Chas223 Samba Member
Posted: Sun Jun 09, 2019 7:45 pm Post subject: Carb Jets? |
I just moved my THING from Denver Co to Kansas City. I am thinking I need to change the jetting on my carb? Any Suggestions on what I should change to? I am at roughly 1000 ft in elevation coming from 5280 ft.
Carb is a stock Solex 34 PIC-3, stock 1600cc, with a 009 dizzy (yes I know I should have the SVDA).
Drive ability is OK at this altitude, it still has a little bit of a flat spot in it. As if the accelerator pump isn't squirting correctly. But the more I have driven it the better it has gotten. Car has sat for the past year or so with very little driving.
Car seems to be running a tad hot, thus that's why I think it is running lean.
Suggestions where to start? Where do I buy main jets these days? |
hylomatt Samba Member
Posted: Thu Jun 13, 2019 9:48 am Post subject: Re: Carb Jets? |
@Chas - And also, regarding your 009 vs SVDA, the correct carb is dictated by your carb base flange code. there are a lot of different 34pict3s. I have 5 different and they don't use the same distributor. Some run like garbage until you put them with the right DVDA distro and then it's heaven on earth. 800-850 idle and no hesitation on take-off.
Here's the base flange code on one of mine (377-1), for example:
There are a lot of topics and charts for figuring out which distributor was supposed to work with your carb. Once you get the flange number, look it up here by searching or ask here again. |
Posted: Thu Jun 13, 2019 8:34 pm Post subject: Re: Carb Jets? |
Thanks for the help I didn't know a thing about that carb number! |
Posted: Sun Jun 16, 2019 11:55 am Post subject: Re: Carb Jets? |
Ok Here is what I have
VW 427
So what is the correct Distributor that should go with this carb?
[/img] |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Sun Jun 16, 2019 1:19 pm Post subject: Re: Carb Jets? |
043905205 DVDA |
Nitramrebrab72 Samba Member
Joined: November 10, 2018 Posts: 485 Location: France
Posted: Sun Jun 16, 2019 1:44 pm Post subject: Re: Carb Jets? |
You need to get a stock Distributor. 009 timing curve does not correspond to the stock engine /carb timing requirements. |
Posted: Mon Jun 17, 2019 8:15 pm Post subject: Re: Carb Jets? |
Nitramrebrab72 wrote: |
Correct. I believe I have the correct dizzy. Probably needs to be rebuilt.
Thank you for the help. |
Posted: Sat Jun 29, 2019 7:52 am Post subject: Re: Carb Jets? |
The distributor I have (I believe it is original to the car is 113905205) |
Posted: Wed Jul 03, 2019 10:54 am Post subject: Re: Carb Jets? |
Chas223 wrote: |
What is the correct carb that should go with this? |
Posted: Wed Jul 03, 2019 9:49 pm Post subject: Re: Carb Jets? |
That distributor is for a 66-67 bus. Are you sure there are no letters after the number like maybe AN? |
