84WestyHobbes Samba Member
Joined: April 01, 2019 Posts: 54 Location: Savannah, GA
Posted: Tue Jun 04, 2019 12:47 pm Post subject: Re: Official lazy person's stupid question thread |
I’ve been trying to figure out what this is and if the disconnected terminal should be back on there, or if it was done deliberately by one of the PO’s.
84 Westy with 1.9 and gowesty aux battery
Any ideas? Thank you as always. |
Paulbeard Samba Member
Posted: Tue Jun 04, 2019 7:29 pm Post subject: Re: Official lazy person's stupid question thread |
At the risk of boring y'all, I am going to repeat and refine an earlier question (this is just for the non-WBX crowd which may account for the lack of uptake):
Has anyone ever removed a dipstick tube (the part that goes into the block/case, that receives the dipstick) and how did you work it? Is it just a steady pull? Obvs i don't need to lube the O-ring, as it's weeping oil which is why I am in this situation. But are there any surprises? Just a straight lift? I could just leave it there, degrease and the surrounding area, and silicone/RTV it. But I'd rather not tempt fate.
I wonder how long this has been leaking and how much oil I have lost over time. When I replace the O-ring, I may take a belt and braces approach and RTV it as well: recommendations welcome. I might also look at a different tube entirely, maybe one that allows me to check the oil from the license plate hatch. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Wed Jun 05, 2019 12:28 am Post subject: Re: Official lazy person's stupid question thread |
As one who has swapped out his engine, I think I can help. I have an AAZ, and if this is the style of engine you have, then this will work.
Yes, just steady pulling while rotating back and forth. The tube is press fit with an o ring.
As a tip, check your oil cooler as well. At the moment, this is where my weeping is coming from. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
Odd_Dutch Samba Member
Joined: March 20, 2011 Posts: 82 Location: The Hague, Netherlands
Posted: Wed Jun 05, 2019 3:02 am Post subject: Re: Official lazy person's stupid question thread |
84WestyHobbes wrote: |
Look like the (broken) part of an auxiliary eberspacher heater.
black box on the left:
https://www.thesamba.com/vw/classifieds/detail.php?id=1879362 _________________ 1980 2.0L Tintop - Subaru EJ-20 conversion |
Posted: Wed Jun 05, 2019 5:02 am Post subject: Re: Official lazy person's stupid question thread |
That’s it, makes sense! Thank you!!!! _________________ 84 Westy with 1.9 wbx |
Posted: Wed Jun 05, 2019 5:29 am Post subject: Re: Official lazy person's stupid question thread |
Team WorldTour wrote: |
As a tip, check your oil cooler as well. At the moment, this is where my weeping is coming from. |
It's an ABA but I doubt our economical friends at VAG used many variations here. Pretty sure I have found the leak…the heat exchanger/filter flange is dry but the indent where the dipstick mounts is generally full of oil and will soak through a rag in short order, even after cleaning it up.
Thanks for the tip. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Sun Jun 09, 2019 4:05 pm Post subject: Re: Official lazy person's stupid question thread |
I have a (real) stupid question:
would it be possible to buy body panels, doors, etc, weld them together and basically build a van from scratch? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32638 Location: Reading Pennsylvania
Posted: Sun Jun 09, 2019 4:12 pm Post subject: Re: Official lazy person's stupid question thread |
VicVan wrote: |
would it be possible to buy body panels, doors, etc, weld them together and basically build a van from scratch? |
I seriously doubt that you could source all of the members needed to make a body new.
There would be a LOT of fabrication on site.
But Yes it could be done if you had the skills.
My Cousin here in NJ specializes in Old British units. I've seen him start with a few rusty field find pieces, he rattles off that its a "1940 whatever, only six were imported into the States" and then he creates an entire car from it.
Yes, he uses parts he can source in the States or from Europe but what he can do with scraps of metal is just shy of miraculous. An aging craftsman........
Ghia
Vanagon
Beetle
VicVan Samba Member
Posted: Sun Jun 09, 2019 8:06 pm Post subject: Re: Official lazy person's stupid question thread |
So... it's not impossible. The most difficult part might actually be getting license plates for the van. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Mon Jun 10, 2019 1:21 am Post subject: Re: Official lazy person's stupid question thread |
IoWesty wrote: |
As the story goes, Bill Gates would always assign a "lazy" person to a difficult problem. His theory was that the "lazy" person would find the easiest solution. |
That’s why you use the Start button to stop your computer _________________ .ssS! |
Posted: Mon Jun 10, 2019 11:15 am Post subject: Re: Official lazy person's stupid question thread |
Ok, real question here for an AAZ motor:
What is this, and where should it be?
[Admin note: non VW pictures are deleted from the gallery] _________________ 1990 Feldjäger Syncro AAZ
Click to view image
jimf909 Samba Member
Posted: Mon Jun 10, 2019 7:56 pm Post subject: Re: Official lazy person's stupid question thread |
[Admin note: non VW pictures are deleted from the gallery] |
Hmmm, did I just miss out on some samba mystery and intrigue? (Yes, that is a lazy person's stupid question.) _________________ - Jim
Abscate wrote: |
Posted: Mon Jun 10, 2019 9:06 pm Post subject: Re: Official lazy person's stupid question thread |
So I opted not to try removing the dipstick and just lathered on some Seal-All® as recommended by the counterman at my FLAPS. Short drive today and there was some oil on top of the new shiny seal which refocuses my attention on the oil filter/heat exchanger which seems to be a little oily where it joins the block. I need to take a longer drive after a targeted cleaning to see if that's the cause. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
Posted: Sat Jun 15, 2019 9:27 am Post subject: Re: Official lazy person's stupid question thread |
Nobody? Anybody?
Here it is again:
We've made it back from Italy, but just barely. Max speed was 105kph, and if I gave it any more gas, it would just spew black smoke out of the tailpipe. I REALLY need some help with this. I'll do a full write up tomorrow about what I've done, what I've tried, and how it worked out (SPOILER: it didn't!). _________________ 1990 Feldjäger Syncro AAZ
Click to view image
kamzcab86 Samba Moderator
Posted: Sat Jun 15, 2019 1:09 pm Post subject: Re: Official lazy person's stupid question thread |
I randomly found this in my garage under the van. Does it ring any bells? 84 Westy with a 1.9 wbx. I took a long look around underneath and couldn’t see a possible spot.
Thanks in advance. _________________ 84 Westy with 1.9 wbx |
michaelbteam Samba Member
Posted: Sat Jun 15, 2019 1:26 pm Post subject: Re: Official lazy person's stupid question thread |
Looks like a luggage rack screw? |
Posted: Sat Jun 15, 2019 1:45 pm Post subject: Re: Official lazy person's stupid question thread |
Seat bolt. Check your seat rails in the middle (or where they should be). _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Last edited by Team WorldTour on Sat Jun 15, 2019 3:22 pm; edited 1 time in total |
Posted: Sat Jun 15, 2019 2:01 pm Post subject: Re: Official lazy person's stupid question thread |
For the bench or for the front ones? I can’t seem to find it. Will look again. Thank you! _________________ 84 Westy with 1.9 wbx |
Posted: Sat Jun 15, 2019 2:16 pm Post subject: Re: Official lazy person's stupid question thread |
michaelbteam wrote: |
It does look like that: I can't see if the business end is tapered but maybe see if one has gone missing. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
