iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2041 Location: M*ssholia
Posted: Tue Jun 11, 2019 7:17 am Post subject: Re: Ice Box modern day use |
I put two frozen 1 gallon jugs in the icebox. Went camping last weekend and it was nice weather ( not hot ) - like high 70's nights in 50's. Two day camping trip: the icebox worked well to keep beer, eggs and cheese. My main issue with it is getting in and out of the bus.
Its actually nice to have the flat surface to put drinks, phone, etc when you are in bed. |
srfndoc Samba Member
Posted: Tue Jun 11, 2019 7:24 am Post subject: Re: Ice Box modern day use |
Something like this is a good trade off for space and functionality:
Or this:
Looks like it would be pretty easy to build and uses the same attachment points as the ice box. I actually reached out to RJ Power about doing one and he said no problem although his would be solid wood (not laminate) and he doesn't have the table laminate for the top. Both laminates are available from nlavw.com so someone could do these. Would definitely want to see some sort of drop down table and like the drink holders on top.
Who wants to step up and make a few? I'm down for one. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2922 Location: San Diego, CA
Posted: Tue Jun 11, 2019 10:37 am Post subject: Re: Ice Box modern day use |
I removed the icebox and sink and am in the middle of building a smaller storage cabinet. Two drawers and a cabinet large enough for a Coleman lantern and fuel. This comes about 10 inches from the bulkhead. Frees up a lot of space and makes for more practical storage.
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Tue Jun 11, 2019 1:12 pm Post subject: Re: Ice Box modern day use |
I'm lucky if I can get a few days out of a block of ice in my SO34 _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Tue Jun 11, 2019 11:02 pm Post subject: Re: Ice Box modern day use |
crofty wrote: |
I'm lucky if I can get a few days out of a block of ice in my SO34 |
I've always wondered how they would do. Does yours have the "dam" at the bottom to hold the overflow water in? I would be afraid to load a block of ice into my ice tray. I feel like it might just snap
The original seal on mine is so brittle and fragile that i'm pretty sure it wouldn't do much anyway. I use it to store various dry goods. _________________ Brandon |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Wed Jun 12, 2019 12:13 am Post subject: Re: Ice Box modern day use |
Outlet of the drip tray down pipe has a 1/4 turn valve... right?
Water is hard to heat up (high heat capacity).
It seems like the drip tray w/outlet valve helps to maintain cold.
I understand the obvious deficiencies of vertical hinges vs. horizontal hinges.
Cold doesn’t drop out of an ice chest when opened.
Well... I should say, heat doesn’t enter as well in a horizontal hinge cooler. _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Posted: Wed Jun 12, 2019 7:20 am Post subject: Re: Ice Box modern day use |
oakman wrote: |
crofty wrote: |
The original seal on mine is so brittle and fragile that i'm pretty sure it wouldn't do much anyway. I use it to store various dry goods. |
I freeze half gallon milk jugs or use yeti ice. Neither last long and I insulated the hell out of the icebox. _________________ Your Vanagon sucks, Stop waving at me.
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Wed Jun 12, 2019 9:50 am Post subject: Re: Ice Box modern day use |
busdaddy wrote: |
Real block ice lasts 2-3 days + if you don't open the door constantly and sit there looking at stuff. Freeze your own in 2 qt paper milk/juice cartons and peel off the paper, or use a small storage tote for a mould. Hardcore space fanatics could make a custom cardboard box mould and put a plastic bag inside to fully fill the footprint and height of the rack over the pan.
Freeze every other thing you can ahead of time too, like bottled water, juice, etc.., it doesn't take long to thaw one out if you need it, after a few days it'll be close to liquid anyways, but it was part of a team effort on the way there.
A few milk jugs of frozen water in there a day or two ahead for a pre cool also helps.
Mass consumption things like beer are better off in their own dedicated cooler for easy access beside the campfire and to save getting in/out of the bus and icebox constantly.
If the bus is parked on a slope make sure the tray can drain and consider where the drainings will go, a soggy river right in front of the cargo door makes a muddy bus inside, and parking on an extreme uphill will flood the cargo floor back to under the bed, that's fun to step in at 03:00 |
Best advice for the stock application. I thought my grandfather was being channeled though you BD _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
gitchesum Samba Member
Joined: November 10, 2003 Posts: 513 Location: North Cali
Posted: Wed Jun 12, 2019 4:46 pm Post subject: Re: Ice Box modern day use |
Pick up a lb of dry ice....keep that on your regular block of ice...you’ll be quite surprised. Wrap the dry ice in a paper bag. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Wed Jun 12, 2019 7:32 pm Post subject: Re: Ice Box modern day use |
I'm liking this design.
Can you enter and exit the bus through the front cargo door with this cabinet?
That would be my criteria. I hate how the stock fridge totally blocks that door.
Edit: Just realized this was in a bay window bus, but I think this design might work for unblocking the front door in a splitty camper.
Anchovy wrote: |
_________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Wed Jun 12, 2019 7:52 pm Post subject: Re: Ice Box modern day use |
j.pickens wrote: |
Thanks, the Lino tiles on the floor are 9" square for refetence so about 12" deep for the cabinet counter top from the bulkhead. I'll have it finished and installed this weekend. Here is the cabinet after I skinned it with the original paneling and repro hardware.
Posted: Fri Jun 14, 2019 9:41 pm Post subject: Re: Ice Box modern day use |
Anchovy wrote: |
j.pickens wrote: |
Those handles really give it the '60's OTW camper vibe. Nice! _________________ Founder and Chairman Emeritus, ECMSAS
Posted: Mon Jun 17, 2019 10:42 am Post subject: Re: Ice Box modern day use |
j.pickens wrote: |
Those handles really give it the '60's OTW camper vibe. Nice! |
Thanks man.
Got it finished and installed. I could have gone with hidden hinges but that was another opportunity to turn back the clock.
Posted: Mon Jun 17, 2019 11:04 am Post subject: Re: Ice Box modern day use |
Dude, I didn't realize it was you looking at the consigned - Lee Hedges 68 Double cab
Did you know it was me in the yellow 77?
t3kg wrote: |
1964 1500 S
Posted: Mon Jun 17, 2019 11:07 am Post subject: Re: Ice Box modern day use |
notchboy wrote: |
Yes! Nice bus. |
perello Samba Member
Joined: April 15, 2005 Posts: 830 Location: where social security comes for free
Posted: Wed Jun 15, 2022 5:52 am Post subject: Re: Ice Box modern day use |
a yeti tundra 45 fits perfectly
_________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
