xavior12 Samba Member
Joined: September 25, 2006 Posts: 92 Location: Portland, Oregon
Posted: Tue May 28, 2019 9:18 pm Post subject: Are the M codes for the T4 Eurovans available |
I checked the FAQ but no entries. Are they the same as T3 Vanagons?
Can anyone point me into the right direction.
Thank you |
markcm2 Samba Member
Joined: September 02, 2015 Posts: 505 Location: Bellingham, Washington
Posted: Wed May 29, 2019 9:53 pm Post subject: Re: Are the M codes for the T4 Eurovans available |
xavior12 wrote: |
Thank you |
What are M codes? I've not heard of that before. |
Abscate Samba Member
Posted: Thu May 30, 2019 3:17 am Post subject: Re: Are the M codes for the T4 Eurovans available |
Old VW plate that’ carried build options for T1 and T2 generation transporters
I don’t think they were used on T3, 4,5, and 6 _________________ .ssS!
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Posted: Thu May 30, 2019 8:33 am Post subject: Re: Are the M codes for the T4 Eurovans available |
Actually T3s did have the steel M code plates. Under the LF seat, riveted to the body.
T4s have their codes on a 50cm square white sticker affixed to the LT A pillar. |
kamzcab86 Samba Moderator
Posted: Thu May 30, 2019 5:31 pm Post subject: Re: Are the M codes for the T4 Eurovans available |
xavior12 wrote: |
Thank you |
Not the same, generally speaking. Here's a place to start: http://prsearch.planetvag.com/default.aspx (courtesy of http://www.brick-yard.co.uk/forum/decoding-pr-codes_topic64619.html ). Post your results, if it provides any, and we'll get a list going.
CdnVWJunkie wrote: |
The rivteted identifier is actually called a PKN plate. Additionally, the T3s also have build sheet stickers affixed to the body near the fuse panel. _________________ ~Kamz
2016 Golf GTI S
