SpoolBug Samba Member
Posted: Wed Jun 05, 2019 10:30 am Post subject: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
So...this is interesting/intriguing and a warning for others..
I bought 2 OEM style steel wheels (4 lug) for my 69 Type 1 from Summit...primed them, painted then cleared them..looking nice..
Then I go to mount my new hubcaps on them and..yeah no way, tried some grease etc and it wasn't even close..
I tried to modify the hubcap and no dice.
So then I researched a little and apparently you have to use a special hubcap from CIP1..well OK ordered those and same deal..slightly closer but no luck.
Looking at the wheel it looks like the nubs on the rim are longer than the stock ones (which look like a small bump).
So long story short..NO HUBCAPS MADE..will fit on these VW Beetle steel wheels...
DOES ANYBODY..know what modifications need to be made to make any hubcap work?
I'm thinking of grinding the nubs down.
Please any input would be great |
Jimbug57 Samba Member
Joined: October 08, 2002 Posts: 817 Location: Mid Michigan
Posted: Wed Jun 05, 2019 11:02 am Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
I bought 2 stock wheels from cip1 and the hubcaps fit -
https://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D6622%2DMB
I don't know if it' worth trying to return the Summit wheels or not. _________________ Repeat after me "I am smarter than metal!" |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Wed Jun 05, 2019 11:09 am Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
Yeah apparently CIP1 sell's 2 different brands, one has the **NOTE: These hubcaps must be used..as stock one's don't fit** (with a link)..me thinking "hey maybe the alt hubcaps would work with the ones I got"..but nope....
Seeing as I have the wheels painted and tires mounted I didn't want to have to buy new ones and do it all again..
There has to be a way to modify the rim to work
Why would they produce wheels that no hubcap fits... |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Wed Jun 05, 2019 11:13 am Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
Aftermarket.... 50% fits 40% of the time. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Jun 05, 2019 11:20 am Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
This is more like 0% fit..if I could get any to fit I'd be happy.
I wonder what the issue is?..seems like a super simple process..the rear OEM's fit every hub caps like butter..
DAMN...so it's gonna be buying new one's, priming, painting, clear and unmounting and re mounting tires all because the freaking numbs are miss-manufactured..llllaaarrrdd...help us
Summit discontinued them...seeing as I painted, mounted etc. they wont return..HA |
Posted: Wed Jun 05, 2019 11:49 am Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
If the problem is diameter you could try cutting a slit 6 or 7 mm's long at a 90 degree angle to the mounting surface at 4 equidistant points along the rim.
I'm reaching I know, but... _________________ Repeat after me "I am smarter than metal!" |
Glenn Mr. 010
Posted: Wed Jun 05, 2019 11:56 am Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
Jimbug57 wrote: |
I'm reaching I know, but... |
I bet they will rust just from moisture in the air once you cut them. _________________ Glenn
Member #1009
#BlueSquare |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 1379 Location: Wichita, KS
Posted: Wed Jun 05, 2019 11:58 am Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
Yeah, aftermarket crap parts often end up eating a lot of spare time, patience, $$$, etc. *sigh*
Maybe try carefully grinding down those "nubs" on the wheels a little, bit by bit, until you can finally get the hub caps to pop over them? Just an idea -- might be worth a try... _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
Glenn Mr. 010
Posted: Wed Jun 05, 2019 12:02 pm Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
I suggest finding a set of good used 4 lug wheels. That should take about 30 seconds.
Media blast them then powder paint them and move on to the next project. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Jun 05, 2019 12:43 pm Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
I totally agree with Glenn on that -- fastest and cheapest way (in the long run) is almost always to just "do it right" the first time. You can pretty much rest assured that OEM stock wheels in good condition are going to fit and work exactly as intended. But aftermarket parts -- who knows? It's a complete crap shoot with lot of that stuff... _________________ 1971 Standard Beetle — fairly stock / driver
Chris333 Samba Member
Posted: Wed Jun 05, 2019 12:48 pm Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
Since we're talkin'. What is the best was to pound hub caps on without denting them?
I have the correct tool to take them off. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed Jun 05, 2019 12:57 pm Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
Assuming you have later stock wheels, you get them somewhat seated on three nubs, then use your palm to tap the EDGE of the fourth nub down.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
vamram Samba Member
Posted: Wed Jun 05, 2019 1:26 pm Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
I had good results w/these from CIP1. Maybe I was part of the luck "50% 40% of the time."
https://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-6622 _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Wed Jun 05, 2019 1:53 pm Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
Chris333 wrote: |
I've got stock wheels and hubcaps on mine, and find I can press them on with palm of my hand -- no pounding required. Like Tim said, you get hubcap started on 2 or 3 of the wheel nubs, and then push on remaining edge that's still sticking out. Does still require some significant oomph / strength in the pressing hand, though, before they finally pop fully into place.
Stock hubcaps are relatively thick and hard to dent by just pressing with your hand. Aftermarket ones possibly thinner though, so probably have to be more careful with those... _________________ 1971 Standard Beetle — fairly stock / driver
ricaroo Samba Member
Posted: Wed Jun 05, 2019 2:26 pm Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
Do you know who manufactured the rims for Summit, maybe contact them for replacement...
Rick _________________ 1971 Standard Beetle 2 dr Sedan 1600dp |
chicagovw Samba Member
Joined: January 06, 2007 Posts: 1419 Location: Chicago IL/CHandler AZ
Posted: Thu Jun 06, 2019 9:27 am Post subject: Re: New Aftermarket steel wheels..ABSOLUTELY NO HUBCAPS FIT?!?! |
You may be able to use the center hub and lug nut covers as used on late base model Mexican Beetles. I believe several suppliers sell them. |
Antonio Trejo VW Parts Dealer
Joined: December 17, 2003 Posts: 937 Location: Mexico City
