
Hello everyone,
I have a '57 Deluxe bus and need some help. The previous owner decided the engine vent trim spears were too flashy so he removed the trim and filled in all the holes . . . with a MIG welder. So I'd like to put the vent trim back on but there is no way to tell where the previous holes were located. Could somebody with an early deluxe bus provide me with the measurements of the holes? This would include the original hole diameter, the spacing between the holes, and the distance up from the edge of the vent louver. The more accurate the better (i.e. in mm would be great). I'm assuming the center hole on each louver is in the center of the louver but it would be great to get confirmation of that before I start drilling. Thanks in advance, really appreciate the measurements, I couldn't find them anywhere.
-Phillips |
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
Posted: Tue May 28, 2019 10:17 am Post subject: Re: Early vent trim holes - measurements needed |
Hello,
Anyone have a deluxe bus they could pull some measurements off? Thanks! |
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Tue May 28, 2019 1:58 pm Post subject: Re: Early vent trim holes - measurements needed |
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
Posted: Sat Jun 01, 2019 2:30 pm Post subject: Re: Early vent trim holes - measurements needed |
Thanks Thom!
I was at OCTO today and pulled some measurements as well in case this helps someone in the future.
The holes are 3 mm
The distance from the edge of the louver to the center of each hole is 4 mm
The center hole is lined up with the center of the louver
The holes are 10 mm apart from each other, as shown in Thom's photo. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7045 Location: Lawrenceville, Ga
Posted: Sun Jun 02, 2019 8:36 am Post subject: Re: Early vent trim holes - measurements needed |
oildrip wrote: |
Thanks Thom!
The holes are 3 mm
you probably mean the holes are 10cm (100mm) almost 4 inches apart from each other _________________ regards
Uli
