Russpauly Samba Member
Joined: January 13, 2019 Posts: 134 Location: San Diego
Posted: Wed May 29, 2019 8:10 pm Post subject: Re: What did YOU do to your van today? |
Make America Vanagon wrote: |
I finished today, but for the last 2 months, a little here, a little there, and here is the finished product.
Dude! We have an almost identical Van! I hope yours runs and has been treating you better than mine has.
_________________ 1988 Wolfsburg Edition - TinTop
2.1L Watercooled
The Space man Van |
VWeGoBeachNow Samba Member
Joined: May 12, 2010 Posts: 197 Location: CRUISING DOWN PCH IN THE OC
Posted: Wed May 29, 2019 8:50 pm Post subject: Re: What did YOU do to your van today? |
Russpauly wrote: |
Nice ones 🤙 _________________ 88 Wolfsburg Limited Edition Vanagon GL Tin Top
Vesuve Grey underneath cheapo Vesuve Grey paint job
2.1 L
4spd |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Thu May 30, 2019 6:22 am Post subject: Re: What did YOU do to your van today? |
Due to completely irrational college sports biases, I have been trained from a young age to hate all shades of the color red in all contexts, with the exception of Tornado Red Vanagons. So cool looking. I want one. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4349 Location: United States, Iowa
Posted: Fri May 31, 2019 10:01 pm Post subject: Re: What did YOU do to your van today? |
Had been hearing a cyclical noise from the front end. Got floss up to give her a feel, left seemed a bit stiff, but no play 10-3 nor 12-6. Right indeed has a tiny bit at 3-9 and a tad at 12-6.. Decided to rotate the tires. Getting ready to trek to Bug-in Minneapolis I think she'll make it there and back, and I expect my front end rebuild parts from Christoph3r soon, so it will get done one way or another!! Hopefully not after a AAA tow home. She'll never be a trailer queen, hopefully not a flatbed nightmare either.
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Marcq Samba Member
Joined: June 15, 2015 Posts: 231 Location: Corona, CA
Posted: Sat Jun 01, 2019 6:16 pm Post subject: Re: What did YOU do to your van today? |
Replaced the seat with a permanent bed for storage, just ordered another foam
Marc.. |
jlrftype7 Samba Member
Posted: Sat Jun 01, 2019 8:20 pm Post subject: Re: What did YOU do to your van today? |
Replaced rear brakes.... all of it...
New backing plates, new wheel cylinders, new rubber hoses, one new hard line( threads stripped coming out of the old hose)
New spring kit, new drums, new anchor pins, new bolts, new parking brake cables. Added some grease into the outer rear wheel bearing via a needle attachment while the flanges were off( they were rusted to the drums and had to be popped apart with the shop press)..
Painted the rear trailing arms with Eastwood Chassis Black.
The pictures of correctly placed arms and springs here on Samba were great to double check my work as this was my first rodeo with the rear brakes. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
obzrve Samba Member
Joined: November 17, 2016 Posts: 52 Location: Hollywood,FL
Posted: Sun Jun 02, 2019 1:02 pm Post subject: Re: What did YOU do to your van today? |
Reconnect my horn
Replace the ignition control module
Clean Fluid injectors
Seal vacuum leaks |
Posted: Sun Jun 02, 2019 1:55 pm Post subject: Re: What did YOU do to your van today? |
Replaced my spider cracked oem tail lights with the smoked ones from Ken at Vanagain.com and replaced a broken license plate bulb.
They are the European version made by JP Group Denmark. Nice quality and yes I know they are not street legal My slightly upgraded bulbs make it a bit brighter. Might run led in the future.
My Hella front smoked turn signals has been waiting for this
2.1 L
4spd |
yew Samba Member
Posted: Sun Jun 02, 2019 9:02 pm Post subject: Re: What did YOU do to your van today? |
I decided I'd done enough engine/mechanical that I'd earned looking into an issue with the stereo -- which stopped working a while back when I tuned up the window crank assembly. Head unit was getting power, but no sound. Replaced it, same issue. Then figured out that the driver's side door was pinching a wire bundle and when I take pressure off it I get sound back to all speakers. I still down understand why, but I guess I understand the fix
Tomorrow new stereo head unit goes back, and I ordered ABS door panels because part of the problem here is that the original ones are water logged and falling apart.
A PO put two speakers in the door and I'm suspecting modern speaker tech will allow me to put one pair in, smaller, with better sound. Lemme know if anyones's got particular recommendations there. _________________ "Panda": '85 Adventurewagen - 2.1L WBX |
Posted: Sun Jun 02, 2019 10:01 pm Post subject: Re: What did YOU do to your van today? |
Drove like the wind. In a F5 cyclone. Now home from the Bug-In Minneapolis. Did NOT win the '67 seafoam beetle.. didn't figure I'd be that lucky.. Some guy named Andretti did, imaging! No worries, already have TOO MANY. Was fun. just over 500 miles added to the ODO. Glad to be home and in bed _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Mon Jun 03, 2019 7:05 am Post subject: Re: What did YOU do to your van today? |
yew wrote: |
A PO put two speakers in the door and I'm suspecting modern speaker tech will allow me to put one pair in, smaller, with better sound. Lemme know if anyones's got particular recommendations there. |
If the wire[s] are shorted to ground inside the harness or are shorting together when pinched, I can easily see an amp shutting down in protection mode, even if it's a small radio with no external amp in the stereo system. I've seen this with Alpine and other radios back in the early 2000s on Land Rovers where the radio would shut the whole vehicle side of that grounded harness down once a screw was accidently out into a radio/stereo harness. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Mon Jun 03, 2019 5:48 pm Post subject: Re: What did YOU do to your van today? |
Finally installed the GoWesty Altn. Support Bracket that I had ordered months ago. My 1.9 had the threaded holes even though I don’t have power steering, so that was less work needed than if I had found non-machined casting bosses like the one poster with his ‘83 1/2 did.
The main pivot bolt snapped on me, so I spent some quality time coaxing the broken bolt out of the bottom of the Altn.
Installed the new bracket and hardware, added copper Anti-Seize to the new pivot bolt and got the satisfaction of finally watching my Altn stop wobbling with the engine running.
Made a temporary repair of the Blue Field wire, cleaned the main output post and eyelet of the double wires for now. A new harness for that circuit is now on my to-buy list.... Blue Wire Insulation was crumbly to the touch... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
4mymalamute Samba Member
Posted: Tue Jun 04, 2019 5:24 am Post subject: Re: What did YOU do to your van today? |
Replaced passenger side power window regulator....got it all back together and rolled it down...and I hear a "snap" that was plastic. Sure enough, the dang little plastic holder that keeps the wire in place snapped. Apparently something is in door that the window is hitting and when rolled down almost completely, it hits thus causing the window to put pressure on the plastic. Uhg, not sure what to do now. _________________ 1989 Sally the Syncro.....she is a work in progress. 1.8T and tuned...she scoots up the hills...watch for flying dog drool out the windows.
1969 Bucky the Bug Convertible...red, rusted, work in progress....LOTS of work. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Wed Jun 05, 2019 5:56 pm Post subject: Re: What did YOU do to your van today? |
... _________________ This free advice is worth exactly what you paid for it.
Posted: Wed Jun 05, 2019 5:58 pm Post subject: Re: What did YOU do to your van today? |
Ran a new power wire up the A pillar on the Drivers side to replace the Mouse chewed open circuit...
Installed one of my LED Festoon bulbs in place of the standard incandescent bulb as a test.
Still more work to do on that circuit...Passenger Side door switch turns on the dome light at the left door while in Auto mode/ Door mode, but the Drivers door switch does not.
2nd contact of the drivers door switch does work with the Buzzer relay, so the mice didn’t kill that portion of it. Always On portion of the front light works, so the wiring is still okay there. I found that blasting the metal contacts with my Baking Soda Blaster is a quick way to safely remove the corrosion on the dome light contacts and not hurt anything . More effective than Contact Cleaner....
Slider door switch works nothing, I’d already cleaned all the door switches earlier this year, so it’s time to break out the Multimeter and find my remaining opens.
Adjusted the new rear brakes one more time and dialed in the Parking Brake as well.
Much better pedal height and stopping power now.
More to do.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Love My Westy Samba Member
Posted: Wed Jun 05, 2019 6:20 pm Post subject: Re: What did YOU do to your van today? |
'Got my Van out of the garage and washed it. Armor-All on all window seals and the front bra.
Just ordered the Bus Depot polycarbonate headlight covers to go over the GoWesty ones so now I'll have double protection. The reason is that my drivers side high beam was broken even with the GoWesty lens protector on it. It cost me $75 for a used high beam.
'Going out now to load our two e bikes for a ride around Park City tomorrow. |
Posted: Wed Jun 05, 2019 6:34 pm Post subject: Re: What did YOU do to your van today? |
Dropped Sally the Syncro off at Stephans Auto Haus to get all the AC lines replaced. Just had new compressor, etc put in and while it was sitting in my driveway...the old lines blew.
So, now Sally will have a sweet chilly AC....for the dogs to enjoy. _________________ 1989 Sally the Syncro.....she is a work in progress. 1.8T and tuned...she scoots up the hills...watch for flying dog drool out the windows.
smd333 Samba Member
Joined: September 08, 2018 Posts: 55 Location: Maryland
Posted: Thu Jun 06, 2019 8:42 am Post subject: Re: What did YOU do to your van today? |
I ordered a set of these
HANKOOK VANTRA LT (RA18)
75.97 apiece
https://simpletire.com/hankook-185-r14-2001939-tires
I'm planning on getting the lifetime alignment at the local Firestone as well
Also got to meet dobryan at his home a few days ago and he was kind enough to look at my van and offer me a few beers... even made a small modification to the battery compartment to make it safer. I know what to bring if I go back to his place now lol |
pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Thu Jun 06, 2019 4:32 pm Post subject: Re: What did YOU do to your van today? |
smd333 wrote: |
...Also got to meet dobryan at his home a few days ago and he was kind enough to look at my van and offer me a few beers... even made a small modification to the battery compartment to make it safer. |
OK- I'll take the bait: What's the little mod we probably all should make in the battery compartment? |
Posted: Thu Jun 06, 2019 5:17 pm Post subject: Re: What did YOU do to your van today? |
pinetreeporsche wrote: |
smd333 wrote: |
. I was wondering this too since the cover DOES end up close to the Positive Terminal. I have the usual plastic post cover that fits in the small round holes on top of the battery, but am certainly open to suggestions of improvements.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
