Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1110 Location: Stanford, CA and Bend, OR
Posted: Fri May 31, 2019 3:15 pm Post subject: |
After 6 years, I'm finally getting around to having the permanent, locking metal top made for my under floor storage. Lid will be made of 0.105" thick steel with formed over twice each edge, then welded at all 5 corners. Welded L-brackets for stiffening and recessed handles. Having the formed edges providing the thickness for the lid will actually allow almost a 1/2" extra storage height inside than the current wood board as the lid will have no bottom layer. Still have yet to determine the final locking mechanism, but I think there are lots of options.
Here's the mockup....
Syncronoid wrote: |
Here's the progress I made today, mostly getting things sealed, final bolt selection and getting the temporary cover cut to fit (still need my sander from my neighbor to dial in the edges).
Cut the two existing bolts out as they were slightly corroded and did not allow enough space between it and the side of the box to fit a nut over.
Silicone injected into openings to seal out dust and moisture.
Rear and front rubber insulation strip to seal the rear of the box where, as a result of the cross cut, left a 1/4 inch gap between the flange and floor.
...front....
Bolt connection. 6 in all.....
Rubber pad cut to fit...
Now just waiting for my neighbor to return my sander so I can finish the temporary wood cover...
[/url] |
_________________ '90 Syncro Westy w/GW2.5L |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6798 Location: Fort Lauderdale, Fl.
Posted: Sat Jun 01, 2019 5:22 am Post subject: |
Syncronoid wrote: |
I'll probably get around to doing mine in 6 yrs. too! _________________ This free advice is worth exactly what you paid for it.
dobryan Samba Member
Joined: March 24, 2006 Posts: 16473 Location: Brookeville, MD
Posted: Wed Jun 19, 2019 12:17 pm Post subject: Re: Lifted Van, Cargo Space Below |
Here's the completed metal lid. Next step is figuring out and installing the locks. Ideas??
E1 Samba Member
Joined: January 21, 2013 Posts: 6369 Location: Westfalia, Earth
Posted: Wed Jun 19, 2019 12:24 pm Post subject: Re: Lifted Van, Cargo Space Below |
Want. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1777 Location: Boise, Idaho
Posted: Wed Jun 19, 2019 12:25 pm Post subject: Re: Lifted Van, Cargo Space Below |
Nice!
Luke:
It's a good thing you have these compartments.
Han Solo:
Yeah, I use them for smuggling. I'd never thought I'd be smuggling myself in them. _________________ Steve
Steve's 87 Syncro project |
Slimvest Samba Member
Joined: March 20, 2014 Posts: 431 Location: Portland, OR
Posted: Wed Jun 19, 2019 1:35 pm Post subject: Re: Lifted Van, Cargo Space Below |
Inspiring stuff. I'm always chasing storage options.
I cut a hole in my roof, so I suppose I could do the same in the floor... _________________ '87 GL w/ Reimo top |
0cean Samba Member
Joined: February 29, 2012 Posts: 1149 Location: California
Posted: Thu Jun 27, 2019 10:06 pm Post subject: Re: Lifted Van, Cargo Space Below |
Locking mechanism coming along......
Posted: Fri Jun 28, 2019 11:52 am Post subject: Re: Lifted Van, Cargo Space Below |
Done! .....except for painting the lid (will likely use spray on bedliner) and putting a nicer trim than duct tape around the edges of the box.
michaelbteam Samba Member
Posted: Fri Jun 28, 2019 2:08 pm Post subject: Re: Lifted Van, Cargo Space Below |
Inspiring "art project." Well done, thanks for sharing! |
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Mon Sep 07, 2020 6:36 pm Post subject: Re: Lifted Van, Cargo Space Below |
super impressive...did you figure out how to deal with the edge condition? _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
Rorke Samba Member
Joined: August 04, 2016 Posts: 255 Location: Traverse City, MI
Posted: Sun Jan 02, 2022 8:16 am Post subject: Re: Lifted Van, Cargo Space Below |
This is my final version. Not fancy and lockable like the others here.
1/2” ply. 3 anti fatigue mats.
When cooler is in place, I can only open the back part. |
Posted: Sun Jan 02, 2022 9:26 am Post subject: Re: Lifted Van, Cargo Space Below |
Adding to this topic for searchers.
This is from my euroBus build topic. https://www.thesamba.com/vw/forum/viewtopic.php?p=9620308#9620308
And I finally started on the under floor storage bin. (I intend this for tools and parts that I hope to rarely have to access. This way I can save the under seat storage for camping and living gear. The other spare parts area will be the bin under the drivers seat.)
When I removed the vinyl plank flooring I discovered that untreated plywood was a bad choice as an underlayment. I will get 1/2" pressure treated plywood to replace this. (Obviously some water had been spilled in the bus and got the plywood wet...)
Nice clean floor ready for surgery.
Opening up.
Treating the open wound edges with rustoleum.
Test fit of the first 1/16" thick aluminum side piece.
Three sides sitting in place. (The rear piece will be placed on after the bin is created as it does not overlap the opening. The bin goes about 4 inches under the floor.)
And the bottom laid in place. The bin now needs to be riveted and 3M 5200 used to hold it together and weatherproof it.
The inside dimension is about 9.5 " wide and 6.5" deep. It hangs no lower than the gas tank or transmission so it should be fine. Basically the same as a propane tank.
[/quote]
And I assembled the storage box.
I will need some spacers for the side closer to the slider since that part does not have the ridges that are in the center portion. Fortunately some leftover jalousie window pieces that are cut off when I do a conversion were just the right thickness.
I pop riveted and 3m5200'd it together.
Now I'll start working on the floor and hatch.
Finished off the lid for the storage bin under the floor.
I went with this handle. It was better quality than the marine handle of similar style and cheaper too.
https://smile.amazon.com/gp/product/B08RYFR6JK/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Routed out the recess for the handles.
Final installation. Need to sweep up....
Storage bin cost $150. _________________ Dave O
The Western Syncro build
Rorke Samba Member
Posted: Sun Jan 02, 2022 10:12 am Post subject: Re: Lifted Van, Cargo Space Below |
That looks factory! Nice |
Rexy128 Samba Member
Posted: Wed Aug 03, 2022 6:23 pm Post subject: |
DASMULE wrote: |
We are fine tuning the CAD models for our under van storage NOW. It sounds like most people are interested in using them primarily for tools. We are also considering a water storage container as an accessory that would fit in the exact space.
Interested to know what all of you would love to be able to use these under van storage spaces for -- the idea is to make a product that people actually want and will use! |
DasMule, did you guys ever refine some of these products? |
jimf909 Samba Member
Posted: Wed Aug 03, 2022 8:39 pm Post subject: |
Das Mule hasn't been here in over a year but they're doing amazing work on other platforms at their shop, Mule Expedition Outfitters. The Syncro was their gateway to overlanding with modern rigs. It's worth a visit if you're in the Seattle area.
https://dasmule.com/
Rexy128 wrote: |
DASMULE wrote: |
_________________ - Jim
Abscate wrote: |
mtnhome Samba Member
Joined: July 17, 2010 Posts: 488 Location: Summit County, CO
Posted: Fri Aug 05, 2022 8:43 am Post subject: Re: Lifted Van, Cargo Space Below |
It appears Das Mule doesn't anything Vanagon specific anymore. They do have some nice accessories and camp/travel gear. _________________ '84 Westy, '93 Subaru ej22 and Subarugears 5speed
Build thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=763098&highlight= |
JohnL99 Samba Member
Joined: September 11, 2012 Posts: 60 Location: Wash DC
Posted: Tue Feb 13, 2024 5:20 pm Post subject: Re: Lifted Van, Cargo Space Below |
Love this concept. Wondering how these boxes are working out for those that have built them. It's another item that I must have. |
